Double posts
Submitted: Thursday, May 24, 2007 at 10:26
ThreadID: 45819 Views:2537 Replies:5 FollowUps:5
Whats with that today, are people having issues posting?
Reply By: Truckster (Vic) - Thursday, May 24, 2007 at 10:27
I answer my own question :)
Microsoft VBScript runtime error '800a000d'
Type mismatch: '[string: ""]'
/Forum/Ask.asp, line 113
AnswerID: 241999
Follow Up By: selasticman - Thursday, May 24, 2007 at 10:33
Ha! I thought it was just me!
FollowupID: 503005
Reply By: GoneTroppo Member (FNQ) - Thursday, May 24, 2007 at 10:43
Database has got morning sickness
AnswerID: 242001
Follow Up By: Gramps (NSW) - Thursday, May 24, 2007 at 18:31
Crikey !!!! Does that mean we'll soon see lots of little databases ????
FollowupID: 503094
Follow Up By: GoneTroppo Member (FNQ) - Thursday, May 24, 2007 at 21:13
Yes Al. And as anyone knows who's had one, they grow and grow and grow up to become big, cumbersome, difficult to manage and just plain hard work.
FollowupID: 503142
Reply By: Member - Troll 81 (QLD) - Thursday, May 24, 2007 at 11:05
Happened to me as well
AnswerID: 242004
Reply By: ExplorOz Team - David - Thursday, May 24, 2007 at 11:34
I have an email of a screenshot and will attend to it shortly. In the mean time if there is a double up please only answer the latest one - ie: the highest ThreadID. I will remove the others.
AnswerID: 242010
Reply By: ExplorOz Team - David - Thursday, May 24, 2007 at 12:20
This bug should now be resolved and I will remove the doubled up posts shortly. I will transfer the items in the wrong posts first.
PS: Timezones will be installed in the Index shortly meaning that the time you see will be YOUR time not system time. It is a new function and may have a few issues when daylight saving starts but one thing at a time.
AnswerID: 242019
Follow Up By: Nick R - Thursday, May 24, 2007 at 18:13
I clicked on a few links such as "about membership" and got what you see below.
I see it is on special at thirty bucks so I will probably join tonight
NickR
Server Error in '/' Application.
Could not load file or assembly 'App_Web_wvmzog5l, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.IO.FileNotFoundException: Could not load file or assembly 'App_Web_wvmzog5l, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Assembly Load Trace: The following information can be helpful to determine why the assembly 'App_Web_wvmzog5l, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' could not be loaded.
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Stack Trace:
[FileNotFoundException: Could not load file or assembly 'App_Web_wvmzog5l, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.]
ASP.TopicSearch.__BuildControlTopicSearch_HT1() +0
System.Web.UI.StaticPartialCachingControl.CreateCachedControl() +15
System.Web.UI.BasePartialCachingControl.InitRecursive(Control namingContainer) +274
System.Web.UI.Control.InitRecursive(Control namingContainer) +198
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +692
Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.42
Carpe Cerevisi
FollowupID: 503088
Follow Up By: ExplorOz Team - David - Thursday, May 24, 2007 at 18:29
NickR,
Would have been a transient error - I was uploading a replacement for the master page that runs the whole site. I was fixing some errors with 800x600 mode. Sorry you got the error it should be solved now.
FollowupID: 503093
