LED replacement globes...
Submitted: Tuesday, May 29, 2007 at 14:46
ThreadID: 46030 Views:4357 Replies:5 FollowUps:18
At the last meeting of the ex ASIO & serving officer's caravanning club I was asked if I could form a committee of inquiry into LED vehicle globes.
"I wish to announce the completion of this task and wish to advise that it is the findings of both the committee and my learned colleagues that these are a waste of money with the possible exception of the "white" LED globes when used in the reversing lights of a motor vehicle.
The findings are as follows:
1) the standard 21 watt incandecesent globes put out approximately 3 times more light measured in lumens (as my meter is an antique one);
2) the angle of "viewability" is much reduced on the LED globes as the beam is directional and unlike the incandecenent globes can only be seen from within very narrow fields of view. This in effect means that traffic indicators, stop & tail lights can only effectively be seen from the rear of the vehicle and therefore these globes do not confirm to ADR's. As you are no doubt aware certain vehicle manufacturers continue the rear lights slightly to the side of the vehicle to enable the drivers intentions to be made clear to motorists travelling or observing from an adjacent lane.;
3) the "white" reversing lights however are an exception to the forgoing. While useless as front Parking lamps as specified in 2 above they do project a clear bluish white beam of a spotlight pattern to the rear of the vehicle and unlike the incandescent globes that provide more of a flood like effect in this application are perhaps worth considering. In the case of the trial vehicle they provided excellent illumination for the rear view camera at night.
4) the fact that the LED globes will be of far greater longevity than the incandescent globes was taken into consideration however the fact that the light produced by these globes is a) far less & b) presented in a direct beam rather than diffused would indicate that they may not actually be seen by other motorists thus negating any advantage gained by longevity.
Many thanks for referring this task to me, my bill follows under separate cover."
Any further comments, I guess this has been covered before.....
if not perhaps Gramps can take us out with a rousing chorus...
Theres a track winding back to an old bean on his back laying behind a maroon jackeroo.....
Reply By: Robin Miller - Tuesday, May 29, 2007 at 15:08
Hi Mr Fawlty
Any through report would have references to the specific products tested.
The above data may be correct if referring to a buget replacement from jaycar etc, however Leds have the capacity to significantly outperform bulbs and can be supplied with more actual light output per watt than bulbs , and are readily manufactured with 120 degree viewing angles.
All you need to do is get a OEM replacement from a car that uses them.
P.S. For the report , worth adding in that LEDs turn on brake lights faster and this is equivalent to approx 1 meter shorter stopping distance at 60kmh.
I.E. If you get run up the rear the nose of the offending car will stop in rear passenger seat , not in drivers seat.
Robin Miller
AnswerID: 243197
Follow Up By: Mr Fawlty - Tuesday, May 29, 2007 at 15:21
Yes you are correct, I was asked to check the "elcheapo" replacements from Smiths Dick.... Viewing angle was about 90 degos but the whits was about 30...
I had not tested the visual innertia aspect of this either, Why the hell did these people not get you to do the tests?
Stuff this, 63 mins of dedicated research thrown out the window because I was not through enough and had no vested interest....
FollowupID: 504159
Follow Up By: Robin Miller - Tuesday, May 29, 2007 at 15:27
Absolutely MR Fawlty
Imagine how much more sincere and dedicated you could have been , if you got 10% of any extra D Smith sales - works for some !
Robin Miller
FollowupID: 504161
Follow Up By: Mr Fawlty - Tuesday, May 29, 2007 at 17:25
Robin, Basil please...
There is no way I would compromise my findings by admitting to reciept of any 'considerations' to bias the out come of this report....
FollowupID: 504178
Follow Up By: Mr Fawlty - Tuesday, May 29, 2007 at 17:34
Run up the rear!!!!!!..... well I wil repeat this even though it's not friday but I think I told you all about the horrendous acident that occured endagering lives outside the Woden hospital in Feb this year. A female motorist rammed the back of the jack and smashed the front of her upmarket Mazda on the towball. 2 cars behind was a policeman and female aide de camp. He got out of his car at the same time as I and we both met at the drivers window of the offenders vehicle, this stupid bimbo is on the phone, we assumed seeking help but no she was making a sale, totally ignored me and the cop.... anyway to cut a long story short she was charged with all the usuall offences but the Male cop said to me not quite soto voce ' women!, thank god they have bleep s, some of them would be useless without them'
I'm sure that does not apply to most women, just the female ones....Ok I'm off to hide from the fusilade from all the femmes d' moteur I've offended...
