Brake Pads
Submitted: Wednesday, May 23, 2007 at 09:34
Member - Troll 81 (QLD)
Morning all
What brake pads do you use to stop your truck? I am getting the fluid flushed today and was thinking I might as
well do the pads on the weekend. I think the rotors are still okay…..do you guys think I should get them machined anyway? Or if they look okay just do the pads?
Reply By: Member - Uncle (NSW) - Wednesday, May 23, 2007 at 09:42
Hi Troll, we use Bendix 4wd pads in the Patrol, also used to have them in the Pajero when we owned it too.They have superior resitance to heat when coming down steep hills, especially with the CT on! ( no more brake fade) Very happy with them. As far as machining goes I usually leave that up to the trained eye of our mechanic. Cheers mate unc.
241802
Follow Up By: Member - Troll 81 (QLD) - Wednesday, May 23, 2007 at 09:49
I keep hearing adds for Bendix on the radio but wasn't sure if it was just a add thing or if they are really good. I have heard other people say good things about them as
well
502742
Reply By: Shaker - Wednesday, May 23, 2007 at 09:56
I am also looking at replacing the disc rotors & pads in my vehicle.
A friend had problems with Bendix pads cracking & breaking up in his GU, now I'm not sure what pads to use either.
Maybe as I am going to fit RDA slotted rotors, I may just use their pads.
241805
Follow Up By: Wayne (NSW) - Wednesday, May 23, 2007 at 12:20
Shaker,
I was thinking about slotted rotors.
What put me off the idea was the sand and mud that would get caught in the slot and that would reduce the life of the rotor and pads.
I was going to cross drill and slot the rotors at work but never did.
Wayne
502780
Follow Up By: 120scruiser (NSW) - Wednesday, May 23, 2007 at 18:21
The idea of the slotted and cross drilled rotors are for the release of the gasses that build up between the pad and the rotor. When gas builds up you get noises. This is why most brake pads have a cut down the middle of the material now. Bendix had all their problems when the asbestos was removed from them in 2003.
502860
Reply By: Trevor R (QLD) - Wednesday, May 23, 2007 at 10:06
Troll,
I don't know what pads are best to use, but if you got good K's out of the last lot, stick to what you know.
(pssssss....little secret: front ones in
mine were changed at 210,000km with more Nissan one's but the back are still original at 310,000km)
Cheers, Trevor.
241808
Follow Up By: Member - Troll 81 (QLD) - Wednesday, May 23, 2007 at 10:12
I have no idea what is on there I have never done the brakes since I have had the car....
502749
Follow Up By: Trevor R (QLD) - Wednesday, May 23, 2007 at 10:16
When you remove them I think they are badged or stamped Nissan if original. At 140 or 160 (I think that's what your's has travelled isn't it?) on your speedo I am sure they will be original.
At least get a price from Nissan, you might be surprised.
Regards, Trevor.
502751
Follow Up By: Member - Troll 81 (QLD) - Wednesday, May 23, 2007 at 10:19
I have just over 150 on the clock now but I will remove them on the weekend and have a look.
502753
Follow Up By: Ron George - Wednesday, May 23, 2007 at 13:19
Troll. If you opt not to get your rotors machined & depending on the amount of scoring/wear pattens the pads can take some time to bed in... the results are a reduction in braking efficiency until they do. With machining you illuminate 99.9% of that potential problem. Some high performance pads require rotors to be machined & a special bedding in procedure straight after installation (1/2 a doz or so rapid stops from about 100 KMH) What brand do you choose?????... For my money I`d stick with the OEM ones, as sometimes changing to a different brand can have a detrimental effect on your rotor/pad life... Pad compound to hard/soft/abrasive. If you take the after market option get an assurance from the retailer that the pads are compatible with your rig. Good luck. Cheers Ron.
502792
Reply By: Sea-Dog - Wednesday, May 23, 2007 at 10:40
Bendix 4wd for me also... in the front at least with genuin toyota pads in the rear as I have an 80 series and the rears last forever so I went genuine with them.
I changed my front rotors over but can't remeber the brand I ended up with.. got them from the local Autobarn so I would assume they are not the same as the ones you would pick up from Supercrap!
241811
Reply By: Member - Phil G (SA) - Wednesday, May 23, 2007 at 12:48
I've used the bendix for all our vehicles for the past 20 years and never had a problem - no queal, and they don't chew out the rotors. The Bendix 4wd pads seem to pull up a bit better on the Landcruiser than the factory pads. I never machine discs unless I have a problem.
241833
Reply By: 120scruiser (NSW) - Wednesday, May 23, 2007 at 18:25
As a licenced repairer, we have been using Bendix or OEM pads in 4wd's for about 25 years and now in cars we use Prime and have done for about 4 years. Never a problem.
Always machine rotors as the rotor face wears uneven and when you put a new flat brake pad against it, you will get poor braking and noises. We have been machining all discs for 5 years and the only ones that come back with noises are the ones that aren't machined because the customer has elected not to.
120scruiser
241893
Reply By: Geoff & Jude - Thursday, May 24, 2007 at 19:24
Hi Troll 81, in reference to brake pads that actually work
well, we all use Maxistop pads in the 4wd pad. Also the premiem pad works extremely
well too. They have great heat range both at peak & continuous temperatures. You don't get any fade when towing on down
hill runs. I own a 60 series cruiser & tow a camper trailor as
well as a 20 foot caravan, hope this helps.
Geoff & Jude
242097
Reply By: Truckster (Vic) - Thursday, May 24, 2007 at 23:11
I tried Bendix 4x4 pads in the GQ, they sucked.. Wore out in no time, spongey feel, just yuck.
In the end at recommendation of Bazzle (THE Patrol guru) I went for OEM pads from Nissan, and it was a whole new car! Awesome! Also tried some EBC Greens, but didnt have the car long enough to see wear rate, they stopped ok, but I got used to the OEM pads.. GU will also get them.
242195
