Dead Waeco
Submitted: Saturday, May 12, 2007 at 10:25
ross
Hi I was supposed to be going away this morning and woke to find my waeco CF50 had stopped running on the 240 volt plug. Ive tried the 12v and no luck there.
Its completely dead,no flashing at all.
It was working fine when I checked it at 5pm yesterday.
Is there a fuse and if so how do you get to it?
Reply By: MickeyJ - Saturday, May 12, 2007 at 10:32
Ross,
SOmetime the plug in to the side of the fridge has a bad contact. You can try giving that a wriggle.
Otherwise does it come on when you flick the bypass switch? If it does then the control circuit is faulty.
I don't think there are any simple fuses on them, but there is one soldered to the electronics board I believe.
Mickey
239510
Follow Up By: Shane (QLD) - Saturday, May 12, 2007 at 11:04
I'm sure you will find a fuse in the cigarette lighter plug end. I have a WAECO 45ltr & it has this fuse. Check the fridge end of the lead with a multimeter to see if it is getting power.
500490
Follow Up By: Shane (QLD) - Saturday, May 12, 2007 at 11:08
Sorry Mickey J this was meant for
Ross !
500492
Follow Up By: MickeyJ - Saturday, May 12, 2007 at 11:24
No worries, kust looked inside my waeco CF 50 plug, and no fuse, but there maybe in the later ones.
500494
Follow Up By: Brew69(SA) - Sunday, May 13, 2007 at 07:28
Look harder..they all have one.
500618
Reply By: Member - Reiner G (QLD) 4124 - Saturday, May 12, 2007 at 11:51
So you didn't go away because your fridge didnt work?
Just wondering :-)
Reiner
239518
Follow Up By: Member No 1- Saturday, May 12, 2007 at 12:27
i would'nt.....cant drink hot amber nectar
500503
Reply By: ian - Saturday, May 12, 2007 at 12:38
Ross,
there will definately be a fuse in the lighter socket end plug. Its not glass, I think its ceramic, with a thin metal line.
Plug that fits into fridge likely culprit, it was in
mine.
Ian
239522
Reply By: Member - Peter R (QLD) - Saturday, May 12, 2007 at 12:43
Sometimes the CF50 goes to sleep when plug is dislodged.
Simply hit the on switch and see how that goes.
It happened to me and I took it to Waeco and they showed me what to do
Pedro
239523
Reply By: whitehorse - Saturday, May 12, 2007 at 15:15
hi
Ross ,this also happened to my cf60,there is a fuse in the cig plug on the fridge cord,8 amp on
mine, you have to disasemble the plug i hope this helps cheers
239540
Follow Up By: bbuzz - Sunday, May 13, 2007 at 10:56
I have a CF45 I am not using anymore if you cannot get your 50 working. Do not want the world for it. Seems to be a shame someone cannot get to use. Not used much.
500641
Reply By: ross - Sunday, May 20, 2007 at 21:51
Sorry for the late reply. I rang
Ranger camping that morning and was told there is no fuse ,even though it says fuse on the plug panel.
They asked me to bring it down and their resident fridge expert found the dead fuse.
So we put a new fuse in and still no go,but got it it to work on another 12V outlet.
Further investigation found a loose wire on the 12V plug in the rear of my ute.
Rainer ,The fridge was central to my trip as I had already chosen and bought the food and as I was staying about 70klms from Mt Magnet in the bush.
It would have meant leaving the following day as I needed daylight to set up and it was a good days drive.
I took some spare fuses for the fridge but had no need of them.
Still a mystery why the fuse blew on while plugged into the house current.
241282
