What sort of glue?
Submitted: Monday, May 14, 2007 at 16:35
ThreadID: 45468 Views:2734 Replies:5 FollowUps:4
Hi Guys,
I'm having some trouble with the inner weather strips on my Commdore. The rubber that sits up against the glass has come away from the plastic that holds it onto the door trim. I've tried once before to fix it with Quick Grip. but it didn't work. I need something thats going to be strong enough to hold the pressure of the glass sliding up and down.
Any ideas?
Reply By: Member - Vincent A M (NSW) - Monday, May 14, 2007 at 16:49
The best will be a remma tip top product called SC2000 its a 2 pack you should get 450kgs on the shear for every 25mm x 25mm (its used in the rubber,mineing, tyre & inflatable boat industries)
AnswerID: 239951
Reply By: Steve63 - Monday, May 14, 2007 at 17:00
Is this stuff heat resistant?
Steve
AnswerID: 239952
Reply By: warfer69 - Monday, May 14, 2007 at 19:03
sikaflex products
AnswerID: 239977
Follow Up By: bunny huntin - Monday, May 14, 2007 at 20:46
thanks warfer69, looks good, I'll see if I can get it at the auto shop down here.
FollowupID: 500975
Follow Up By: goingplatinumcomau - Monday, May 14, 2007 at 22:09
Sikaflex 221 <<<<<<<<< is the best bunnings have it
FollowupID: 501004
Reply By: MP - Monday, May 14, 2007 at 20:34
I fixed mine with roof & gutter silicone. Doing the job so far after a couple of years.
Mark
AnswerID: 240009
Follow Up By: bunny huntin - Monday, May 14, 2007 at 20:43
yeah thats what I was thinking of using, but I didn't think it would be strong enough to hold the rubber to the plastic.
FollowupID: 500973
Reply By: goingplatinumcomau - Monday, May 14, 2007 at 22:00
Cyberbond 2007 Instant Adhesive
The best instant glue i have ever seen and bonds any type of Plastic anything Also it cheap 20 G for $12.00.
I brought some from Harvey Hose Supplies at Geebung Brisbane they also have a serious range of Industrial hoses radiator heater ect .
AnswerID: 240041
Follow Up By: goingplatinumcomau - Monday, May 14, 2007 at 23:35
Opps Thats 2077 Cyberbond
FollowupID: 501026
