4x4 air con!
Submitted: Sunday, May 13, 2007 at 16:16
Graham & Lynne
does anyone know of any toyota 4x4's that ahev air condition in the back for the paassengers because what ever ones i have looked at there is no air con in the back for the back
seat drivers....
cheers for now, Graham
Reply By: Member - Stephen M (VIC) - Sunday, May 13, 2007 at 16:34
the only one i know of is the sahara....
239724
Reply By: Markymark - Sunday, May 13, 2007 at 16:35
If you're looking at Prado's, the Grande model had rear air con. If it's the 100 series, they released limited edition models of their GXL's called 'Kathmandu' that had rear air con, not sure about the Sahara versions.
Mark.
239725
Reply By: Member - Stephen M (NSW) - Sunday, May 13, 2007 at 17:12
Yep we have the vx grande 90 series which has rear air as standard. Regards Steve M
239733
Follow Up By: Graham & Lynne - Sunday, May 13, 2007 at 18:58
is your A/C outlet overhead?I was looking for outlet behind centre console.
from Graham
500730
Follow Up By: Member - Stephen M (NSW) - Monday, May 14, 2007 at 08:57
Hi Graham, no they are overhead which work better as we know cool air drops so if sitting right up the back in the rear seats (little fold up ones) you get plenty of air. I turn the rear air on when I have my dogs in the back so they get some fresh air as the rear windows only pop open a bit. I had rear centre vents in our commodore and find the ones in the prado a lot better for ventilation. Regards Steve M
500873
Reply By: Markymark - Sunday, May 13, 2007 at 19:31
I have the same Prado as Steve and the air con outlets run along the outside roof line.
Mark.
239770
Follow Up By: Graham & Lynne - Sunday, May 13, 2007 at 19:35
Mark
thanks for the reply.I was looking for ideas to retrofit rear A/C outlet to 80 series GXL
500742
Reply By: philldeb - Sunday, May 13, 2007 at 21:08
I have a 79 series no a/c in the back
seat
239797
Reply By: MickWA - Sunday, May 13, 2007 at 21:52
Hi Graham,
My 2004 Patrol STL has rear aircond.
239811
Reply By: Olcoolone (SA) - Monday, May 14, 2007 at 08:00
Hello Graham, what are you trying to do, all the 80 series with rear air have a evaporator plumbed into the front air con. The rear evaporator has its own fan.
If you go that way you will need the 2 pipes that connect the front evaporator to the rear, the 2 "tee" pipes in the engine bay, the rear evaporator assy with coil, fan and solinoid valve and you will have to modify the pipes because the connect into an ice box aswell.
The rest of the system is standard 80 series.
Its no small job to fit rear air con to a 80 series.
Regards Richard
239863
