Oh dear - not the rear seal!
Submitted: Thursday, May 17, 2007 at 01:32
Member - Davoe (Nullagine)
noticed a bit of oil coming through from where the gbox mates up to the motor on my 1hz 80 Im assuming its the rear seal. From memory most mechanics seem retisant to fix rear seals. Anyone had this done in
perth with a posative result? I have heard of people getting them fixed and the leaking continuing.
I would assume it isnt a cheap fix especially if the clutch gets done at the same time
Reply By: Member - Peter R (QLD) - Thursday, May 17, 2007 at 07:28
Not in
Perth but at the
Gold Coast.
Cost just under $1000, and was a necessity to get a road worthy certificate, when selling vehicle.
Probably should have gone to Mr Shifty for the road worthy.
Pedro
240482
Follow Up By: DIO - Thursday, May 17, 2007 at 07:47
Would your suggestion 'to see Mr Shifty' imply that some owners and authorised checking centres are actually fabricating the Inspection Certificates to enable vehicles to be re-registered? If so, how can such a thing happen, I thought the Vehicle Inspection process was meant to be beyond reproach - to ensure that only roadworthy and mechanically sound vehicles be allowed to be registered for road use. Do you think the authorites realise that the system may be open to abuse?
501421
Follow Up By: Footloose - Thursday, May 17, 2007 at 08:17
DIO the authorities are only human. There have been several reports in the local press about court cases involving such things. In one such case, hundreds of such certificates were involved.
Same old thing. Give a person the authority, then wave big dollars in his face and the dollars will win every time.
501426
Follow Up By: Gerhardp1 - Thursday, May 17, 2007 at 08:21
DIO, have you ever associated with people in the used car industry?
If not, I don't recommend starting, and if yes, you should realise that there are plenty of dodgy RWCs issued.
You were taking the pi$$ , right ?
501427
Reply By: Member - Fizz (NSW) - Thursday, May 17, 2007 at 08:05
I've just had clutch and rear main seal done on my 96 Troopy.
I had it done by Toyota using genuine parts because they give a 1 year/20000km warranty. They give you a quote beforehand and stick to it. I paid about $1230.
I'm glad I've got the warranty because the clutch isn't as smooth as I was hoping, and they said if it doesn't improve as it "wears in", they will replace it at no cost.
240486
Follow Up By: Gerhardp1 - Thursday, May 17, 2007 at 08:23
Sounds like they weren't surprised that the job is sub-standard.
Perhaps they tried the clutch that came out of someone else's car that was complaining of the same thing, hoping you would put up with it, or hoping it wouldn't show up in your car.
501428
Follow Up By: Member - Jiarna (NT) - Thursday, May 17, 2007 at 21:10
Does that mean they expect you to pay another $1200 or so in a year? I'd not be pleased if a new clutch and seal only lasted a year or 20,000 km!! Warranty is a rip-off.
501559
Follow Up By: Member - Fizz (NSW) - Thursday, May 17, 2007 at 22:05
No, in fairness I think they've done the right thing (I've been a customer on and off for about 20 years and in fact bought my land 25 years ago from the bloke who came for the test drive). I have no reason to suspect skullduggery of any sort.
They say the early problem could be a small oil leak while the new main seal beds in. If that's the case the slight judder should go away as the new seal seals properly. If it doesn't go away they'll pull it down and find why. Surely that's fair enough. As far as warranty is concerned, I'd rather have 20000 warranty than none at all!
501583
Follow Up By: Gerhardp1 - Thursday, May 17, 2007 at 22:41
Hi Fizz, I'm definately guilty of being a sceptic. There are many many posts on the
forum about the absolute reliability of Toyota parts and service - that often being quoted as the reason to buy Toyata over anything else and pay the higher price for lesser specification.
Who better to try and offload a possibly faulty item onto than a long term, loyal customer? If it goes pearshaped, the customer will get re-inforcement that his loyalty is
well placed.
I don't buy the "oil seal bed in" bit - I've replaced many an oil seal and they don't require bedding in. Perhaps they damaged the seal during installation and were always afraid it might cause trouble.
I know that when I was much younger and had no money to do a job properly, I have taken a shortcut and it has backfired - I'm sure I'm not the only one who has had the foreboding of this approach going wrong.
Hopefully they won't have to do it a third time :)
501588
Follow Up By: Member - Fizz (NSW) - Friday, May 18, 2007 at 07:28
Thanks Gerhard.
