super cheap jacks
Submitted: Wednesday, May 23, 2007 at 12:52
darcla
Hi.
Has anybody out there had any experience with Supercheaps 2,500KG trolley jacks
good or bad ?Currently on special at $ 99. Would appreciate feedback thanks in anticipation.
Cheers Bungarra.
Reply By: Member - Doug T (W.A) - Wednesday, May 23, 2007 at 13:14
Hoo Ho Ho Haaa
have I what ....
well not with a trolly jack personally but seen one being used and it's
wheels bent, My experience was with the small bottle Jacks, I had 2 over 14 months and both failed, and ya know why , Yes everyone here we go again
MADE IN CHINA , mate i tell you now don't waste your money, $99 eh
well triple that and get one that will last MASADA made in Japan
PostID: 39813)
Marquette (formerly Lincoln) used to be the American made field leader but after moving their production to China their quality has changed quite a bit.
The Japanese models imported by Norco and Astro are currently the best values while the Chinese & Taiwanese make some very inexpensive lines, tho, they usually don't hold up
well in professional situations.
241840
Reply By: Member - Doug T (W.A) - Wednesday, May 23, 2007 at 13:19
This too is another great idea
www.hyjacks.com/H21.HTM
These cute little beasts were designed to squeeze into tight spots where no other jacks 'dared to go'... Using a side-to-side pumping motion.
We feature two popular brands. Power Team and Zinko. (All jacks made by Masada in Japan.)
241842
Follow Up By: Member -Signman - Wednesday, May 23, 2007 at 15:27
Now that's clever & lateral thinking. The side to side pumping action. How simple but how effective. How many times have I located a bottle jack into awkward
places, with not enough up & down room to operate easily !!!
502811
Reply By: Member - Max- Wednesday, May 23, 2007 at 14:52
Hi darcla,
i've had the 2500kg floor jack for about 2.5 years now and not a problem, I use it on the patrol with not a problem. The main thing is to use a stand when working on the vechile. Never rely on any jack when under a vechicle.
Max
241850
Follow Up By: Shaker - Wednesday, May 23, 2007 at 16:04
Never rely on any jack when under a vehicle .............
EVER!
502817
Follow Up By: Mike Harding - Wednesday, May 23, 2007 at 17:50
As I observed when I was a
young man of about 22 years: I jacked my Triumph Spitfire up on a scissors jack and was just about to remove the wheel when the jack stripped it's threads and dumped the Spit back on the ground! Prior to that I had, occasionally, gone under the car with just the jack holding it - NEVER done that since.
Mike Harding
502840
Follow Up By: Gerhardp1 - Wednesday, May 23, 2007 at 18:53
I jacked up the front of a Triumph spitfire once and it bent into a banana shape.
Had to stick the jack under the middle to bring it back up again, with 2 people sitting on the ends.
I never, ever travelled in one of those death traps. Thank god they don't make cars like they used to !!
502871
Follow Up By: Shaker - Wednesday, May 23, 2007 at 22:55
The Spitfire had a full rolling chassis.
502957
Follow Up By: Mike Harding - Wednesday, May 23, 2007 at 23:02
Shaker:
I was struggling to remember but I thought it did too!
Mike Harding
502961
Follow Up By: Mike Harding - Wednesday, May 23, 2007 at 23:09
It did.
"Thanks to the separate chassis the Spitfire enjoyed"
www.motorbase.com/vehicle/by-id/388/
502963
Reply By: khavers - Wednesday, May 23, 2007 at 16:10
I have a supercheap trolley jack about 3 yrs old rated about 1500 kilos but wont and never did lift more than 700. I use it for the camper trailer and odd jobs. Also have had a hydraulic jack rated 4t die recently lifting less than a tonne. It has had little use. I wont buy another one. And I certainly wouldn't put my head under a car held up by one (I always use stands) although I bet some people do.
241859
Reply By: samsgoneagain - Wednesday, May 23, 2007 at 16:20
i bought one years ago and the
wheels at the front were too far back. when i jacked the vehicle up the jack started to tilt. i think it was ' lion ' brand
241861
Reply By: Member - Vince B (NSW) - Wednesday, May 23, 2007 at 17:51
HI Darcla.
I purchased a similiar jack. It was ok for 6 months & now is only good for a boat anchor.
Save your money!!!
Vince
241882
Reply By: 120scruiser (NSW) - Wednesday, May 23, 2007 at 18:19
I had three with no troubles a few years back until they were recalled. I took them back and received a full refund.
I then went and bought Liftteck jacks. These are brilliant and not much more expensive. Try Burson Auto Parts as thats where I bought
mine from.
241891
Reply By: Member - Howard (ACT) - Wednesday, May 23, 2007 at 19:28
I have had a superrcheap 2500 kg trolley jack for at least 5 years.
These were actually subject to an ACCC recall.
I did not return
mine for 3 reasons
1) Im a cheap skate and could not source a repalcement jack that lifts the 80 series as
well for anywhere near the money. Handles the weight and achieves the height necessary to get both
wheels on 1 side of the vehicle off the ground .
2) I dont get under vehicles without stands in place so will chance it collapsing. Given that even if it only lifts 2 tonnes that is much more than 1 side
or front or rear of the truck.I have never attempted to lift whole vehicle off the ground at once.
3) jack I have will also just fit under the commodore vx .this allows me to jack it up to work on it as that car is to low to drive up a set of ramps.
In the time I have had the jack, which is used minimum several times a week
with 3 , 4x4's, crapadoor plus kids cars to be worked on,I have had to top up oil once about 12 months ago.
I think it cost $159 .
Howard
241904
Reply By: DIO - Wednesday, May 23, 2007 at 20:01
Mate, surely the value of your vehicle and potentially your life or at least your
well being are worth more than $99.00 - if not - go for it.
241920
Reply By: Member - Sam (NSW) - Wednesday, May 23, 2007 at 20:13
I thought it was only the 1500kg trolley jacks that were subject to the recall and not the 2500 ones. I have one of the $99 2500kg ones and so far its behaving and lifting the heavily modified patrol. I do use stands though. But my jack has been going for a few years now and no probs.
241922
Follow Up By: kcandco - Wednesday, May 23, 2007 at 20:51
Does anyone have further details about the 1500 kilo recall as i think I have one of these. I an a regular visitor to supercheap but have never seen a recall notice.
cheers Kc
502909
Follow Up By: Member - Sam (NSW) - Wednesday, May 23, 2007 at 20:56
Kc
check out " target="EOF" class="lbg">Site Link
502913
Follow Up By: Member - Howard (ACT) - Friday, May 25, 2007 at 20:52
2500kg jack recall was in 2004 2 models affected.
check model on this site
www://recalls.gov.au
Howard
503348
Reply By: ross - Thursday, May 24, 2007 at 00:33
I bought a Kmart 1500 kg trolley jack in the early 80s and used it reguarly and sometimes improperly.
It eventually lost pressure and died slowly. Bought another identical one at a cheaper price 25 years later!! and it is also ok apart from losing one of the split pins.
Chinese jacks are ok for home use and you never get under there without a jackstand.
I did by some wheel ramps once that had a weld fail while we were at lunch.
241971
Reply By: Robnicko - Thursday, May 24, 2007 at 09:01
Darcla,
I have been using one of those for a couple of years now without a problem. The only thing i do not like about them is the sprocket that opens and shuts the fluid valve. It sometimes can not engage properly. Otherwise for home use it's excellent, but always use stands. The jack is only there for getting the car on and off the stands.
Rob
Alot of people refer to it as super#^$% but when you can get the same product for far less from them it makes sense. EG rheem jerry cans (black ones)
241992