FollowupID: 504182
Follow Up By: Robin Miller - Tuesday, May 29, 2007 at 17:44
I wouldn't dare post a followup to that followup
Robin Miller
FollowupID: 504185
Follow Up By: Skippy In The GU - Tuesday, May 29, 2007 at 18:12
Yes you can Robin, use Binary or Cipher code :-) :-)
FollowupID: 504199
Follow Up By: Member - Au-2 - Tuesday, May 29, 2007 at 20:17
BASIL....BASIL.....(in strident plummy voice) what are you on about? Don't you know that there are some very femme males (girly men) around here these days? Do you include those in your diatribe too? Really. . . .
Sybil a.k.a. OzeSheila.
FollowupID: 504237
Follow Up By: Mr Fawlty - Tuesday, May 29, 2007 at 20:36
Ah girly men... You mean most males with prostate problems that have to wear, well you know what to stop them getting nick names like "yellow stain"?
Good onya ozeshiela....( in a soto voce expression of exasperation)
FollowupID: 504244
Follow Up By: Member - Au-2 - Tuesday, May 29, 2007 at 21:06
I'm sure I don't know Basil. That's what that big 'Terminator' fellow calls males who aren't testosterone riddled condoms full of walnuts, like himself.
FollowupID: 504258
Reply By: Kev M (NSW) - Tuesday, May 29, 2007 at 15:30
The chorus did it for me,
As for the report well that another issue. LOL
Kev
Russell Coight:
AnswerID: 243203
Reply By: Max - Sydney - Tuesday, May 29, 2007 at 16:32
Mr Fawlty
Is this the real report that the Minister has changed to suit his greater knowledge (sorry, I mean been subject to rigorous scrutiny & review), or is it the report by the operative who was foolish enough to use facts?
Could be very different! he-he-he-he
Max
AnswerID: 243221
Follow Up By: Mr Fawlty - Tuesday, May 29, 2007 at 17:21
Well actually this report could be attributed to "sources close to the supplier" but I always stoop to using the facts, unless of course the facts don't support my view in which case I generate my own statistics to support my own view. I do have some credibility though, I always check with my wife before making promises that may or may not make me look like a fool....
And for the interest of the person suggesting that I may have benifitted in some way from the purchase of these globes for testing rest assured that I have returned them for a full refund as they do not meet the requirements of the ADR's, the look on the face of the PFT at said retail outlook was priceless when I told him to stick his globes in his socket and try them...
FollowupID: 504175
Follow Up By: Stu050 - Tuesday, May 29, 2007 at 21:01
Or , has this report been "seasonally adjusted" (because we don't like the actual figures) to take into account daylight saving (if applictable) the phase of the moon, cloudy or overcast, summer or winter (this can produce a significant variation due to the difference in daylight hours) nominated voltage over actual voltage, divided by the square root of the date last Tuesday?
FollowupID: 504256
Reply By: Sand Man (SA) - Tuesday, May 29, 2007 at 18:49
Basil,
How about forming another committee to investigate and report to ExplorOz members, the advantages (and disadvantages if any) of sealed LED stop/tail/indicator lights. The whole light, not just the globes.
I suspect you make come back with a completely different report.
I replaced the rear lights on the Camper with LED lamps and couldn't be happier.
The old incandescent lamps had a tendency to become intermittent with poor connection between the globe base and the contact point. After buggering about with them over a period of time, a chance advertisement I saw from Autopro for these "you beaut" brake/tail/indicator lamps at $49 each had me wipping down to the local store for a closer look. Very good indeed.
Because they are sealed they even work under water.
I have since done the same with the Trailer and contemplating a similar solution for the folding boat trailer when these lights become salt water affected.
Bill
AnswerID: 243277
Follow Up By: Doggy Tease - Tuesday, May 29, 2007 at 19:42
Gday Mr Sandman and Basil.
