Snorkel & Power
Submitted: Wednesday, May 23, 2007 at 19:00
Wayne-o
Should a
snorkel increase power?
Reply By: Gerhardp1 - Wednesday, May 23, 2007 at 19:07
No.
241901
Follow Up By: The Explorer - Wednesday, May 23, 2007 at 19:38
Agree - in fact
mine slows me down, especially in shallow
water:)
502884
Reply By: Member - Roachie (SA) - Wednesday, May 23, 2007 at 19:14
There is some merit in the belief that on a naturally aspirated diesel, a
snorkel fitted with an "air ram" (as opposed to a Donaldson-type dust pre-filter), could aid in getting a bit of extra air into the donk......but only at speeds over about 80k/h.
In a turbo'd vehicle a
snorkel isn't going to improve power one little bit (IMHO).
241903
Reply By: Member - Stephen M (NSW) - Wednesday, May 23, 2007 at 19:41
Hi Wayne, had
snorkel fitted to old hilux mainly for
water crossings dust etc but was hoping it would improve it a bit in the power department as
well but it did didly squat. I had the exact same power before and after. Didnt seem to go any better and fuel usage didnt change either way. So I would say if putting one on to gain extra grunt you'd be wasting your money. For
water crossings, dusty conditions etc yes. The hilux was shocking for resonating through the
snorkel but common with all the 2.8D some thing to do with the air intake design. Wife hated the noise all the time (mounted her side) even with the metal plate safari included in the kit to shut it up,with out it couldnt hear yourself talk. I'm hoping prado when I get
snorkel fitted will not be intrusive into the cabin. ?? Regards Steve M
241910
Reply By: Topend - Wednesday, May 23, 2007 at 19:45
To put this into perspective, the air pressure around us is 14.7 psi at sea level. Typical turbos boost this to around 6 to 12 psi above this (ie 20.7 to 26.7 psi absolute). This amount of boost is easily noticed by the driver.
The pressure created by ram air at the
snorkel is so small it would be unmeasurable on a boost gauge. For arguements sake lets say the ram air effect at the
snorkel is 0.1 psi (I think it would be far less than this) at 100km/h. I believe there is no noticable improvement.
Something that could make a difference is if the
snorkel draws significantly cooler air up high than what is available in the engine bay (if the vehicle draws it's air from there). Most modern vehicles draw the intake air from the inner guard or from behind the grill.
Topend.
241912
Reply By: Steve from Top End Explorer Tours - Wednesday, May 23, 2007 at 19:51
I recently bought a non turbo 100 series 74000ks, I drove it from
Darwin to
Jabiru 250kms at 140 kph top speed.
When I got home I put a safari
snorkel on with ram then I had to go back to
Darwin and back I sat on 140 kph top speed.
I think that answers your question.
Cheers Steve.
241914
Reply By: Member - Glenn D (NSW) - Wednesday, May 23, 2007 at 22:05
Hows it going Wayne
When I installed
mine I found all my intake air was being sucked through a crusty bit of foam over the inlet in the inner guard , you would think removing this obstruction would have to do somthing .
Glenn
241948
Follow Up By: Wayne-o - Wednesday, May 23, 2007 at 22:50
well that was my train of thought.
thanks glen
ps. nice rig
502952
Reply By: Philip A - Thursday, May 24, 2007 at 09:20
I have tested the effects of a
snorkel by using a Minihelic gauge to measure pressure drop before the filter compared to atmosphere on a 92 Range Rover with 3.9 V8. The
snorkel is a fibreglass custom
snorkel with a ARB? type top scoop pointed forwards.
At 100Kmh , there was a pressure RISE of about 0.5 inches of
water, ie barely measurable.
At full throttle second gear up a
hill there was a pressure drop of about 3 inches of
water. ie very low.
FYI total drop even after the standard paper filter of the Range Rover was 10.5 inches of
water which is very low. So much for after market filters.
Regards Philip A
241996
