IN CAR CAMCORDER MOUNT
Submitted: Saturday, May 12, 2007 at 22:48
ThreadID: 45412 Views:6016 Replies:11 FollowUps:12
I am going to be 'doing' the Simpson in early July with a couple of other 4x4 but am driving alone in my vehicle.
There will be times when I will want to get some 'action video' as I am driving.
Obviously I don't want to be driving 'one handed' with the wheel in one hand and the camcorder in the other.
Does anyone know where I can buy a store bought suction mount that would hold a Sony camcorder, probabaly using suction cups direct onto the inside of the window.
I have done a google search, I have looked at the Ram Mount website etc.
A few years ago I saw one in a camera shop in Malaysia but didnt buy it so I know they are being made commercially - just havent seen one here
Reply By: KiwiAngler - Saturday, May 12, 2007 at 23:01
This is the sort of thing I am looking for
In car camera mounts
Scroll down to SM5 and SM7
Anything like this in Aussie?
AnswerID: 239625
Follow Up By: KiwiAngler - Saturday, May 12, 2007 at 23:07
There are some clever people around when you start to follow up on a thread like this :-)
Storm chaser camera set up
FollowupID: 500606
Follow Up By: KiwiAngler - Saturday, May 12, 2007 at 23:15
This is getting closer
Headrest mount
FollowupID: 500611
Follow Up By: DIO - Sunday, May 13, 2007 at 00:42
You could always plug a small camera (from Jaycar or similar) into a capture device (USB) on your laptop and save images/video there. Camera capabale of good high resolution will give good results.
FollowupID: 500615
Follow Up By: KiwiAngler - Sunday, May 13, 2007 at 08:11
Don't really want to use the laptop to do this as some of the filming will (by definition) be done in corrugations and or bumpy off raod driving - I belive I can make the handycam more stable than I could the laptoip - nece my focus (excuse pun) on using the handycam :-)
FollowupID: 500620
Reply By: Truckster (Vic) - Saturday, May 12, 2007 at 23:12
Even better, goto Jaycar, and buy one of their small cameras, mount it in a small perpex box, and mount it on the bullbar - this way you dont get the glare off the screen/dash
Then you can lay the video camera in a bag, on the floor in the car, where it wont get damaged, and run the cord from one to the other.
EG: but doesnt have to be this one....
AnswerID: 239627
Follow Up By: KiwiAngler - Saturday, May 12, 2007 at 23:48
My camera doesnt have provision to plug a second device into it - but I like your lateral thinking :-)
FollowupID: 500613
Reply By: Member - Doug T (W.A) - Sunday, May 13, 2007 at 01:32
I got some good shots on the Googs Track by taking the mittor off and fixing it there , my Mirror brackets are the same as those on Landcruiser Traybacks
AnswerID: 239640
Follow Up By: KiwiAngler - Sunday, May 13, 2007 at 08:12
How did u affix it to your mirror mounts?? - do u have pics that u could post showing this? :-)
FollowupID: 500621
Follow Up By: Member - Doug T (W.A) - Sunday, May 13, 2007 at 09:59
KiwiAngler
You don't need to see a photo , use your imagination, picture in your mind the camera , it has under it a threaded hole for mounting on a tripod, so all I did was obtain a small bolt of same size , remove the R/H mirror from the bracket and and afix the camera in the same hole, next time you see a L/C Trayback have a look at the mirror bracket , but if your vehicle has those fancy flashy mirrors then this idea is not for your's,
Doug
FollowupID: 500632
Reply By: Member - Doug T (W.A) - Sunday, May 13, 2007 at 10:07
KiwiAngler
I totally missed the point here didn't I . Your post is about IN CAR CAMCORDER MOUNT , My mirror bracket idea is OUT CAR CAMCORDER MOUNT.
Doug
AnswerID: 239672
Reply By: Gob & Denny - Sunday, May 13, 2007 at 11:19
goodday kiwi
that sm7 looks just the ducks guts for what i want for my camera woman as we get a lot of sky shots
just got to find a retailer in melb will go into eliabeth st next sat and have a look around
steve
AnswerID: 239685
Reply By: V8Diesel - Sunday, May 13, 2007 at 11:54
The mounts in Kiwi's first post are the go but very expensive. I have worked professionally mounting 30kg 35mm movie cameras worth $600K plus on vehicles (Grip) and have a huge amount of respect for the limpet mount systems for lighter stuff. They look dodgey but work brilliantly.
BUT.....they are very expensive. All the gear can be purchased locally from Panavision (aka Greedyvision) in Artarmon Sydney and Cameraquip in Clarendon St Melbourne (not too sure if that's Panavision these days as I don;t do much in Vic) or a comapny called Lemac. All should have websites.
You could also check out the ACS (Australian Cinematographers Society) and the CML (Cinematographers Mailing List) for more info.
My advice is that a handy cam is the way to go. You need a zoom lens to get a good frame and have the abilty to vary it. You should also find the manual apperture lock so the camera doesn't 'hunt' for correct exposure between inside and out.
Another handy tip is to make a lightproof box out of matte black cardboard and gaffer tape from an art supply shop to go between the lens and windscreen. This will avoid the nasty reflections so you don't get a tape full of reflected pictures of the front of your camera rather than what's happening outside. It is the same principal as when you cup your hands around your eyes to look inside a car or shop window.
