Motorola radio
Submitted: Wednesday, May 16, 2007 at 12:19
ThreadID: 45534 Views:3548 Replies:3 FollowUps:9
Hi Guys,
Bought some junk at the local car boot sale. One item I picked up was a hand held radio ($7) thought it was worth a punt as it turned on and sqarked a bit.
Its a Motorola GP328, I have been trying to find out some info on it, It seems there are several variants, VHF and UHF and different numbers of channels.
Has anyone had any experience with these?
How can you tell if its VHF or UHF?
Can you get them set to run on UHF cb frequencies?
If worst comes to the worst its cost me 7 bucks for a mornings entertainment.
Rgds
Ian
Reply By: Shaker - Wednesday, May 16, 2007 at 13:16
This may help ..... http://www.wireless2way.com.au/two-way-comparison.htm#GP3284channel
$875.00 new!
AnswerID: 240315
Follow Up By: Member - Noldi (WA) - Wednesday, May 16, 2007 at 16:04
Wow if I can get it to work sounds like a winner, Unfortunatly I am still not clear
on which one I have and how I would go about getting the frequencies changed
Might have to try motorola themselves
Thanks for your help
FollowupID: 501308
Reply By: Member -Signman - Wednesday, May 16, 2007 at 16:27
Some of the newer Motorola are PC programmed..
You might find a Motorola chat room/ forum that could help point you in the right direction.
However, if it is VHF- there's no way you'll get it on UHF CB band..
AnswerID: 240343
Follow Up By: Member - Noldi (WA) - Wednesday, May 16, 2007 at 16:47
Thanks Signman, I will give it a go and suspect it will actually be bad news . But for the price of a beer....
Rgds
Ian
FollowupID: 501315
Follow Up By: Mike Harding - Wednesday, May 16, 2007 at 16:55
If it's a VHF unit it may be capable of being programmed onto the 2m Amateur Radio band so you could either try to sell it here:
www.vkham.com
or, better still, go for an Amateur Foundation Licence yourself and get to use _proper_ radios :)
www.amateurradio.com.au/foundation/
Mike Harding
FollowupID: 501316
Follow Up By: Member - Noldi (WA) - Wednesday, May 16, 2007 at 17:04
Thanks Mike,
will keep the options in mind, may also see if there is a local Motorola dealer in Perth
Rgds
Ian
FollowupID: 501321
Follow Up By: PandJ - Wednesday, May 16, 2007 at 17:17
Hi All,
To find out the specifications of any transmitter just put the name and model in your search and you will get the answer after you have surfed the info supplied.
The Motorola GP 328 is UHF 450- 527 mhz which can be used on Amateur and cb bands.
FollowupID: 501325
Reply By: Grungle - Wednesday, May 16, 2007 at 17:48
Is it a 4 or 16 channel radio? Also what is the part number on the back sticker (will say something like AZH25SDC9AA2).
If you let me know then I can give your details.
David
AnswerID: 240361
Follow Up By: Member - Noldi (WA) - Thursday, May 17, 2007 at 09:14
Thanks David,
I don't know to be honest, I printed out the specs yesterday and cannot see how to tel the diference.
I will have a look tonight and get the numbers off the back and drop you a follow up post tommorow. Thanks for your help
Rgds
Ian
FollowupID: 501435
Follow Up By: Member - Noldi (WA) - Friday, May 18, 2007 at 08:54
Hi David,
The number is AZH25KDC9AA3 I think its 16 channel, the channel change knob has 16 positions,
Rgds
Ian
FollowupID: 501628
Follow Up By: Grungle - Friday, May 18, 2007 at 18:05
Hi Ian,
The radio is GP328 16Ch 136-174MHz radio. Not really good for much unless you are a keen amateur as Mike above pointed out. Can only be programmed by a PC as well.
Do a Google search (Australian) on the number you gave. It still sells for quite a bit new so secondhand should be worth a couple of hundred $'s.
A lot of the mines up this way use VHF high band but at only 16 channels would not handle even 1 mine.
David
FollowupID: 501731
Follow Up By: Member - Noldi (WA) - Monday, May 21, 2007 at 15:33
Thanks David,
Appreciate the Info, thought I would be lucky, not a problem though. as you say it might be worth a few bob and I'll be able to buy a little hand held.
Rgds
Ian
FollowupID: 502342
