stoneguard for my camper
Submitted: Saturday, May 19, 2007 at 18:06
Prattie
hey folks first time on thanks for a great venue - I am trying to find some sort of specification for or where I can by a bolt on stoneguard for my camper trailer.I will be protecting the back window but feel the more the better.
Reply By: PeteS - Saturday, May 19, 2007 at 18:30
Hi Prattie
Try looking at post 45578 it may help.
PeteS
241035
Reply By: Sand Man (SA) - Saturday, May 19, 2007 at 18:44
Prattie,
A bolt on stonegard on the camper trailer will mainly provide protection to the front of the camper trailer.
Stones can still bounce off the frame of the guard (even if angled down) and bleep ter the rear window. (This happened to me on the
Birdsville track)
The best way of protecting the rear window is with a cover of some sort over the windows. This can be homemade, out of cardboard or perspex type material, or you can purchase a commercially made one from Obie's Outback
241042
Follow Up By: Prattie - Sunday, May 20, 2007 at 17:27
Hey Sand Man
Thanks for that have got the rear window covered - looking to give a bit of protection to the front of the camper also and if it helps with the window as
well fantastic.
502105
Reply By: Notso - Saturday, May 19, 2007 at 19:06
There is also the problem of spraying rocks onto the paintwork at the rear so a stone deflector on the trailer is really necessary.
I used 20mm Square tube for four poles then strung bungee cord across the top and bottom to which I stitched shade cloth. The whole thing was angled towards the ground. I didn't use anything on the back of the truck but did put larger mud flaps behind all
wheels.
241050
Reply By: Member - Doug T (W.A) - Saturday, May 19, 2007 at 19:46
Bunnings sell sheets of clear perspex of various dimensions , you will find it near the plastic roofing section, once you have it and cut with snips or small hacksaw m drill some small holes in it in each corner for fixing , with a bit foresight you vould add spacers to avoid fouling the wiper if one is present
241062
Reply By: Member - Bucky (VIC) - Sunday, May 20, 2007 at 07:44
Have a look at a Trak Shak camper trailer, they have it all figured.
A sacrificial chadecloth, supported by 2,,, inch x inch box tube.
They point forward at 30 degrees, and are located on either side of the out-side front.
There is heaps of excess cloth, set up to then fold forward and to be " ocky straped " to the blttom of the bumper, thus keeping all stones underneath vehicles.
Cheers Bucky
241127
Reply By: Grungle - Sunday, May 20, 2007 at 09:28
Hi Prattie,
Try the campertrailer site www.campertrailers.org/tech_tips.htm for ideas (half way down the page).
David
241141
Follow Up By: Member - John C (QLD) - Monday, May 21, 2007 at 11:42
Thanks Grungle! That's an absolutely brilliant website for all sorts of ideas.
502323
