Tyres GRR & Tanami
Submitted: Monday, May 07, 2007 at 11:11
ThreadID: 45177 Views:3229 Replies:4 FollowUps:12
Heading NW in June for first time - GR & Tanami. Have 2 good spares for the Disco & repair kit. And spare for the CT. What sort of tyre damage should we expect? Is the tyre damage speed related, or is it a given that we're going to do-in tyres regardless? (..or should that be, irregardless)
PS. Have you priced a spare wheel for a Disco Lately? Just the steel one that hangs on the back door. The ba----ds are asking over $1k for a new one. They're rare in wreckers at about $150 per rim. I think I'll find a padlock for mine.
Reply By: Transient - Monday, May 07, 2007 at 12:45
you'll probably find some spare rims on all the dead Disco's lining the GRR.
AnswerID: 238373
Follow Up By: Smudger - Monday, May 07, 2007 at 12:47
Mate, Disco's don't die ..they just have issues.
FollowupID: 499463
Reply By: Member - Kiwi Kia - Monday, May 07, 2007 at 13:00
Don't over inflate, don't try and set a new speed record and you may be lucky. Tanami is just corrugated, GRR has some sharp stones.
AnswerID: 238376
Follow Up By: Smudger - Monday, May 07, 2007 at 13:03
Thanks, that's about what I was anticipating. Planning to drop pressures by about 20%.
FollowupID: 499467
Follow Up By: Steve from Top End Explorer Tours - Monday, May 07, 2007 at 13:39
Hey Smudger
A mate of mine runs tours across the GRR monthly, He runs his tyres at 42 psi he has between 2 to 6 pax and tows a trailer full of camping gear.
I have 4 cruisers that do the Jim Jim road daily, which is the same corrugated type of road as the GRR.
That means my trucks do 700km each per week on this road, I run my tyres at 40 F and 42 R neither of us have a problem with tyres blowing out.
IMOA lowering tyre presure on this type of road is asking for trouble.
Cheers Steve.
FollowupID: 499472
Follow Up By: Smudger - Monday, May 07, 2007 at 17:57
I hear you Steve,
But my truck spends 90% of it's time in Sydney traffic, so I run ATs. I'm guessing that your trucks have more aggressive rubber. Having said that, in the good old days when we did the Nullarbour in our Holdens with pretty basic radials, we never let the tyres down. And the only problems I had was picking up the tacks that the servo's used to drop on the bitumen roads as you came into town. Never lost a tyre on the bulldust, and crossed it 5 times before they sealed it.
FollowupID: 499511
Follow Up By: Steve from Top End Explorer Tours - Monday, May 07, 2007 at 21:23
Hey Smudger
I run OZ made D693 265/75/16 bridgestones.
Steve.
FollowupID: 499564
Follow Up By: Off-track - Monday, May 07, 2007 at 23:19
Yep, I'm with Steve - 40-odd PSI. Higher pressures will reduce the chance of sidewall damage due to bulging and prevent too much flexing in the carcass tread area.
FollowupID: 499597
Follow Up By: Member - Kiwi Kia - Tuesday, May 08, 2007 at 08:17
If you don't want sidewall bulge then don't use radial tyres, fit x-plies.
Radials are designed to flex in the side wall and over inflating negates this. Radial tyres should be considered as being part of your vehicles suspension system and are designed to help give you a comfortable ride but don't do this if over inflated.
FollowupID: 499625
Follow Up By: Smudger - Tuesday, May 08, 2007 at 11:26
That reminded my of a convesation I had with couple of roo shooters at the Middleton Pub a couple of years ago. They told me that they run XPly rags at 70psi. True story ..they told me, "Ride's a bit rough, but they're so bloody hard, even gidgee stakes can't get through 'em."
FollowupID: 499647
Follow Up By: Off-track - Tuesday, May 08, 2007 at 12:01
But it comes back to the point that if you dont want a puncture use higher inflation pressure to reduce sidewall bulge...pretty simple stuff really. On BFG AT's 42psi is not the upper limit either so it's not like they're being overinflated.
