96 pajero gearbox
Submitted: Sunday, May 27, 2007 at 09:51
mickyde66
hi,
Just wondering if anyone can help with info on the gearboxes, I have just purchased a 96 pajero with 200k km's. the gears seem to be stiff mostly 1st & rev seem to be the worst at the moment. thanks mick
Reply By: tryonreef - Sunday, May 27, 2007 at 12:22
Hi Mick try the Pajero club for an awnser,here is the link below.
www.pajeroclub.com.au/home/publicforum/
242677
Follow Up By: mickyde66 - Sunday, May 27, 2007 at 19:15
thanks for your help i will check it out
503732
Reply By: Member - Oldplodder (QLD) - Sunday, May 27, 2007 at 18:43
Using the right oil can make a difference.
Using an industry standard SAE80 oil does make the gearbox stiffer.
Try the
forum as mentioned above.
242726
Follow Up By: mickyde66 - Sunday, May 27, 2007 at 19:16
thanks i will change the oil and see if it makes a difference.
503734
Follow Up By: Member - Oldplodder (QLD) - Sunday, May 27, 2007 at 19:25
No problems.
Not sure which gearbox you have.
So I would check the pajero
forum for the best oil to suit your gearbox.
503738
Follow Up By: Middle Jeff - Sunday, May 27, 2007 at 19:30
Oldplodder is right, castrol make one just for Mitsubishi. It is their normal numbers with the letter "M" at the end, Toyota 80 series use it in there boxes as
well, but with that any K's it could be getting to the time for a rebuild.
Have fun
Craig
503741
Follow Up By: hiab - Sunday, May 27, 2007 at 21:50
dont rebuild just yet, the others are right, if the oil is too thick it will give the symptoms you said, sometimes, engine oil can be used in gearboxes, eg. ford, but check it out. if you box was buggered you would have heard it .
503801
Follow Up By: Member - Oldplodder (QLD) - Monday, May 28, 2007 at 08:35
The old 2.6l 4 cyl engine gearboxes need a 5th gear rebuild every 200 thou K.
The 3.0l V6 had a stronger gearbox.
The 2.8l diesel and 3.5l V6 (same gearbox) is pretty tough, and heavier again than the 3.0l V6.
I have 300 (
well 287 :o)) thou K up now on the 2.8l diesel and no problems, and it does a bit of surburban driving up and down through the gears. 5th gear is just starting to make some noise.
Been a while since I changed the oil in the gearbox (usually do it every 50 to 80 thou), and use a semi synthetic 70 grade oil. I try and stick close to what Mitsubishi recommend, as Jeff said.
Did go too light at one change too, after some oil that just didn't work because it was too heavy. Had to change it again.
503859
