What type of Jack
Submitted: Monday, May 14, 2007 at 19:58
ThreadID: 45480 Views:1913 Replies:3 FollowUps:0
Planning extended extended trip in 2003 T/D Hilux wih 2" lift what type of jack is suggested as Hilux has no HiLift jacking points, and standard Toyota Hydraulic struggles in the drive-way at home
Reply By: Peter 2 - Monday, May 14, 2007 at 21:15
Get a 4 tonne hydraulic from your local auto parts store, it will lift the Lux easily and also higher.
Don't forget a piece of formply about 300mm square for a jack base.
Remember too that the standard jack will rarely fit under a vehicle with a flat tyre, you need two jacks quite often to lift a vehicle with a flat
AnswerID: 240020
Reply By: Member - Dunworkin (WA) - Monday, May 14, 2007 at 21:25
Hi Rip64, so you are planning an extended trip in '2003', aren't you leaving a bit late!!!!!............. LOL
D
Simba, our much missed baby.
AnswerID: 240026
Reply By: Steve from Top End Explorer Tours - Monday, May 14, 2007 at 21:26
If you have a tow bar and a steel bull bar, you could go to a small engineering place and get them to weld a 75x 50mm box as hi lift jacking points.
I have seen this done many times.
Cheers Steve.
AnswerID: 240027