Besides, who runs xply's on 4WD wagons?
www.beadell.com.au/tyre_construction.htm <<some good info
FollowupID: 499649
Follow Up By: Member - Kiwi Kia - Tuesday, May 08, 2007 at 13:28
Hi off-track,
To quote from your link to Beadell Tours;
S.B.R 4WD tyres are the best compromise for On-road and Off-road work. Steel plies under the tread of the tyre give strength and rigidity for high speed On-road travelling, while also giving the ability to bend and grip reasonably well while Off-road.
The sidewalls are thin and supple, allowing little heat build-up at high speed thus reducing tyre wear. These same thin sidewalls can also be used as shock absorbers for Off-road. By letting your pressure down a few psi, the tyre will absorb many of the corrugations and potholes with ease. Most importantly it should reduce the risk of damage, as the tyre with less pressure will "give way" so an object won't damage it, (try popping a half flat party balloon). This makes travelling much more comfortable and less strenuous on the suspension and chassis of your vehicle.
I agree with what they say. Don't run tyres so hard that the side walls are firm, and, they give both you and your suspension a better ride.
What 4wd uses x-plys ? I reckon I would have more chance of getting a x-ply tyre for a Troopie ANYWHERE in Australia then you would looking for a radial (note I say ANYWHERE). But that is not the point, I am not saying you should use x-ply tyres. I am saying that you should not run radials so hard that they have a rigid side wall.
FollowupID: 499654
Follow Up By: Off-track - Tuesday, May 08, 2007 at 16:24
Ahh yes but I did say '4WD Wagon' for that very point. ;-)
Staking damage through the sidewall is more risky through underinflation where the sidewalls balloon out than higher inflation where the sidewall is flatter. This is the point that is being discussed.
You are indeed right to say that lower pressures increase comfort but that means little when the tyre has been punctured through lower inflation pressure. Of course the opposite spectrum to this is absolutely rock-hard tyres rattling the crap out of the vehicle but this would be no more than if x-plies were fitted.
And again you are right in stating x-plies are the preferred option in rough terrain where punctures are at risk but the tyres being discussed are AT's so the best outcome (apart from fitting x-plies) is to inflate them to around 40-42psi, not deflate them. (Without looking at them I believe the quoted upper limit is around 65psi for BFG AT anyway)
FollowupID: 499666
Follow Up By: Member - Kiwi Kia - Tuesday, May 08, 2007 at 16:28
Hi again Off-track,
I go along with everything except the pressure. Actually I hate x-ply and leaf springs, but, horses for courses. I will stay with 26 -28 psi and enjoy the scenery :-))
FollowupID: 499667
Reply By: Dave & Shelley (NT) - Monday, May 07, 2007 at 21:20
Hi Smudger,
I can only re-enforce what the others are saying. Most of the other guys are running with larger weights so need that extra air in the tyres.
You will get chip damage from rocks etc on the GRR and the Tanami Road is definitely corrugated. I ran about 30 PSI F and 34 PSI R along the Tanami. I had around 30 PSI in the Camper tyres but it is an early Kimberly Kamper and only weights around 700 fully loaded (including water). These did chip out some what but they are Kelly tyres, not BFG's or anything to expensive.
As for the disco steel rims, I should have not given mine away for a carton. I bought a lot of stuff from a mob down at the sunshine coast call "British off road" off memory and they had a lot of stuff like tyre rims etc. Give it a check.
Happy travelling
AnswerID: 238467
Reply By: Member - Royce- Monday, May 07, 2007 at 23:06
Pulled off the road near the Granites about 10 years ago and punctured two tyres [4wd and trailer] on short stubs ... sticks. ... old bits of stumps of the bushes out there. Luckily had spares for both vehicle and trailer. So.. careful off the track.
AnswerID: 238503
