Towball weight on Ultimate Camper
Submitted: Monday, May 07, 2007 at 08:59
Member - Gerard (NSW)
Hi all,
What towball weight can I expect from a loaded Ultimate Camper.
Also is anyone using a WDH with the TREG coupling. I have heard elsewhere that it can be done but have never seen it. Don't know if it's needed either.
All advise welcome
Gerard
Reply By: DIO - Monday, May 07, 2007 at 09:28
Regarding WDH (Weight Distribution Hitch) have a look at this Link you might find some useful info.
238346
Reply By: Member - Karl - Monday, May 07, 2007 at 09:44
I have heard it can be done as
well - the only problem is that it would greatly reduce the off road ability of the Tregg / Trigg hitches, therefore, if going off road with the WDH fitted is going to be more of a problem than a benefit.
I think better
suspension or air bags (as I have) are a far more appropriate leveling device than a WDH.
If you are not going to take the Camper off road and want to fit a WDH then you might as
well go back to having a tow ball - IMHO.
238349
Reply By: Peter McG (Member, Melbourne) - Monday, May 07, 2007 at 10:18
Gerard
I don't know the exact weight - dpeends how much you store in the boot I think. But we have not needed to any weight distribuition gear. First thying to do with the Pajero will be to look at the
suspension. This will be needed anyway when you start to load it up. If you have a good set of springs installed it should easily take the Ultimate when hitched.
238350
Reply By: Member - Brian A (QLD) - Monday, May 07, 2007 at 12:30
Hi Gerard
I tow an Ultimate Off Road Camper(431) behind my 1995 GXL. I had OME863 Rear Coil Springs fitted along with a set of Polyair Air bags. Although I have never had the tow ball weight checked, I can honestly say I have packed the camper to near capacity and never found the need to resort to the use of any type of weight distribution hitch. A couple of extra pounds of air pressure into the Poyairs and the camper has always towed level and safely. Hope this helps.
Brian
238369
Reply By: Member - Gerard (NSW) - Monday, May 07, 2007 at 18:42
Thanks guys for that feedback. Very helpful for begineers like us.
Our Ultimate is in production as we speak. Can't wait............but will have to.
Gerard
238424
Follow Up By: Gronk - Tuesday, May 08, 2007 at 09:16
You should have a brochure ?? that shows total weight, ball weight etc etc ??
If not just ring them, they will only be too happy to tell you !!! And also advise you on tow hitches etc !!
499632
Reply By: Member - Peter R (QLD) - Tuesday, May 08, 2007 at 11:19
I read somewhere that WDH should be taken off for off road towing.
Pedro
238549
