Second battery needed for fridge
Submitted: Wednesday, May 09, 2007 at 12:51
ThreadID: 45260 Views:3566 Replies:8 FollowUps:18
We just bought a Waeco 5O litre fridge and are after a second battery for the car. We already have a second battery installed but it is only a truck battery and have been told that we need a deep cell instead.
An electrician friend of ours suggested a Hybrid MRV70 deep cell. He can get us one for around $140.
Has anyone got one of these batteries? Are they any good? Any info would be great. thanks
Reply By: Member -Signman - Wednesday, May 09, 2007 at 13:26
I've been using H/D wet - non deep cycle, cranking- truck batterys for many years with no probs. Generally last for 4 or more years, or I change them when I see them on special. I do rotate the cranking/ aux. batts. every 6 months or so.
I'm yet to be convinced that 'Deep Cycle' are a necessity for an aux. battery.
AnswerID: 238803
Follow Up By: Michael ( Moss Vale NSW) - Wednesday, May 09, 2007 at 13:33
Yep!! I tend to agree, just dont drain them too much and they last to a normal life.. Michael
FollowupID: 499841
Follow Up By: Time - Wednesday, May 09, 2007 at 14:04
Also yep, what signman said. Cranking battery will work fine, it has done for me for years.
FollowupID: 499843
Follow Up By: Red Frog - Vic - Wednesday, May 09, 2007 at 14:28
yep and they charge faster compared to a deep cycle
FollowupID: 499845
Follow Up By: Mainey (WA) - Thursday, May 10, 2007 at 00:15
yes Cranking batteries WILL charge faster than all Deep Cycle battery that's a known fact, reason being they have thinner plates and do not have the continuous high drain cycling advantage of Deep Cycle batteries.
Cranking batteries can't be drained as low as a Deep Cycle batteries according to every battery manufacturer's web sites on the net or the various battery 'information' web sites either.
The most effective battery to run a fridge is an AGM Deep Cycle, as it will recharge much faster than any Cranking battery and cycle even lower than any wetcell Deep Cycle battery, but yes they do cost more, so if you want a compromise use something else, however if you want the BEST performance from an Auxiliary battery get an AGM Deep Cycle battery.
Anyone who has used an AGM and found it unsatisfactory please state the perceived reason and the charging/battery system specifications...
FollowupID: 500018
Reply By: Gossy - Wednesday, May 09, 2007 at 15:08
Deep cycle batteries are in the market for a reason. Unless you only do overnight trips you will need a deep cycle. Save your fingers in typing about debating this with anyone. You want a battery that you can safely run flat whilst camping in one spot for a couple of days or more, pack up and move on and not worry all day if you killed your battery. They are worth every cent. No point spending $900 of a fridge and saving $50 on the wrong battery which dies and then you can't run your fridge anyway!
AnswerID: 238821
Follow Up By: Member -Signman - Wednesday, May 09, 2007 at 16:15
Hey Gossy
You sure you can keep flattening a 'deep cycle' battery- and expect it to keep charging full, with max. output???
FollowupID: 499867
Follow Up By: Member - Phil G (SA) - Wednesday, May 09, 2007 at 20:38
I'm with Signman - Most wet cell deep cycle batteries only come with a 6 month warranty .....for a reason!
FollowupID: 499934
Follow Up By: Leroy - Wednesday, May 09, 2007 at 20:41
you will kill any battery running them dead flat. Deep cycles are no exception
Leroy
FollowupID: 499936
Follow Up By: Mainey (WA) - Thursday, May 10, 2007 at 00:36
"Most wet cell deep cycle batteries only come with a 6 month warranty, for a reason" and the reason is ??
Quality wetcell DC batteries have a 12 month warranty, Cranking batteries have a 2 year warranty because they are ONLY used to start cars, not run as Deep Cycle batteries.
Quality AGM Deep Cycle batteries have a 10 year life expectancy, my previous Delkor Deep Cycle batteries lasted 4+ years when I replaced them, I gave one away to a guy who needed it more than I did and replaced my 4yo overlander 700cca Cranking battery with the other, that Deep Cycle battery has been used for 13 months as my Cranking battery and is now over 5 yrs old.
I replaced the Deep Cycle delkors with 100+ ah AGM's and had them tested only last Saturday, they were producing in excess of 1,200cca and easily passed the Deep Discharge testing applied to them by their supplier.
