Patrol oil bypass pressure
Submitted: Wednesday, May 09, 2007 at 17:08
ThreadID: 45266 Views:2444 Replies:6 FollowUps:5
Does anyone know what the oil filter by pass pressure is for the GU turbo 4.2 diesel????
This is the pressure that the relief valve opens if the filter is blocked or viscosity of oil is to high etc. Most filters have this valve in them but for the patrol it's mounted in the cooler on the block. It's not the pump relief valve pressure but the filter by pass pressure.
Reply By: Keith_A (Qld) - Thursday, May 10, 2007 at 17:34
Hi Aust - I thought at least Roachie or Truckster would come to rescue.
I will ask my mechanic when I see him next, as I am fairly certain he has a workshop manual on our beasts. Will post back here......................Keith
AnswerID: 239098
Follow Up By: Austravel - Friday, May 11, 2007 at 13:23
Thanks Keith. Any help would be great.
FollowupID: 500305
Reply By: Keith_A (Qld) - Friday, May 11, 2007 at 13:41
Hi Ray - I visited Mario, my 4wd Mechanic today. He did own a GQ and now has the 4.2 GU - plus he has the official Nissan GQ manual.
We searched it and found the diagram which clearly shows the pressure relief for the oil filter - it is in the body where the filter screws on. Mario said it looks almost identical to other Nissan oil filter housings (eg the 200B etc). Having serviced them, he commented they are not very high pressure - you can depress them easily with a finger. ( I found the same with the the relief valve in the Z9 filter.)
But no-where in the manual - either on the page with the diagram and data, or in the specification pages does it say what the bypass pressure is. It did give the oil pressure as 11psi at idle to 54 psi.
Sorry I cannot give any more detail - it just was not in the GQ manual.
This is a puzzle that definitely needs solving . I wonder if Nissan has a tech email address or phone number....................Keith.
AnswerID: 239284
Follow Up By: Austravel - Friday, May 11, 2007 at 17:07
Thanks Keith,
Did you see my latest response to your email on another site regarding the Z9, I assume your the same Keith??
Looks like there's no major dramas in using the Z9 which is what I've been doing for a couple of years now. Backed up by oil tests.
Nissan used to have a help line but it's since ceased for anyone other than Nissan staff. However Nissan here in R'ton gave me the same data as you did but couldn't find a pressure for the by pass relief valve.
FollowupID: 500330
Reply By: Keith_A (Qld) - Monday, May 14, 2007 at 14:05
Hi Ray - I contacted a friend who works for a Nissan dealership.
He searched the GU on-line manual. The service procedures are there (simply press and check) and the repair procedure - replace, but again nothing on the actual Psi of pressure release.
He is going to email Nissan HQ and see if he can chase it up.....Keith.
AnswerID: 239928
Follow Up By: Austravel - Monday, May 14, 2007 at 14:18
Great news, thanks for that. Will be interesting to see if they have an actual value.
FollowupID: 500911
Reply By: Keith_A (Qld) - Tuesday, May 22, 2007 at 08:58
Hi Ray - I rang the Nissan Service guy today, and the Australian H/O did reply to his question, but they simply sent back the oil pressure range : 11 to 58psi.
Either they mis-understood the question, or they also don't know the answer.
He is going to send an email to a Nissan technical engineer in Melbourne.
Will post any reply recd..................Keith
AnswerID: 241524
Follow Up By: Austravel - Wednesday, May 23, 2007 at 21:01
Thanks Keith will be interested to hear.
FollowupID: 502916
Reply By: Keith_A (Qld) - Sunday, Jun 03, 2007 at 14:40
Hi Ray - unfortunately no response from Nissan HQ.
It seems that nobody can answer this very simple question.
No doubt there is an old mechanic somewhere who does know.
Would you mind either posting or emailing me the results of your oil analysis over time? Not the exact details, just the conclusion at 7,500k then 10,000K etc.
I often think that with advances in oil technology (I run a semi synthetic) we should be able to extend oil drains, but the final proof is the actual oil analysis.
Thanks......................Keith
AnswerID: 244368
Follow Up By: Austravel - Tuesday, Jun 05, 2007 at 09:16
Can fax it if you have a number.
FollowupID: 505917
Reply By: Keith_A (Qld) - Tuesday, Jun 05, 2007 at 17:13
Thanks Ra y - Fax 07 3376 4548
regards.....................Keith
AnswerID: 244945
