Pop Top Caravans
Submitted: Thursday, May 17, 2007 at 15:49
ThreadID: 45585 Views:14820 Replies:8 FollowUps:4
Hi all,
Just doing some research on pop-top caravans and was after some personal feedback and experiences on this type of caravan. It would be great to get some discussion on the types of mechanisms used to raise and lower the roof such as gas struts, scissors, easy lift bars and any others out there. It would also be good to get some discussion on the advantages and disadvantages of pop-tops and what kind of maintenance issues there may be.
Thanks everyone.
Reply By: nofixedabode - Thursday, May 17, 2007 at 16:13
Im also looking at one of these, from what i have found on this site, and there has been quite a bit the Jaycos are cheaper but less likely to take the knocks. I have a friend with a Cormoral and it has had the suspension lifted. It looks fairly sturdy and capable, certainly a comfortable place to live for a while. Having done the last year of travel around oz without a trailer im going to make the step and just choose my paths a little more carefully..will look forward to comments. I am guessing the standard '80 series will be able to pull it without much fuss, considering im left hand lane all the way around anyways
AnswerID: 240552
Reply By: F4Phantom - Thursday, May 17, 2007 at 17:09
Over the past few months I have been through nearly all the brands to look for the ideal van. I started looking at cloth tops but I have stumbled upon what I think is the best product on the market.
www.innovan.com.au (i think thats right)
it is basicly a small caravan with all the good stuff inside but its got a moveable hard case, its not to heavy but gives what I think is an excellent balance between a full caravan and a small rag top. It uses gas struts to move the main mechanism up and down. It also has lots of storage. I am looking at taking this thing to fraiser. One more point, it can come in a trailer or be mounted onto a ute.
AnswerID: 240568
Follow Up By: Member - John A (SA) - Friday, May 18, 2007 at 14:58
G'day F4Phantom
What an outstanding web-site & a very well thought out piece of equipment.
The apparent spaciousness has to be seen to be believed considering it's a box on the back of a ute.
I never fail to be amazed at the ingenuity of people in coming up with these concepts, let alone putting them into practice.
The manufacturer / designer deserves to do well!
It has some conceptual similarities to the South African trailed camper trailer (Jurgens??) I saw at the caravan & camping show in Adelaide 2 or 3 years ago.
Any idea what the ball-park cost is for either unit with all the bells & whistles?
FollowupID: 501696
Follow Up By: F4Phantom - Friday, May 18, 2007 at 17:28
Yeah I know a little about this thing, I really want one! Basicly the ute version is around 20k and the trailer is around 30k, there is a lot of worthy options tho so you could be looking at more. The thing I like most about it is that its small, light, and full featured but also all hard external case, so no flapping or water or dust. From what they told me its an aussie invention too. I dont know anything about the south african one, have you got a link? Also if you look at comparable units you have the track trailers which are the best you can get, I have looked at those as well but they are not as good as this thing and they cost around 10k more! so this is very well priced, I hope they odnt sell a few and jack the prices up.
FollowupID: 501721
Follow Up By: Member - John A (SA) - Saturday, May 19, 2007 at 15:29
Hi F4Phantom
see post 28090 & 30088 on the Jurgens camper trailer.
A google search will also bring up some other threads.
Only thing I noticed in the video of the crossing of the Simpson Desert, when the tray back unit went over the crest of a dune, the lift-up top bounced up & down.
Seems they also need restraints at the back as well as on the sides which is all that the video shows.
FollowupID: 501902
Reply By: StephenF10 - Thursday, May 17, 2007 at 17:31
Pop-top advantages...
1. Lower height means easier storage and less wind resistance when towed.
2. Big zip-open panels in vinyl sleeve are excellent for ventilation.
Pop-top disadvantages...
1. Some extra steps required when setting-up/packing-up.
2. Not as many, or smaller, eye-level cupboards.
3. Entry door height is usually lower, so care required to avoid banging head.
4. Vinyl sleeve does not provide much insulation in cold weather.
It might seem that the pop-top is outscored, but for me the advantages are more important. There is an urban myth that pop-tops are heavier, but they're not. The vinyl lasts for years and is easily replaced when necessary. My Coromal has spring-loaded scissors and gas struts with simple push-up handles inside and is no problem to operate. Can't comment on other types of roof lifters.
Stephen.
AnswerID: 240575
Follow Up By: Col_and_Jan - Thursday, May 17, 2007 at 18:39
I have had a pop top Viscount since 1986. Its been great, and have no trouble with the vinyl. Did replace the side scissors with gas struts as the springs went soft. Trouble is I chose stronger struts than I needed. Bit of an effort to bring the top down now. Hoping they lose some of their strength with time.
Our carport was only high enough for the pop top. If height is no problem, I would go for the full height van. More cupboard space, and better insulation from the heat and the cold. Steamlined fronts on the full height vans would negate any difference in wind resistance. As well, the side awning setup on the full height van is better than on the pop top IMHO.
And as the Viscount has aged, the top which was relatively level, has dropped in the centre, allowing rain (when it on that odd occasion falls) to sit on top, seeping in if there is any cracks in the sealant - did so last holidays.
So unless there is a good reason to go for the lower height, Id go for the full height van.
