Electronic Brake Controller Question
Submitted: Monday, May 07, 2007 at 22:30
ThreadID: 45201 Views:2564 Replies:7 FollowUps:0
I have a LC100 series, where do most of you LC100 Series owners locate your Elec Brake Controller in side the vehicle, (If you have one for towing a caravan with elect brakes)
Reply By: apriti00 - Monday, May 07, 2007 at 22:39
I have a 02 auto and made a bracket which used the two blanks next to the t bar as I wanted to have clear access if I wanted to use the manual control, a mate used the ashtray hole.
AnswerID: 238492
Reply By: Cammo - Tuesday, May 08, 2007 at 08:33
I had mine right next to the steering column. The ashtray already had the battery monitor.
AnswerID: 238530
Reply By: Member - Wim (Qld) - Tuesday, May 08, 2007 at 10:38
Mike.
Astray hole. Works a treat.
Camper setup
July 2012 - Hay River & Binns track
VKS 737 Mobile 0091
Selcall 0091
AnswerID: 238542
Reply By: tuck 01 - Tuesday, May 08, 2007 at 10:39
Mine is directly in front of my left knee, on the bottom section of the dash.
Manual gear box.
Never been in the way of "clutching". Easy to reach if needed.
AnswerID: 238543
Reply By: Member - Raymond S (QLD) - Tuesday, May 08, 2007 at 16:44
It's important that it is in a position that you don't have to look away from the road to find it as the above threads have said. Put it as close to the gear stick so all u have to do is drop your hand down onto it, u learn fast from past experiences.
AnswerID: 238599
Reply By: aceman - Tuesday, May 08, 2007 at 18:04
I have 03 LC100 T/D Auto and have (small) solid state Hayman Reece controller
located to the right of steering wheel directly under the elec mirror switch.
Works for me.
Leigh
AnswerID: 238616
Reply By: japmel - Tuesday, May 08, 2007 at 20:39
I have a Tekonsha Prodigy controller in the Ashtray Hole, Fits really well and it is easy to get to.
Should add that is in a 2002 100 series.
AnswerID: 238663
