REDARC SMART START
Submitted: Thursday, May 31, 2007 at 20:13
ThreadID: 46118 Views:8503 Replies:7 FollowUps:20
After peoples experience. Have used Redarc solenoid in my landcruiser for 2 years. Connects 2 wet cell cranking batteries, only run engle 60l off second battery. Over easter the solenoid died, not allowing charge through. Posted it to Redarc who replaced it no worries (Awesome service from an australian company). New one is all good so far. A friend has had one in his patrol and it also did the same. He took it back to the guy who he bought it from and he swapped it. 2 weeks later it also died, took it back and guy is going to swap it for a different sort as he has had a few do the same. Anyway my Question is, Has anyone else had a bad run with these ? Also one for the Electricians. These run hot when the batteries are connected, apparently normal, but in my case the batteries may take quite a few hours to drop to the cutout voltage. Is this damaging the unit? and if so, can you fit something to make it cut out when ignition switched off like the electronic units do? I think they are a great unit, just dont want it to die on me again if i can help prevent it.
Reply By: Wayne-o (Pilbara WA) - Thursday, May 31, 2007 at 20:36
reddog,
mine did the same, but i needed one that day, so just bought a new one.
the first one was 3 yrs old.
new one is sweet.
Wayne-o
AnswerID: 243831
Reply By: Derek from Affordable Batteries & Radiators - Thursday, May 31, 2007 at 20:44
Hi Reddog
Redarc has changed the voltages of their new units to try compensating for the new regulators and computer controlled charging systems of newer cars.
By lowering the kick in and kick out voltages the units will stay engaged for longer than normal.
This lowering keeps the Redarc engaged for many hours if the main battery stays above 12.5 volts and if your batteries are in good condition this will take a long time so the unit is energized the whole time. The solenoids are continuous rated so can stay engaged and will get warm to hot due to the coils inside.
As I have mentioned once before all solenoids have a cycle life and will fail after a while. The Redarc is no different. Early failure is normally due to burnt contacts or overloading. Remember that the solenoid used in the Redarc is a very simple light duty Briggs and Stratton mower type solenoid and not designed for heavy loads. I have repaired many of these buy using the Redarc black box on a marine 100A continuous duty solenoid.
We have started moving away from these solenoid designs as it is old technology and very limited and we are now focusing on multi battery charging using high current Mosfets and a micro processor giving us true isolation of multiple batteries in one circuit. This prevents one battery draining the other when isolators engage and allow each battery to charge at its own ideal current. The new Mosfets are military grade and have no voltage drop and are NOT diodes.
Similar multiple systems include Rotronics, Hellroaring and Blue Sea Systems.
Derek.
AnswerID: 243835
Follow Up By: Thylacine - Friday, Jun 01, 2007 at 02:31
"The new Mosfets are military grade and have no voltage drop"
Derek would you elaborate on this please?
ed
FollowupID: 504780
Follow Up By: Derek from Affordable Batteries & Radiators - Friday, Jun 01, 2007 at 08:51
Hi Thylacine
A Mosfet is a electronic switch also know as a gate. They are widely used in almost all electronic products to switch them on and off. Plasma TV's, Audio equipment, computers, etc. They offer a clean on / off solution to sensitive electronic devices. You may remember older radio's that turned on with a switch and they would crackle and spike. New radio's and tv's fitted with mosfets are switched on without noises, crackles and spikes.
Our Mosfets are large units of the above and are capable of switching very large loads with no burnt contacts, faulty solenoids, moving parts, corrosion or most important voltage drop.
They are new being introduced into winch controllers as they are reliable and waterproof.
www.jeephorizons.com/news/images/06_sema/milemarker_mx9.jpg
The ones used in our BiSolator have been used for DC switching of high current loads on fork lifts, loading platforms, telecommunications and electric vehicles.
Think of a Mosfet as a solid state solenoid. Here is a basic picture of the principal of a Mosfet. Mosfets are quite complex and there are many types.
I hope this explains it a bit for you, I have tried to make it as simple as possible.
Derek.
FollowupID: 504794
Follow Up By: Derek from Affordable Batteries & Radiators - Friday, Jun 01, 2007 at 08:54
I will try another picture of the MOSFET winch.
FollowupID: 504797
Follow Up By: Thylacine - Friday, Jun 01, 2007 at 09:22
Ta Derek, but I'm actually pretty clued-in on semiconductor basics (Control Systems engineer for 20+ yrs).
What I was interested in was the "no voltage drop" statement (and calling them "our mosfets" is a bit cheeky).
Would you mind posting the specs of these mosfets please.
ed
FollowupID: 504803
Follow Up By: Derek from Affordable Batteries & Radiators - Friday, Jun 01, 2007 at 09:37
Hi Ed
I did not realise you already knew what a MOSFET is.
No I will not be posting my specs or internal circuits of our BiSolator as they can easily be copied.
Our test at 13.8 Volts and 20 amp current showed a differing voltage between source and load of 0.016 volts.
Solenoid type Smart Relays show an average of 0.5 v drop.
Derek.
