84 Pajero 4d55 2.4 turbo diesel
Submitted: Tuesday, May 22, 2007 at 20:10
ThreadID: 45763 Views:5062 Replies:5 FollowUps:3
if anybody has any information on quirks or idiosyncracies of these Pajeros,,along with any tips on services/tuning/add-ons/secrets or what-have-you, anything would be apprieciated, i just acquired one & what i know about them, could fit on the back of a panadol tablet!!!! Cheers All.
Reply By: Willem - Tuesday, May 22, 2007 at 20:28
All Pajeros of that vintage had major problems with 5th gear falling off. In this oldie it may have been repaired already. Used to occur bewteen 80 and 100,000 clicks. They are pretty sluggish trucks but will go forever(apart from the gearbox, that is...lol)
AnswerID: 241685
Follow Up By: mike w (WA) - Tuesday, May 22, 2007 at 20:58
Yep, definetaly issues with the gear box. They use the same parts inside as they do for a sigma.
Im not aware of any rectification, my pajero ended up with the same issue after several months of getting it repaired.
They are also notorious for rusting in the sills around the door and the roof.
Apart from that, bullet proof vehicles, I used to take mine places I wouldnt dream of going today, then again, I was young, dumb, and often full of rum!!
FollowupID: 502622
Reply By: earwig65 - Tuesday, May 22, 2007 at 21:06
Thanks for the quick-fire response, Mike & Willem, very much appreciated, Happy trails to you both.
AnswerID: 241695
Follow Up By: earwig65 - Wednesday, May 23, 2007 at 00:20
Another thing i'd like to know if anyone can offer any clues,,, does this model ('84) share a stud pattern with later model Pajero's or indeed with other make 4x4's such as rodeo/hilux/????
Also like to lay my hands on a workshop manual if anyone has one they'd like to sell
Thanks, Earwig.
FollowupID: 502704
Reply By: Member - Littleborgy (SA) - Wednesday, May 23, 2007 at 00:52
Hi Earwig, i think you'll find that the whell stud patterns will be the same on most 4X4's (as long as its 6 stud), just the offset of the rims will differ... Sorry, i can't help you with the service manual. Hope this helps
Cheers, Brad
AnswerID: 241760
Reply By: ooze - Wednesday, May 23, 2007 at 16:52
Earwig, i aquired one also, picked up a haynes manual from repco, but you can get them anywhere. It's not to bad, a bit vague in spots though. if they exist, and if you can, check out a gregories, maybe they might be better, but i'm not sure.. All the best and have fun. Mines not going yet, turbo's stuffed, but the gearbox has already been fixed! Yee Haa!
AnswerID: 241869
Follow Up By: earwig65 - Wednesday, May 23, 2007 at 16:56
thanx fellas, i dont know the extent yet of its ailments, i havent been able to turn it over yet due to a lack of a battery, plus living in remote NW of WA, repco & coventry stores are few & far between, but we'll get there eh?
FollowupID: 502829
Reply By: DarrynJ - Thursday, May 24, 2007 at 20:01
G'day Earwig, I also a 1986 T/D Superwagon. Never let me down, only hassles were waterpump bearings and alternator bearings. Had to get a mobile mechanic to do the waterpump as I didn't have access to enough gear to fix it at the time as the crankshaft pulley/harmonic balancer has to come off along with the front engine cover to get the waterpump out. Alternator was easy with off the shelf bearings for about $15.00. Had the timing belts changed by a mechanic too as its a big job with 2 belts as the Mitsi diesel has 2 balance shafts. I still have a Haynes manual as there is no Gregories for the diesel Paj. If you ever come to Eastern Victoria you can have it!
Cheers Darryn
AnswerID: 242115
