Maps for OZICE
Submitted: Thursday, May 24, 2007 at 10:23
selasticman
Hi everyone,
Has anyone downloaded these map files fir use with OZI before?
maps.mynrma.com.au/TouringMaps/Data/
Reply By: traveller2 - Thursday, May 24, 2007 at 10:45
Just looking at them I would say that they wouldn't work with either Ozi or Ozi CE as they are file types that it cannot use. PDF's definately can't be used by Ozi.
242002
Follow Up By: Member - Doug T (W.A) - Thursday, May 24, 2007 at 11:17
By doing a properties on a file they are a .Kap file , got no idea who would be using them,
503008
Reply By: Member - Doug T (W.A) - Thursday, May 24, 2007 at 11:25
I think If they were on my PC i'd not be bothered with it , If you want a good set of Maps then get the Raster set as Advertised here in EO or the Great Deasert Tracks CD set that runs with OziExplorer
Site Link
KAP is installed on the Digital UNIX system with the system commands kcc or kapc . See the KAP for C for Digital UNIX Installation Guide for details.
The directory that contains the executable KAP file must be in your path; or a command such as kapc must be aliased to point to the executable file.
If you are a frequent user of KAP, you may find it convenient to add an alias to your .cshrc files so that a kapc command with preferred switches is available. Contact your system manager for the directory location of the executable KAP file.
242006
Follow Up By: selasticman - Thursday, May 24, 2007 at 11:30
Hi Doug,
I understand, (i think) Thanks Doug
503010
Reply By: festy - Thursday, May 24, 2007 at 12:20
I tried them with Ozi ages ago, you'll need both the .kap and the corrisponding .bsb file to import them into ozi.
They won't work with OziCE in that format though, pretty sure it only recognises .ozf2, .ozfx3 and .ecw maps
242018
