Landcruiser Wheels
Submitted: Sunday, May 13, 2007 at 09:26
ThreadID: 45418 Views:2331 Replies:3 FollowUps:2
I have a 2006 Landcruiser GXL TD with 17in alloy wheels. I want a second set of wheels for off-road work.
Will the previous model 16in wheels fit with the 14mm studs that my vehicle has?
If I could find a second hand set of original 17in wheels that would be my preference, but they are just not out there.
Reply By: Stu050 - Sunday, May 13, 2007 at 10:04
Ray,
The 2006 poverty pack still has 16" split rims as standard, so they should fit no worries.
Might pay to borrow one from somewhere, to try it out for brake clearence to be sure, but I think you will find it will bolt straight up no worries.
Rgds
Stu
AnswerID: 239669
Follow Up By: Ray Borrett - Sunday, May 13, 2007 at 13:50
Thanks Stu, I will try to borrow a wheel and try it, just to be sure.
FollowupID: 500674
Reply By: Outnabout David (SA) - Sunday, May 13, 2007 at 11:06
The 16 inch wheels will fit straight on as this vehicle when released came with 16" steels and then the 17" came as a mid model update to help flagging sales.
Just make sure the wheels come from an IFS cruiser though as the rigid axle has different offset.
AnswerID: 239681
Reply By: Ray Borrett - Sunday, May 13, 2007 at 13:52
david
My concern is whether they also changed from 12mm studs to 14mm studs when they went to the 17in wheels. I will try one if I can find one to borrow.
Ray
AnswerID: 239707
Follow Up By: Topend - Sunday, May 13, 2007 at 15:10
I have a 2006 LC100 IFS with the 17" alloys. I purchased a 2nd hand set of IFS 16" steel wheels and fitted them with MT tyres. The stud size is no different to my last 2001 IFS LC100 with 16" rims and I had no problems with fitting the 16" steel rims to my new LC100.
Cheers.
FollowupID: 500688
