Sat Phone adapter & Oversea's use
Submitted: Saturday, May 19, 2007 at 13:31
Mark
Hi, I am buying a Motorola 9505a for a trip to Africa. I have read lots of post on this site regarding use of a normal GSM SIM in the phone with international roaming enabled. Apparently you need to use the full size GSM card in the phone & can buy an adapter convert if you only have the small SIM. A few post mention the adapters were available from Dick Smiths but I could not find any on thier website so it seems they no longer do them, does anyone know an alternative supplier?
Also wondering if anyone has tried the Telstra GSM SIM overseas as all the post on this subject mention use in Oz only.
Mark
Reply By: Smudger - Saturday, May 19, 2007 at 14:10
Drop into your nearest Telstra or Optus phone
shop and ask for a couple of discarded cards from which SIM cards have been removed. We carry a roll of sticky tape in the phone bag to hold the SIM card in place on the large card in our old 9500. Works just fine.
I was under the impression that the later models used the small SIM card?
241004
Follow Up By: Mark - Saturday, May 19, 2007 at 14:17
Thanks for
the tip Smudger, I think i might even have one of the full size cards at work somewhere. I don't have the 9505a as yet but thought I read somewhere that it still took the full size card.
501897
Reply By: Willem - Saturday, May 19, 2007 at 19:00
It will probably be cheaper to use your Satphone as a Satphone while in Africa.
It still costs about $2.50 a minute but with Global Roaming it may cost close to that with a GSM card as you get charged by two carriers. So I found out to my detriment a few years back. Came home after a three week trip to $700 bill.
When in Africa just dial your normal Australia number.....Area Code and then your number. This I discovered by trial and error as Telstra people had no idea what I was talking about and this was in 2005!!!
241048
Reply By: prado4x4 - Monday, May 21, 2007 at 10:50
The motorola 9500 uses the full size sim card, and needs the adapter for your mobile sim card to fit. A 9505 and 9505A take the small sim card straight from your mobile, so you won't need an adapter. (I've got a 9505A myself and use my telstra mobile sim with intl roaming. no adapter needed).
Can't help with experience of use outside Oz though. Only used
mine here.
241374
Follow Up By: tdv - Monday, May 21, 2007 at 14:54
I'm new to this....do you get cheaper calls using a GSM Sim card?
502339
Follow Up By: prado4x4 - Monday, May 21, 2007 at 21:32
Calls are usually more expensive, but you don't have to
sign up on a plan at all. Call rates are international rates, and you pay for incomming as
well as outgoing. On a sat phone plan, you normally only pay for outgoing calls.
If the sat phone is mainly for emergency use (which is what I use it for), and not daily chat-fests, it turns out cheaper. ie: No calls made, no $20, $30 or whatever plan to pay each month.
For regular coms back home, I just send/receive SMS messages via the satphone. Pretty cheap that way, its time talking that tends to cost. Of course if I need it for an emergency, who cares what it costs, I'll gladly pay.
John.
502439
Follow Up By: tdv - Thursday, May 24, 2007 at 12:46
OK I get it now. Thanks. Shame this thread wasn't up 2 weeks ago as I just got a satphone on a plan!!!! Oh
well. I'll know what to do when the plan runs out now.
Tez
503022
Reply By: Stu050 - Monday, May 21, 2007 at 18:37
Why not just get an Iridium pre-paid sim card?
Site Link
241434
Follow Up By: Mark - Tuesday, May 22, 2007 at 08:55
Thanks for the link, I will check out the prices. I did see prepaid cards going on EBAY but they were only valid for one month.
502453
Reply By: Big Woody - Tuesday, May 22, 2007 at 06:15
Hi Mark,
I also have the later model 9505A and it takes the small sim card straight out of my GSM phone with no adaptor required.
I have chosen the no contract road with international roaming on my GSM card. I realise the call costs are higher and I am also charged for incoming calls but I will only really use it in an emergency and 000 calls are free anyway and will even work with no sim cad inserted.
Regards,
Brett
241497
Follow Up By: Mark - Tuesday, May 22, 2007 at 09:03
Thanks for confirming the 9505a takes the smaller SIM. Are you on a plan with Telstra for the GSM SIM?
502455
Follow Up By: Big Woody - Wednesday, May 23, 2007 at 05:37
Hi Mark,
My GSM SIM is not under any contract but I do have it on a $20 plan with Telstra. This seems to work out just about riht with $20 worth of free calls each month. It does not get a lot of use as I use CDMA for work and my wife has the GSM phone for keeping in touch with the kids.
Brett
502709
Follow Up By: Mark - Wednesday, May 23, 2007 at 20:37
Thanks Brett,
I will call Telstra & see what the cheapest plan is. I might take a short term contract with Iridium for the trip though as I believe the Telstra sim will be very expensive when used overseas. TR Telecom
Melbourne had a $30 plan for min 4 months & the call cost were not to bad at $3 a minute with sms under $1. The Telstra GSM sim would be best for when I'm back in Oz as I can also use it in my GSM handset when its not in the Sat phone I guess.
502905
Follow Up By: Big Woody - Thursday, May 24, 2007 at 05:40
Hi Mark,
I recently had a look at the satelite plans onthe telstra website and found the cheapest to be $30/month. From memory the calls on this plan were $1.17 per 30 seconds and about $1 per sms. I think this plan though was if you had purchased the phone through them and included the repayment of the phone itself.
The website indicated that if I already owned the phone I would need to phone them for specifics which I have not done.
If you do make contact with Telstra I would be interested to know what you end up going with and the costs involved.
Regards,
Brett
502978
Follow Up By: Mark - Saturday, May 26, 2007 at 10:57
Thanks again Brett, I understood that the Telstra Sat plans are longer term (12 months min) whereby the TR telecom $30 plan is only 4 months & you can then terminate or put the plan on hold for $15 a month in order to retain the number. I am thinking of doing the 4 month contract for the Africa trip & then switching to the normal Telstra GSM plan when returning to Oz. I can then use the Telstra GSM SIM in my normal GSM phone as
well & just occasionally in the Sat phone when required.
BTW. The Sat phone arrived yesterday & I have just put it on charge so will need to get the SIM to try it out.
Mark
503450
