improves the alternators charging??
Submitted: Saturday, May 19, 2007 at 01:24
rbt
rather than buy a cheap generator and the jaycar charger, is there a device that improves the alternators charging abilities and maybe provides a line-out to charge a battery-pack while running 350 watt device from a inverter at the same time.
Reply By: Member - Bruce and Anne - Saturday, May 19, 2007 at 05:54
Search in marine electronics there is a device used in stead of the normal regular so the alternator keeps charging at near full voltage until battery is fully charged. Just cannot think what they are called at the moment. We built a manual over ride in one of my yachts, but that is a bit risk in a vehicle thought.
Cheers Bruce.
240930
Reply By: Grungle - Saturday, May 19, 2007 at 07:53
Yes there is a smart 3 stage alternator regulator but whether it has a second line out to charge a battery pack is unknown.
" target="EOF" class="lbg">Site Link
It is from a reputable company (Xantrex) but I have rarely seen them for sale in Australia.
David
240941
Follow Up By: Grungle - Saturday, May 19, 2007 at 07:55
I don't know why exploreoz changes links but it is starting to drive me crazy.
Site Link
501829
Reply By: rbt - Saturday, May 19, 2007 at 09:29
I must be missing something...
so then the standard practice must be to buy the cheap gen & chgr...
is running your engine that much worse from the expense & other stuff from running a generator...
or does 2-3 hours of the he above "fully" charge your batteries better than a 1 hour engine idle
i only have a small 24v fridge that is off at night and a 1 hour per desktop pc
240952
Reply By: Stu050 - Saturday, May 19, 2007 at 12:17
Try this
www.unipower.com.au/prod_up185.asp
240982
Follow Up By: Member - Duncs - Sunday, May 20, 2007 at 09:52
The Unipower gear is good. Had one in my GQ. The biggest problem was that when the alternator died it had to be sent to WA for repair. The postage was a killer.
The Unipoweer in my truck had done heaps of work before it died.
Duncs
502029
Reply By: Robin Miller - Saturday, May 19, 2007 at 14:35
Usual method is to bump output of alternator up a little RBT
Don't know your car.
1/ Many have manual throttle to set revs about 1200
2/ Another way to to provide switchable altternator volts output via series doide in field circuit which leaves idle speed same.
3/ Often series resitor on temp sender - makes ECU keep car revs up thinking engine is cold.
4/ Me - I redesigned my cruise control to provide manual engine speed overide.
Gives me bulk power for running winch or 1500 watt inverter - as only use single
battery here.
5/ Two 15 to 20 minute periods a day is usually a good way to go and this is a very effective method of replacing batts charge and a lot less of a hassle/expense than most gennies.
Robin Miller
241009
Reply By: rbt - Sunday, May 20, 2007 at 00:09
so it will charge while we shower, beaudy everything is fine
i shouldnt put that cheap charger on my batteries cause it will cake them up...
atm i get three days from the fridge turning it off at night and then one day (beer-day) if i do a
water run about 25mins in it .. so that must be ok
i've got a sirius L300 4x4. I realise some of the benefits of keeping the batteries fully charged. I am going to presume an alternator isnt a three-stage charger.
I may now consider a smart charger/battery controller or batt pack (Zantrax) and assuming everything fine, the next step to replace the batts with gels... eventually ill get to a gennie but a quality quiet one..
241114
Follow Up By: rbt - Sunday, May 20, 2007 at 00:42
many ta's for that too...
502007
Follow Up By: Mainey (WA) - Sunday, May 20, 2007 at 16:53
rbt,
What's the 'perceived' benefit of "the next step to replace the batts with gels" ? ? ?
502098
Reply By: rbt - Sunday, May 20, 2007 at 21:02
yes yes, i am examining my reasons...normally i wouldnt spend the money..
they discharge lower... and they are stronger build... significant for me
and that now i realise i have been ruining my wet-cell with a bad chargers, i wouldnt mind getting good batteries and keeping them for thier lifetime to make up for the others ruined...
241258
