Earth Strap
Submitted: Monday, May 07, 2007 at 07:29
ThreadID: 45164 Views:3957 Replies:2 FollowUps:6
Is it worth while to fit an earth strap to the car ( Car to ground) to improve the performance of a HF radio?
Reply By: Mike Harding - Monday, May 07, 2007 at 08:17
Probably not but with a vertical antenna, which uses the car body as it's ground plane, it may improve things.
Buy on of those giant corkscrew like things intended as a ground stake to attach a dog's lead to ($2 shops) and use some heavy braid or copper strap do not use ordinary wire because at RF frequencies it may have some issues.
You do ask some interesting questions Blue - you're not going to ask which fridge is best next, are you? :)
Mike Harding
AnswerID: 238338
Follow Up By: Ron173 - Monday, May 07, 2007 at 13:44
Go on then Mike, which fridge is best? LOL!!
Ron.... couldnt resist...sorry
FollowupID: 499473
Follow Up By: blue one - Monday, May 07, 2007 at 21:00
I was thinking about tyres.
That was the last HF question for this week.
Thanks for your help.
FollowupID: 499553
Reply By: Tony Middleditch - Monday, May 07, 2007 at 13:58
No. Instead, use a counterpoise. This is a 1/4 wavelength bit of wire (size not important) that would connect to earth at the base of the antenna and simply sit on the ground.
Multiple counter poise wires used around the antenna will in effect be radials. They will markedly increase the amount of RF that actually radiates from the antenna rather than heat up the ground. Short vertical antennas an HF are very inefficient.
Cheers, Tony.
AnswerID: 238388
Follow Up By: Member - Roachie (SA) - Monday, May 07, 2007 at 14:34
I still reckon he's talking about an anti-static strap (car to ground)....One of those rubber straps that hangs down and drags along the road/ground etc.
But; I wouldn't put money on it......It's just the way he's phrased the question (twice now, in fact.....2 separate posts)
FollowupID: 499479
Follow Up By: Mike Harding - Monday, May 07, 2007 at 14:58
Tony:
Having recently completed an experiment trying to use counterpoise lines (which only simulate ground anyway) to perform _exactly_ this task with a vertical antenna for use on 80m and 40m I found I needed at least 12 of them before I started to get a noticeable difference in Rx or Tx signal. My experience concurs closely to that detailed in the ARRL Antenna Book - I seriously doubt one would be any use at all.
Mike Harding
FollowupID: 499483
Follow Up By: Tony Middleditch - Monday, May 07, 2007 at 15:39
Mike, the main purpose of using one counterpoise is as an artificial earth. The advantage of using them over a "real" earth is when experiencing RF feedback type problems.
I found that when I switched from coax to open wire feedline for the wire antenna, that the only way to kill stray RF was to use counterpoises.
I got a decent zap off the CW key! I use 2 wires of slightly different lengths per band. Also, I still use an earth "mat" system under the floor consisting of heaps or copper radials originating from the main earth rod and chicken wire clamped together.
The idea of the mat is to try and have an effective earth to work against when strapping the feeders together thus making the antenna a top loaded vertical.
The main earth rod is under the floor, directly under the antenna tuner.
Mike you may be interested in the present HF wire antenna. It uses home made open wire feeder - estimated to be 600 ohms into a full wave horizontal (sort of) delta loop that is resonant on 40 metres. Works a treat on 30 & 40 with a significant reduction in noise pick up. It does tune on all bands. Performance on 80 has not been fully tested but RX reports would have it down as compared with the 80 metre flat top zepp.
Cheers, Tony
FollowupID: 499490
Follow Up By: blue one - Monday, May 07, 2007 at 21:14
Was embarrassed by the "groung" mistake Roachie.
Ta for your help
FollowupID: 499560