Dead flat is often stated as being 12v, however most battery isolator switches and fridge cut-out systems are set for around 10.5v to 10.8v which is well below what the battery is designed for, constantly running batteries to this low level cause the battery to die prematurely, as has to be expected.
FollowupID: 500023
Follow Up By: Red Frog - Vic - Thursday, May 10, 2007 at 00:49
Mainey, the dead flat at 12v you mention, is that under or off load ? Obviously the cut-out voltages 10.5v to 10.8v must be under load but at what current draw. My fully charged cranking battery drop to around 8 volts when cranking but recovers almost immediately.
FollowupID: 500026
Follow Up By: Mainey (WA) - Thursday, May 10, 2007 at 01:02
No load....12v is dead, however can often be recharged.
Yes the 10.5v figures are under load, however the load would only be about O.4v
My "power hungry" fridge draws ~10Amps (running) and only drops my voltage O.5v.
Your Cranking battery drops to 8v only because it's built to use a massive power drain only for a few seconds when starting the vehicle, and yes it recovers immediate because either the alternator recharges it again or the natural battery acid reaction returns it to 12.6v that's what happens in a healthy battery.
FollowupID: 500028
Follow Up By: Member - Phil G (SA) - Thursday, May 10, 2007 at 09:07
Mainey,
The "reason" most wet cell deep cycle batteries ONLY come with a 6 month warranty is the way they are used and abused, as a second battery under the bonnet of a 4wd.
If you repeatedly do what Gossy suggests (discharge to dead flat), then you'll trash the battery. In addition, because they recharge slower, they are less likely to be recharged by a vehicle alternator to a reasonable charge state in a short space of time, so they sulphate.
FollowupID: 500052
Follow Up By: Mainey (WA) - Thursday, May 10, 2007 at 22:38
Phil,
I used the word "quality" – yes some 'budget priced' DC batteries may only have a 6 month warranty, however better "quality" built batteries that cost more than the average low priced battery do have a better warranty and do give superior service and most quality built AGM’s actually have a 10 year life expectancy.
You will only get what you are prepared to pay for.
Yes, a battery will sulphate when it sits with no charge applied and while in a very low state of charge for any reasonable period of time, which equals low battery maintenance, not by discharging and charging often and fully.
No battery will be abused IF the battery "system" is correctly set-up in the first place.
My own system has never been seen below 12v at any time, day or night, it's just a matter of having the correct sized capacity battery / batteries, cabling, auto battery disconnect system and most importantly recharging system available.
I draw only of the top of my ~2OO+ ah Auxiliary battery system, if it was of lower capacity obviously I would drain it deeper and more often, which would shorten the useful life of the battery. My first Deep Cycle battery was an American made mega expensive failure, simply because it was only 90ah and it drained to far & too often, it only lasted about 3 years.
My next system was 2 x 80ah, they lasted 4 years and I replaced them, not because they were small or faulty simply because they were 4 years old, I now use one of the batteries as my Cranking battery and its been doing that job since March 2006 when I replace them with 2 x 100+ ah AGM’s.
Because I choose to camp in one place for weeks at a time without driving the Aux battery system has to be fully self sufficient in capacity and also it’s recharging system and basically because I’m lazy I use Solar as the recharge power source.
Those who only rely on the alternator to recharge their Auxiliary (often only 1 & also undersized) battery should not expect to get the same life or performance from their Auxiliary battery system as those with fulltime recharge facilities available for their Auxiliary battery system.
FollowupID: 500216
Reply By: Gossy - Wednesday, May 09, 2007 at 16:32
yep, that's exactly what it's built for. Thats why this type of battery has its share of the market.
AnswerID: 238830
Reply By: Member - Bentaxle - Wednesday, May 09, 2007 at 17:21
Fiona
You want/need a deep cycle battery for a second battery, truck batteries/cranking batteries are designed to deliver maximum power for a short period, ie starting. They don't like supplying constant power over a long period of time and will "Kark it" very quickly. Deep cycle batteries are designed to supply power for extended periods and can be run almost flat, recharged for a number of times before they show signs of "Karking it".
