Larger Mudflaps for LC100
Submitted: Thursday, May 31, 2007 at 12:03
ThreadID: 46107 Views:3054 Replies:7 FollowUps:5
I'm looking to put some larger mudflaps on the front on the cruisers ... not the bigger than ben hur type, but just something that will stop the metal from the front tyres hitting the back with such force.
Any ideas or recommendations?
Andrew.
Reply By: Member - Toytruck (SA) - Thursday, May 31, 2007 at 13:06
Andrew,
been there, done that :-) I would suggest you go to Clark Rubber and buy soem heavy duty rubber and cutout your own. This way if you rip one off or damage one you simply make another. Additionally you can cut tehm out any shape you want.
Toytruck
AnswerID: 243724
Follow Up By: Andrew from Vivid Adventures - Thursday, May 31, 2007 at 13:12
Thanks for the benefit of your experience TT.
I must say I always feel raped when I go to Clark Rubber - I can't believe that the price they charge for material like that reflects fair margins - anyone have any better ideas in SA for places to buy rubber?
Andrew.
FollowupID: 504609
Follow Up By: Member - Phil G (SA) - Thursday, May 31, 2007 at 19:47
Andrew,
I know exactly what you mean. Although I haven't been there for a while, used to use Fitch The Rubber Man, 2 George St Hindmarsh (08) 8346 5193. It was a great shop.
FollowupID: 504704
Follow Up By: Member - Kingsley N (SA) - Thursday, May 31, 2007 at 20:03
Andrew,
There is a good little rubber shop on Anzac Highway near Officeworks at Keswick. I have bought some bits and pieces from him occasionally.
Kingo
FollowupID: 504711
Reply By: Member - MUZBRY (VIC) - Thursday, May 31, 2007 at 13:17
Gday
Don't use insertion rubber as the mud guard will come off when you back over a rock. That stuff is very strong. I suggest that you get some 4.5mm neoprene and sew them to your existing mud flaps with cable ties. Just drill a few holes a fit the ties. When you back over a bundi the new flap comes off , not the original.
AnswerID: 243726
Reply By: Matt(WA) - Thursday, May 31, 2007 at 19:03
Andrew,
Do you know anyone that works in mining or on a process production line? Conveyor rubber is the good gear if you can get it for free. Most of it has a fabric cross ply not ounlike a tyre side wall so its pretty strong gear.
Matt
AnswerID: 243806
Follow Up By: Stu050 - Thursday, May 31, 2007 at 22:32
Some conveyor belting has steel cores through it.
We got some from the Hunter some years ago and it was a real PITA to cut due to the steel cores.
FollowupID: 504756
Reply By: Andrew from Vivid Adventures - Thursday, May 31, 2007 at 19:08
Thanks Matt and MUZBRY - all good input.
The guards on all the cars are already pretty bashed about just in front of the door on both sides - this seems particularly prone on 100 series.
Andrew.
AnswerID: 243807
Reply By: Member - Col G (WA) - Thursday, May 31, 2007 at 19:18
A decent set of steps may be an answer to your problem.
AnswerID: 243812
Follow Up By: Andrew from Vivid Adventures - Thursday, May 31, 2007 at 19:21
well my side-steps have taken a hammering but largely from ramp-over scrapes - I'm happy enought with them, but the issue is not the paintwork which already has a lot of "character" - it's the rear tyres at speed on gravel/metal roads.
Andrew.
FollowupID: 504693
Reply By: Member - Tour Boy- Thursday, May 31, 2007 at 19:55
Andrew,
As Matt said use conveyor belt rubber, about 1/2 inch thick and easy to drill, just cut with a stanley knife. I did my rears to protect the trailer last weeekend.
Tough and look good you can paint them too if you like I did on my 80 series dual cab and the paint was still good 2 years later.
Tour Boy
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 243819
Reply By: Crackles - Friday, Jun 01, 2007 at 11:05
Conveyer belt rubber from a local quarry is normally free if you ask nicely. Cut to what ever shape you want but suggest attaching with large mudflap washers & tieing back to the side step with a short length of chain otherwise they tend to just rip off when you back up in sand or mud.
Cheers Craig...........
AnswerID: 243927
