hp pda and ozexplor
Submitted: Sunday, May 13, 2007 at 17:15
ThreadID: 45432 Views:3671 Replies:8 FollowUps:11
Hi I was wondering if any one can shead some light on a small issue I am having with the exploroz ce softeware on my PDA. For some reason - if i let the pda run flat or do not use it for a couple of days then for some reason the software needs to be reloaded - same applies to my street nav program.
I look for the software in the menue and file explorer but no luck - where does it go ??
All other software remains ie calendar etc
Strange - just a bit frustrating having to reload - not normal perhaps.
hope those in the know can help
Pj
Reply By: lloydb - Sunday, May 13, 2007 at 17:20
If you let the pda run flat the flash memory gets erased.
Load the program onto the storage card if you have one rather than the flash memory.
You will still probably lose the link to it from program files but you should be able to browse to it with the file explorer and run it.
Lloyd B.
AnswerID: 239735
Follow Up By: lloydb - Sunday, May 13, 2007 at 17:59
When I say flash memory I mean the internal memory, not SD of CF memory cards. These types of storage cards should never lose their memory unless you erase them or they are faulty.
FollowupID: 500718
Reply By: Tony Middleditch - Sunday, May 13, 2007 at 17:32
Hi Mark. Have you stored the program on an SD / CF card or is it in the internal memory? I have had issues with loosing the contents of my SD card (maps) but no hassles with loosing the program which is in internal memory. I seem to remember when first getting my HP5550 to not leave the SD card in place when not in use. Thus, I try to remember to take it out once finished with it. So far, I have only had to reload the maps a couple of times. Very frustrating.
Cheers Tony
AnswerID: 239738
Follow Up By: Member - Mark F (NSW) - Sunday, May 13, 2007 at 17:49
Tony
When i synch to the pc the software gets loaded ( i think ) to the internal memory ??? - so that why i find it strange when the battery runs flat - i can not find it - i am about to reload now so i will monitor the location.
thanks
mark
FollowupID: 500715
Reply By: kimprado - Sunday, May 13, 2007 at 17:46
Mark
If you have the new HP iPAQ 6965 you'll need to disable WI-FI, Bluetooth and Tom Tom when not in use. From my experience, if you don't do this, the battery will flat within 24 hours.
I use an SD card for both Tom Tom and Exploroz. When not in use I take it out.
AnswerID: 239741
Follow Up By: Member - Mark F (NSW) - Sunday, May 13, 2007 at 17:52
Ok - looks like i will need another SD card as my street nav ( co pilot ) runs of the current one - thanks for your advice.
mark
FollowupID: 500716
Follow Up By: Blaze - Sunday, May 13, 2007 at 23:07
Ditto to what most have already said. If its stored on the units inbuilt memory it will be gone as soon as the batt runs flat or is removed for any reason
FollowupID: 500826
Follow Up By: The Explorer - Monday, May 14, 2007 at 13:38
By the way ...the software in question is OziExplorer not ExplorOz. Good to promote the website in this fashion though:)
FollowupID: 500909
Follow Up By: Blaze - Monday, May 14, 2007 at 15:42
Good one Greg, Funny how we all missed that, and no sure if this is good or bad, lots of members that have Oziexplorer and also frequent EO call both by the opisite names at times in face to face conversations. LOL
Guess we all speak what we are knowing about.. hehehe
FollowupID: 500918
Follow Up By: The Explorer - Monday, May 14, 2007 at 15:50
Sure gets confusing - Exploroz, DiscoverAus, OziExplorer, The Explorer:)...what next
FollowupID: 500920
Reply By: Lyds- Sunday, May 13, 2007 at 19:38
Mark,
when you say the software needs reloading do you mean everything? like you have to go thru the screen alignment and cut/paste exercise? If so, you just need to keep it charged. or replace your battery.
otherwise, if you have a large sd card say over 2GB, I have heard (no proof) that there have been issues with formatting and lost data.
AnswerID: 239772
Follow Up By: Member - Mark F (NSW) - Sunday, May 13, 2007 at 20:00
Stuart
Its a case of a full reload?? - so I will work through the advice provided so far - its the software - which does not show up - Hmm!!
I am thinking if my pc goes flat - l charge it and the software is always there again - so why does exploroz go "walk about" on me - I will of course check with the guys in WA .
mark
FollowupID: 500754
Reply By: Richard Kovac - Sunday, May 13, 2007 at 23:27
Mark
You need to re charge the PDA a least once a week, if not try iPAQ Backup and back up all programs and data file to you cf or sd cards,
Also set ActiveSync to back up your files and the iPAQ Backup, backup,
This way if the main and backup battery goes flat and you can re-charge them and do a Restore using iPAQ Backup..
Richard
what model HP PDA do you have?
AnswerID: 239839
Reply By: Grizzle - Monday, May 14, 2007 at 12:40
As said here if the PDA goes dead flat all programs are lost. Youe PDA should have an internal backup battery which should allow you to remove your main battery for a while at least. There is a software fix on the HP website. I think the problem is to do with Pocket PC 2003. The 05 version doesn't lose the programs when flat.
AnswerID: 239913
Follow Up By: flappa - Monday, May 14, 2007 at 14:32
My HP6828 has gone flat PLENTY of times (pretty crappy battery life) , and I have never had to reload programs (Running Ozi in memory). Mine uses WM5, maybe thats part of the reason ?
FollowupID: 500913
Follow Up By: lloydb - Tuesday, May 15, 2007 at 18:20
It depends on the pda and on the type of the internal memory.
When you say gone flat do you mean really flat or just flat enough to just shut down?
Lloyd B.
FollowupID: 501144
Reply By: Member - Darren T (VIC) - Wednesday, May 16, 2007 at 18:58
When the battery goes dead flat, all installed programs and applications are lost, it pretty much goes back to factory settings.
Mine used to do this and after getting jack of rebooting everything back onto it I thought there must be an easier way.
I found that if you do a Backup (I think if you go to the "Start menu", then Programs or "Settings" you should find it, I put mine in the start menu for easy access so can`t remember exactly where I found it) of the PDA the next time it goes flat, go to the "IPAQ Backup" application and do a "Restore". It will then restore the PDA back how it was before the battery went flat.
AnswerID: 240373
Follow Up By: Member - Mark F (NSW) - Wednesday, May 16, 2007 at 20:12
Darren
Bingo - thanks to all those with input along the way -
I will give this a go in the coming days and if it does not go my way then the Ipac "gets it" - and i will replace it with a more reliable one
Mark
FollowupID: 501361
Reply By: Member - Drew T (Melbourne) - Sunday, May 20, 2007 at 12:28
i have an ipaq HX4700 & had the same problems .. battery life poor & wiped the applications everytime it went flat. Finally solved it by upgrading the OS from PocketPC 2003 to Windows Mobile 5 (which allows persistent memory). now even when i do a hard reset the applications are not lost (& my battery lasts enormously longer too!)
AnswerID: 241163