This is indeed an interesting question, and one that may in fact perplex the more learned amongst us when it comes to these matters, however with the use of a few simple words i am sure that i can enlighten one and all as to the benifits and detractions of utilising the L.E.D. Combo lamps that are being refered to.
They work bloody brilliantly,,,,,,,,,,,,,,,when you are directly behind a vehicle with these lights fitted you know they have hit the brakes et al.
BUT,,,,,,,,as has allready been pointed out,,,,they have a limited side view (not sure of angle tho)
At night however, they really come into their own. The brightness of these lights is excellent to say the least, casting a very good glow over a large area, with the added benifit being that they can be seen from a very long way away.
Just make sure that they are well secured to the vehicle,,,,and make sure your wiring and connections are even better, then they will last a lifetime.....or untill you reverse into something.
meow.
rick.
FollowupID: 504227
Follow Up By: Mr Fawlty - Tuesday, May 29, 2007 at 20:31
"or until you reverse into something" Hmmmmmmmmmmmmm thats why I have a candid camera mounted on the rear of both Jack & Gin Palace, so that if I'm going to reverse into something I can see what I'm reversing into....
Yes the purpose made LED lamps are a different matter, to look for some good buys simply search for "LED trailer" in EBay. Note though that few actually do carry an ADR compliance and I would suspect that for the pedants that inhabit the world of 4x4 and camping they would insist that their tails were covered by lights that complied with the ADR's. Noteworthy here are trailer lights that are of the "festoon" type, they still fit them to new trailers, vans etc but they are not legal, but who gives a choc dipped quokka?
I also noted some LED globes for sale that were inverted pineapple shape to allow the light to shine sideways so those may be a better choice in a conventional situation....
When the lenses on the Gin Palace fade I will replace the existing setup with ADR approved LED units.
I have seen some on some vans and campers and they do work superbly, Im not knocking the product, I'm just doing what I was asked and I can only work within my brief.
Now if someone wants a report on reversing cameras and LCD monitors - elcheapo versus expensive I can handle that with great authority and passion.... but you would have to ask nicely.
FollowupID: 504243
Follow Up By: Muzzgit [WA] - Wednesday, May 30, 2007 at 00:10
Indeed Mr Tease! After having endless trouble with the rear lights on EVERY JAYCO I'VE OWNED (thats a sum total of three).....I've been thinking about putting those sealed LED thingo's on the back of our NEWLY AQUIRED SECOND HAND JAYCO DOVE!!!!!!! hahahaha
No longer can you threaten me with..... "I'll ring Jaqcui and tell her she should have bought the dove" LOL
How's the 4.2 going?
Do you miss the 3.0?
FollowupID: 504324
Reply By: Member - 'Lucy' - Tuesday, May 29, 2007 at 20:30
OK! I'll be the dufus and ask the question.
Where do I get me some of these extraordinary ASIO Caravaning LED thingy's.
Could you please direct me to the ASIO Caravaning shop closest to me. (I'm in Melbourne and never heard of these suckers)
AnswerID: 243315
Follow Up By: Mr Fawlty - Tuesday, May 29, 2007 at 20:42
Hell your not Lucy Blake are you???
The ASIO shop in Melbourne is in a secret location known only to serving TSGA's...(top secret govt Agents) as I'm a retrenched spook that information is not at my disposal..... David Hicks may know where they are...
FollowupID: 504248
Follow Up By: Member - 'Lucy' - Tuesday, May 29, 2007 at 22:20
Nup! from another branch of the family actually.
Full name Lucy Yota (nee Philby).
FollowupID: 504297
Follow Up By: Member - Fizz (NSW) - Tuesday, May 29, 2007 at 23:50
Try this guy - in Qld:
www.ledshoponline.com
(I'm nothing to do with him - just a happy customer!)
FollowupID: 504322
Follow Up By: Mr Fawlty - Wednesday, May 30, 2007 at 08:42
So Lucy Philby..... Hmmm I spose your not going to admit that your grandfather was Kim Philby.... the site is seething with retrenched spooks LOL
FollowupID: 504350