Mike
May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
AnswerID: 238837
Follow Up By: Red Frog - Vic - Wednesday, May 09, 2007 at 18:08
Hmm, then how come cranking batteries do such a good job of powering a fridge ? is it because a fridge switches on and off, not demanding constant power ? My cranker (exide extreme) which is used mainly for the Engel is still good after two years, it also charges a lot quicker than my previous deep cycle.
FollowupID: 499890
Follow Up By: Member - Bentaxle - Wednesday, May 09, 2007 at 18:45
Red Frog
What else do you run of it apart from fridge, try running camp lights (fluro,) laptop& GPS, radios, diff lockers and you will find the average cranking battery can't withstand the demands. Fiona may not be running anything else apart from fridge at moment but as you know you soon start adding things to the truck that require power as well.
FollowupID: 499904
Follow Up By: Red Frog - Vic - Wednesday, May 09, 2007 at 19:34
Thanks Bentaxle, I'll keep that in mind.
FollowupID: 499910
Follow Up By: Leroy - Wednesday, May 09, 2007 at 20:46
generally Mike when you are running the laptop, gps, radios etc you are using your vehicle so not really an issue ie engine running and you're driving around.
Don't know about the battery operated diff locks though. They may draw a lot of current while stationary over night!
Using a fluro only draws around 1ah so not a big burdon on any batt.
Leroy
FollowupID: 499938
Reply By: obee - Wednesday, May 09, 2007 at 20:52
I will be using the marine battery from the boat cos I cant use boat and camp at the same time and might as well put the thing to good use for the cost of owning it. They say marine bats are semi deep but my main concern is controlling the amount of current after running it down overnight. It is also said deep cycle bats dont like intitial fast charge.
I am going to find out soon if the cable I am using (I estimate 20 amp capacity cable) is going to melt. I read all I can find on this site but I still aint sure of the physics.
Owen
AnswerID: 238914
Follow Up By: Mainey (WA) - Thursday, May 10, 2007 at 00:42
Marine batteries are 'different' only because of the method of "attaching" the plates to the case... to avoid damage caused when the plates vibrate around in a boat, which is much rougher than in a vehicle.
FollowupID: 500025
Reply By: Leroy - Wednesday, May 09, 2007 at 20:54
I replaced all the UPS batteries at work the other day (i have many 5ah batteries to power the shower, camp lights etc) and had a good chat with our supplier and he reckons calcium batteries are the go now. He sells AC Delco and reckons they don't cost that much more that wet cell batteries and will last longer. I remember a few posts on the topic some time back so could be worth a search.
Many will be happy to hear my 18 mth exide exteme after 24v hrs running the engel is measuring aroung 12v where friends with me are measuing 12.5v with the same 40l fridge. I think it may be dying a slow death lol. But it won't put me off buying another as everone else is getting 2+ years and maybe I've been nursing it too much as this battery has only had to power the fridge and lights for overnight trips (24hrs at the most). But it maybe time for a change.
Leroy
AnswerID: 238916
Follow Up By: Mainey (WA) - Thursday, May 10, 2007 at 00:50
My 5 yo Delkor Deep Cycle batteries are Calcium.... lol
As to measuring the voltage of a battery that has recently run a fridge for 24 hours it has to be expected it would be 12v not long after the fridge has stopped, however if RE-tested about 2 hours later it would then read in excess of 12.5v
If the battery is 12v some hours after running the fridge, it's close to dead !!
FollowupID: 500027
Reply By: Gossy - Thursday, May 10, 2007 at 09:21
it seems that batteries get the same passionate response as tyres. Reading between the lines (as with tyre forums) people get passionate and disagree because they are defending their own purchase for their own vehicle. Bottom line is that manufacturers make these batteries for a reason and for the market share they are aimed at. Sure you can survive with a normal battery and be happy with it's results but running your fridge and lights and the deep cell being used under exactly the same conditions will give better results and longer life.
Compare them to tyres. Yes I can drive to Birdsville in Mud Terrain or AT tyres. Both will get me there fine but the tyres have been made for a different reason. When it rains the MT will get me home rather than being bogged with the AT because it's now being used for what the manufacturer made it for.
Anyway I think you now have enough information to make your own choice. Either choice will run your fridge but only the deep cell will give you better value for money over the longer term.
AnswerID: 239031
Reply By: Shaker - Thursday, May 10, 2007 at 22:42
Delkor Calcium are hard to beat, it's all we use in the CT
AnswerID: 239185