I understand where you are coming from. I guess one's outlook depends on past experiences. As I said, I have no reason to suspect anything underhand.
As it happens, Toyota at the moment would like to get me back as a regular customer, because although I have been a customer for a long time, I have been anything but a loyal one, due to the higher prices charged by Toyota dealers.
The "bedding in" bit arises from the possibility that the shaft may have a small amount of wear on it from the old seal.
I will let you know how the thing turns out.
501614
Reply By: Willem - Thursday, May 17, 2007 at 08:35
What ever you do Davoe, make sure that a Genuine Toyota Seal is used.
My Nissan box came out 3 times as mechanic insisted on using Repco alternative seals without my knowledge and they don't cut the mustard with the Genuine product
Its going to cost you around $1000 or more. Have a new clutch, thrust and spigot bearings fitted as
240491
Follow Up By: Member - Davoe (Nullagine) - Thursday, May 17, 2007 at 09:12
definitly Willem. My previos camper had a rubuilt TC case which leaked and was fixed with a genuine Tojo Seal.
I figure if the leak proves bad enough (it has only just developed) once the box is out at 230k the clutch will either have been done or could do with it (I have also heard the gen clutch is the way to go). The Price 1200 above sounds reasnable Probably more in
Perth Tho.
With the Aircon also needing attention It looks like money that could have gone to a lift and extractors will be going elsewhere
501434
Reply By: x4by4 - Thursday, May 17, 2007 at 12:17
Just curious, how many Kms on your 80 series?
240517
Follow Up By: Member - Davoe (Nullagine) - Thursday, May 17, 2007 at 15:05
about 230k
501479
Follow Up By: Member - Jiarna (NT) - Thursday, May 17, 2007 at 21:13
Just replaced my rear seal at 391k and it was non-genuine (the one I took out). I put in a genuine one, and replaced the clutch at the same time. All up about $650 but I did the work myself.
501562
Reply By: waite80 - Thursday, May 17, 2007 at 13:00
Hi, just had
mine done after 265000 kms. Was leaking small amount for many months. Done in
Sydney at Traction 4 - said was common in 1HZ and they do them regularly with genuine Toyota parts. Had my clutch done at same time - not that needed it - that adds a bit more to cost. And cost is not cheap. Regards.
240526
Reply By: jeffwa - Thursday, May 17, 2007 at 13:09
Yeah if it's only leaking a small amount it's prob not worth it until the clutch needs doing....
Mines an auto so theres no advantage of getting the clutch done at the same time, but the surf has had a small leak there for a while now. It only leaks while the motor is running (oil pressure is up) and is only a drip here or there. I just keep it clean under there (give it a degrease every 5k when I service it) and it's not a prob. Between oil changes I have yet to notice any visible change in the dip stick reading due to the leak, so until I have funds it'll just have to stay that way.... :-(
I have also found that just adding a little less oil at the service it almost disapears, I guess due to a slight drop in oil pressure. The oil pressure guage still reads the same and I'm only talking about 250ml out of 10L or so.
240528
Follow Up By: Member - Davoe (Nullagine) - Thursday, May 17, 2007 at 15:11
Hmm the pressure things got me thinking. I just grabbed penrite last time and didnt notice till i got
home it was 20-40 rather than 15-40, could just be a co incedence.
Also i had a service malfanction (limit the amount of cans during a service) and lost a bit of oil so it was down a bit on the dipstick but recently added another litre - could be a bit full
501483
Follow Up By: jeffwa - Thursday, May 17, 2007 at 15:21
Yeah I think that's how I did
mine. I overfilled it with 15w-60 instead of the normal 15w-40 penrite. (limit the amount of cans during service) LOL I think the cobination of the thicker oil plus the slight overfill was what did
mine. Now it leaks all the bloody time, but hardly at all if I leave the oil a little lower and keep to the Jack Truck Semi Synthetic 15w 40 penrite. I was also getting a heap of blow by with the 15w60 which has stopped since I changed back...
501485
Reply By: V8Diesel - Thursday, May 17, 2007 at 19:03
Just for safety's sake
check the oil closely to see what it is. Toyota boxes can leak from the gearbox input shaft seal too, especially if your vehicle has ever seen mud or water. Touch and smell should tell you straight away.
Either way the box has to come out. HEAVY.
240595
Follow Up By: Member - Davoe (Nullagine) - Thursday, May 17, 2007 at 20:34
definitly engine oil
501543
