LR Discovery oil leak.....ho hum
Submitted: Tuesday, May 29, 2007 at 22:33
ThreadID: 46055 Views:2976 Replies:9 FollowUps:9
Forumites,
I've moved on now and purchased a 98 LR Discovery 2.5 TD, whilst many of you aspire to owning such a prestigious vehicle I'm one of the lucky ones.....
In the next breath I have an ever so slight oil leak between the transfer case and the gearbox, can I remove the transfer case from the gearbox in situ, fix the oil leak and go on my merry way, rather than remove the entire gearbox? If so how hard is it, could I have replies from people with experience of this rather than the next door neighbours best friends uncle if you know what I mean.
Just a a bit of good thing to report I purchased this vehicle from Adelaide via the internet, made a bit of a holiday out of the trip back to Perth. Couldn't of wished to have dealt with a better person. The vehicle was as described and a month later I believe I got a good deal, great vehicle. Plus I scored a couple of points with my wife combining a bit of a trip with the purchase.
To cap this off I sold my Range Rover to a guy in Victoria via the internet again a perfect transaction, this time the vehicle went over East via the train, didn't cost as much as I thought it would of done.
Keep the shiny side up
Reply By: disco driver - Wednesday, May 30, 2007 at 00:31
Hi Martyn,
Haven't done that job on a Discovery.
If yours is a '98 it is the TDi 300, a 4 cyl diesel turbo.
I have a '99 Disco TD5 auto, great vehicle on and off road in standard form.
If you need to find someone who knows Landrovers, I can recommend Kevin Falconbridge at Jordan Rover Tech in John St, Bentley. Not the cheapest in town but certainly one of the best for servicing and parts. Rover dealers tend to be a bit too dear IMHO.
Good to find another Disco owner here among the Toysan brigade.
Disco
AnswerID: 243399
Follow Up By: Martyn (WA) - Wednesday, May 30, 2007 at 00:38
Disco,
Thanks for that I was going to give Kevin a call tomorrow I just wondered if anyone on the forum had any experience this evening. You're right Kevin's good value, I talk to him on quite a regular basis.
FollowupID: 504326
Follow Up By: disco driver - Wednesday, May 30, 2007 at 01:15
Hi again Martyn,
On a wild offchance, did you happen to know a couple of guys named Hooper and Fuller who grew up in Como WA back in the late 50's?
If not, don't worry, but if you did,I know you too.
Disco
FollowupID: 504330
Reply By: Pavo - Wednesday, May 30, 2007 at 07:54
Post this question on Australian Land Rover Owners.
www.aulro.com
Lot of guys who know Land Rovers inside out and very helpful.
Pete
AnswerID: 243417
Reply By: Willem - Wednesday, May 30, 2007 at 09:09
Hello Martyn
Back to the future....LOL
My experience with Landrover products has been that ALL of them leak oil somewhere. It has to do with the quality of their gaskets and seals which are not compatible with the harsh climate of the Antipodes.
Just keep on topping up or maybe put a gasket sealer additive in the box.
AnswerID: 243430
Follow Up By: Martyn (WA) - Wednesday, May 30, 2007 at 17:51
Hi Willem,
Yea still in the background reading away contribute every now and again depends if we move off tyres and suspension. Great site still, good to see some of the hardy annuals are still plugging away.
FollowupID: 504464
Reply By: GoneTroppo Member (FNQ) - Wednesday, May 30, 2007 at 09:29
Speaking as a ling time LR owner I can say this.
They're supposed to leak, how else can you tell if it's got oil in it.
It's when it stops leaking that you worry.
I know that's an oldie but I couldn't resist :-))))))
Enjoy, sounds like you got a good deal on a good car.
AnswerID: 243433
Follow Up By: Truckster (Vic) - Wednesday, May 30, 2007 at 10:05
That is correct, and also 8-10 LR's ever made are still on the road.. the other 2 made it home.
FollowupID: 504370
Follow Up By: Rosco - Qld - Wednesday, May 30, 2007 at 13:17
Nah mate
They don't leak .. they just mark their territory
FollowupID: 504411
Reply By: John Davies - Wednesday, May 30, 2007 at 10:04
It is possible to separate the transfer case leaving the gearbox insitu.
Re-installation is the hard bit as the seals are likely to get damaged whilst man handling it back into position.
John D
AnswerID: 243435
Follow Up By: Martyn (WA) - Wednesday, May 30, 2007 at 14:37
Thanks John
FollowupID: 504432
Reply By: Baldrick - Wednesday, May 30, 2007 at 15:54
If it's ever so slight why bother? From previous experience sometimes when you try to fix a slight leak you end up creating a bigger one!
It's actually a very clever built in system that ensures the oil is regularly changed.
As said above, if it stops leaking start worrying!
AnswerID: 243504
Follow Up By: Martyn (WA) - Wednesday, May 30, 2007 at 17:49
Baldrick,
I understand what you mean and yes when it stops leaking start worrying, yes fine but I'll put money it will stiop leaking when i don't have access to any oil, usually the case.
I suppose I'm a bit anal when it comes to my vehicle I like it to be just right, no doubt I'll get comments now about what I drive..................
FollowupID: 504462
Reply By: nowimnumberone - Wednesday, May 30, 2007 at 19:59
we did one at work a few weeks ago(well the other bloke did)
seemed like an easy job but theres a shaft or something in there that might need treplaced at the same time seals cheap but shaft is dear ill find out more for you tommorow
AnswerID: 243574
Follow Up By: Martyn (WA) - Wednesday, May 30, 2007 at 22:53
nowimnumberone,
That would be great thanks, leave a member mesage if you don't want to post, if you are a member that is..........
FollowupID: 504538
Reply By: Member - Mark E (VIC) - Friday, Jun 01, 2007 at 14:46
It's not a leak, just an AUARPS (Automatic Underbody Anti Rust Protection System)...!??!??!?!??
8-)
Mark
AnswerID: 243977
Reply By: nowimnumberone - Friday, Jun 01, 2007 at 21:13
geez it was hard finding this post again lol
spoke to the guy at work about the shaft thing i was talking about the other day.
once the transfer case is out theres a shaft that slides into the gearbox through a seal(the one leaking)make sure the shaft isnt worn on the shaft it sits over(you will undersatand once its out)he also said to check one of the gears that are low range on there shaft for play(the gear goes over a shaft than wears out)grab the gear and make sure thetres no play
pretty easy job if every thing else is ok
AnswerID: 244077
Follow Up By: Martyn (WA) - Saturday, Jun 02, 2007 at 12:29
nowimnumberone,
Thanks for taking the time out to get this information to me it's appreciated. I feel happy enough now to have a go. The gears you are talking about shouldn't be worn the gearbox has recently had a major overhaul, so I suspect the person doing the job damaged the seal you talk about before I bought the vehicle. I'll just have to be more careful.
FollowupID: 505118