Col
FollowupID: 501516
Reply By: Member - Bucky (VIC) - Thursday, May 17, 2007 at 18:15
G-day all !
One of my neighbours had a Prattliner ( spelling ? ), pop top caravan.
Size is reasonable.
Definately not an off roader.
The top was a hard top, that was lifted by hydraulics..( jacking system ) about 20 pumps and it was ready to lock out. The upper skin was slightly wider than the lower, and sealing was a problem till he went right thru it, and replaced all seals with car door type ones, that when the van was popped it was seal on seal, and a neat fit ,,, perfect seal.
Wow it was the best thing I have ever seen.
He modified it to lift quicker by using a bigger pump, and at one stage contempleted an electric type pump, but the mighty $$ stopped that , ( as he has bad arthritis and has very few good days that he can work on it. )
There was a single axle on it initially, and he put a second axle on it and it towed like a dream, from then on.
Recon if ever I had to choose a van then the Prattliner would be high on my list.
They are really practical inside too, and warm.
he tows the van behind a Nissan Terrano 2.7 TD and it does it easy due to the fact that it packs down fairly low.
Hope this helps
Site Link
Cheers All
Bucky
AnswerID: 240583
Reply By: Member - barry F (NSW) - Thursday, May 17, 2007 at 18:25
Hello Damien, My wife & I are fairly new to the caravan way of life. We bought a
second hand 98 Jayco 16 foot pop top two years ago and have managed a few trips in that time, the longest being about 8000 Kms through central western Qld, as well as some of the NT & SA etc.
We are very happy with it, it has gas struts, is easy to pop up & down & cant help but agree with Richard F response in particular in relation to ventilation when you open up the ventilation flaps. Magic!! Yep ,cupboard space a bit limited because of the pop up concept, but for our needs more than adequate.
We decided on Jayco I guess because we did a fair bit of "tyre kicking" before buying & were influenced by their popularity & they were a bit cheaper than some others. Our rationale was that whilst some said Jayco were on the cheap end of the market they cant be all that bad given their dominance on the road.
Mind you, I have to admit that we have looked at some of the current model Jaycos, including the upmarket models, & they leave a bit to be desired in my opinion.
We have'nt had in maintenance issues, had wheel bearings,brakes etc checked out after purchase. We make a point of cleaning top to bottom after a trip & pay particular attention to the vinyl pop top section to prevent mildew.
All the best
AnswerID: 240585
Reply By: Danman - Thursday, May 17, 2007 at 20:44
I spent months looking for the right poptop,a 16footer, but wanted a few changes to the standard fitout. Jayco and others refused and sold only thier type or nothing.
Also wanted a G&S chassis as they appeared the best constructed.
Finished up buying a Coronet from Regency Caravans in Bayswater Vic.
The owner Andrew had all the answers as he also has a caravan repair business and has seen many a flaw in other vans.
He built the van interior that I wanted at no extra cost, fitted second spare tyre had shackles instead of slipper springs and shockers as I will be towing on many a gravel road.
I've had it for 12 months and during that time if I had a queiry or any minor fault he was always willing and abliging to fix it.
It weighs 1200Kg empty and tows well.
It think any bigger van would have to have dual wheels as they appear to travel smoother. I tow my with a Prado Diesel getting around 15lt /100km.
P.S. This is my 11th van and the best
Danman
AnswerID: 240627
Reply By: Keith_A (Qld) - Thursday, May 17, 2007 at 20:55
Hi Damian - we have an offroad Coromal Poptop - (Pioneer Corvair).
Weights in at around 1.8 ton. Single axle, independent suspension.
Roof raises/closes by spring assisted scissors with gas struts. Simple and fool proof. The large ventilation in the roof is rarely a problem in our climate, where heat is more often the issue than cold. Even at Innaminca in mid winter the cold on the vinyl was not noticeable. (If used in the snow fields, perhaps you would consider dropping the roof at night - always an option.)
We have towed it down gorges into Gem fields, into 4wd national parks, across rivers etc. Never even a screw loose.
I have done some minor work strengthening the inside supports under chairs and cupboards, more as precaution as we are off to the Gibb River and Plenty highway in 4 weeks. (Also ran heavier wire to the fridge, again more from abundant caution than need.)
Inside comfort levels are excellent.
(Noticed a similar model in a sales yard last week, with shower and toilet inside.)
Prior to this we had a Coromal magnum (wind-up style) and several years of reasonably serious offroad work convinced us of the build quality.
Our Coromal is not much higher than the Patrol, so if the Patrol can get in the van can. For the places we like to go, a full van was just too high, and fuel economy is gaining more importance as prices increase.
There is a significant difference both in build (chassis/ fittings etc) and price between on and off road models. Take this into account when comparing.
Unlike motor vehicles, Vans often increase in value as demand increases with the retirement of the 'baby boomers'. Second-hand offroad models can be hard to find even now. They can be considered both a lifestyle and an investment.
The standards today are very high for all manufacturers. Enjoy the research....Keith.
AnswerID: 240634
Reply By: ExplorOz Team - Damian - Friday, May 18, 2007 at 10:52
Thanks everyone for your posts. I have read them all and it has helped me a lot.
Much appreciated.
AnswerID: 240726