We often use a 'Cine Saddle' which is just a 'U' shaped canvas bag filled with foam bean bag balls that seems to 'grasp' the camera like a human hand. Often the super serious rig will vibrate too much, so a bit of low tech will often work better. CineSaddle These are great but far too big for your application. Maybe something like this but smaller velcroed to a dash mat would be an idea. I'm sure someone's Mum could whip it up out of an old pair of jeans. It's important it has a zip so you can adjust the packing.
Another mob to talk to is Miller Tripods, an Aussie company who seem to focus more on the smaller tape stuff these days. Again, just look on their website.
I should also point out the importance of lens choice. If you go 'wider' it will look smoother and you'll see more around you, but it will also lose some visual impact. Pictures never show the 'real' look and 4x4'ing always looks a lot less hairy than it really is. It's a bit like watching Bathurst, they just don't look that fast but if you are standing trackside they are absolutely hooting! A 'tighter' lens will look more dramatic, but also rougher and you may miss out on some of the action. There's no such thing as a free lunch.
Try and get some variations looking out the side, backwards, at the dash, pedals, gearsticks etc so you can edit the footage on your computer when you get home. Even if it's crap it will give you the 'tools' to cut from shot to shot. This will make it 1000000000000% more watchable and memorable. 30 seconds of one shot is boring enough, an hour is sheer hell. Watch a few good videos you like before you go and note down the camera shots, you'll be surprised how many variations are used.
Hope this helps mate, good luck!
AnswerID: 239690
Follow Up By: KiwiAngler - Sunday, May 13, 2007 at 12:48
V8D
Excellent reply - very informative - thank you. I will start a web search now
I went to the 'Cine Saddle' site and was more than amused about this comment -
" .......snipped......the balls on the bottom of the bag vibrate faster than those on the top"
ahhhh isnt that just so true of many things in life :-) :-)
FollowupID: 500656
Reply By: Member - Tim - Stratford (VIC) - Sunday, May 13, 2007 at 13:28
Kiwi,
I went through the same thing - searching for Sony mounts. We do an annual Boy's Trip with the madatory DVD at the end.
My problem was that I was the only one who took a video camera so filming was limited. I wasn't able to attach it to the vehicle as I wanted to have 'outside' footage as well. I was concerned that by mounting the camera I may miss out on the spontaneous (read Bloopers) footage.
I ended up getting a Helmet Cam off ebay. It is made by Oregon Technologies for those crazy enough to get 'air-time' on their mountain bikes etc.
I've made up a bracket off my dash pod and tested it on lots of High Country tracks and roads. It doesn't move and takes reasonable footage. It is self contained and records directly to an internal SD card so there is no cables etc. I get about 60 minutes with a 2gb card.
I now have the cam corder for the outside footage and the helmet-cam for truck footage. Each day/night just download the files from the SD card to the laptop ready for the next day.
Cost for the Helmet Cam was about $240 - cheaper than the good mounts.
PM me with your email address and I can forward a few photos of the helmet cam and setup.
AnswerID: 239703
Follow Up By: KiwiAngler - Sunday, May 13, 2007 at 13:36
Tim
Unable tp PM you as I am not a member
my e-mail addy is:
kiwiinaussieau@yahoo.com.au
FollowupID: 500671
Follow Up By: Member - Tim - Stratford (VIC) - Sunday, May 13, 2007 at 14:04
Kiwi
email sent.
FollowupID: 500677
Reply By: Big Mike - Sunday, May 13, 2007 at 14:29
Yeah Kiwi, talk to John Toole from Wannago Tag Along Tours, (google them). He has a video mount in his vehicle which is quite nifty.
AnswerID: 239709
Reply By: KiwiAngler - Sunday, May 13, 2007 at 15:34
Thanks to all for your thoughts and suggestions
especially TIM - I have purchased a helmet cam as shown here
E Bay Helmet Cam
AnswerID: 239714
Follow Up By: Big Mike - Sunday, May 13, 2007 at 19:35
Thats pretty groovy Kiwi. I can use one when SWMBO is driving. I wear my crash helmet then and the video evidence might come in handy for the court cases. :)
FollowupID: 500744
Reply By: madcow - Monday, May 14, 2007 at 07:32
Try looking at a Ram mount. www.rammount.com.au and you may be surprised what they have
AnswerID: 239858
Follow Up By: KiwiAngler - Monday, May 14, 2007 at 18:08
Thanks for the suggestion but as I stated in my original thread I have already done that - I am very familiar with the Ram range as I have 2 of their products in my 4xx already.
FollowupID: 500935
Reply By: Member - Sam (NSW) - Monday, May 14, 2007 at 08:19
I purchased the SM4 from www.b-hague.co.uk for the exact same reason (crossing the Simmo) and I could not be happier with the results.
They aren't cheap compared to some of the other options, but having the twin suction mounts gives the added rigidity and I put it through some tough stuff and it didnt' budge.
So if you have the $$$$, i'd recommend something from them. I dealt with them via email and their customer service was also fantastic.
AnswerID: 239867