FollowupID: 504808
Follow Up By: Thylacine - Friday, Jun 01, 2007 at 10:13
Mate I didn't ask for a circuit diagram. Just the specs for the mosfet you are using. This is akin to asking Toyota what size/type tyre fits a landcruiser.
It's not as if you designed or made them, and anyone with enough knowledge to understand the specifications would be more than capable of designing their own dual battery system. We are, after all, talking very simple circuitry.
Starting to look like another case of "baffle them with bull bleep ".
Please prove me wrong, as there is far too much of this going on in the 4WD electrics area.
ed
FollowupID: 504818
Follow Up By: Derek from Affordable Batteries & Radiators - Friday, Jun 01, 2007 at 10:22
Hi Ed
I thought that was where you were heading and won't get into this type of thread.
FollowupID: 504821
Follow Up By: Derek from Affordable Batteries & Radiators - Friday, Jun 01, 2007 at 10:34
Hi Ed
Here is the last thread you answered to the same questions you have.
PostID: 41421
Derek.
FollowupID: 504827
Follow Up By: Thylacine - Friday, Jun 01, 2007 at 10:55
I'll tell you what.
You stop making fantastical claims, and I'll stop querying them.
You promote your units specifically stating the benefits of mosfet design, yet refuse to offer the specs on such.
I'm not into arguing for the sake of it, but am sick of salespeople mis-representing their products. This is rife with dual battery controllers, and often coupled with enough technical terms to convince a layman that they're getting advice from someone who knows what they are talking about.
ed
FollowupID: 504836
Follow Up By: Derek from Affordable Batteries & Radiators - Friday, Jun 01, 2007 at 12:36
Hi Ed
I have in your previous thread made you an offer to test a unit free of charge.
"Why not send me your email address and when they arrive you can test one for a few weeks. I plan to have test modules for people to try out and then return if not happy. "
to which you answered.
"Thanks for the offer Derek, but no thanks, for several reasons.
Firstly I can't see the point in a few-week test, or a few-month for that matter.
Secondly, If it has more electronic components than diodes, bush fault-finding becomes difficult. And looking at your pic of the unit it's set in resin so irreparable anyway. I'd have to know it's principle of operation (and be happy with it) before thinking of trusting it.
This is the reason I stick with a simpler system (and drive an old landcruiser) - I can fix most things that break in the bush.
cheers, "
We have done our own extensive tests on the ability of the product to carry the specified loads and compared these to the manufacturers specifications prior to ordering and manufacturing these BiSolators. They perform perfectly and are covered by a full exchange warranty.
We are the Australian Distributor and have stock holdings to service the 4wd and marine market.
2 models are available. 80A Constant with 160A surge and our big unit 150A with 300A surge. These are alternator currents and both units have current limiting protection. The automatic start boost feature is included in both units.
Yes they are set in resin for marine and heavy 4wd applications.
Derek.
FollowupID: 504865
Follow Up By: Derek from Affordable Batteries & Radiators - Friday, Jun 01, 2007 at 13:19
The specifications are on my site if needed.
FollowupID: 504870
Follow Up By: Mike Harding - Friday, Jun 01, 2007 at 14:00
In over 30 years in the electrical/electronics design field I have never, ever
heard a MOSFET or any type of FET called "a gate". The gate is the control terminal of the device.
What range of temperatures were your tests performed over Derek?
You should see what he says you can do to AGM batteries! :) Still waiting for a manufacturers reference on that one btw Derek?
How do these units react in the event of an impulse current above the specifications?
One of the big advantages of relays is that they will accept severe abuse without failing, semiconductors are much less able to do that and MOSFETs, because of their extremely high input impedance are also far more susceptible to noise causing rogue switching.
Thylacine: the best RDS(on) I have seen in recent times is about 10mR typical at 25C, there may be better ones but they would be quite expensive.
Mike Harding
[Who's designed a few things with MOSFETs in them over the years]
FollowupID: 504882
Follow Up By: Derek from Affordable Batteries & Radiators - Friday, Jun 01, 2007 at 15:31
Hello Mike
“In over 30 years in the electrical/electronics design field I have never, ever
heard a MOSFET or any type of FET called "a gate". The gate is the control terminal of the device.”
No, the gate is the gate and the gate has a terminal ! Not everyone is a rocket scientist.
MOSFET
metal-oxide-semiconductor field-effect transistor
The 'metal' in the name is often incorrect as current process technologies usually use polysilicon gates. Some prefer to use "IGFET" when referring to devices with polysilicon gates. When a voltage is applied between the gate and source terminals, the electric field generated penetrates through the oxide and creates a so-called "inversion channel" in the channel underneath. it provides a conduit through which current can pass. Varying the voltage between the gate and body modulates the conductivity of this layer and makes it possible to control the current flow between drain and source.
“What range of temperatures were your tests performed over Derek?”
If you check our specifications the test was done at 20 deg C.
“You should see what he says you can do to AGM batteries! :) Still waiting for a manufacturers reference on that one btw Derek?”
Lifeline batteries are a C4 rating (max charge rate is 25% of capacity) 100 a/h battery = 25 amps max charge rate.
Fullriver batteries are a C5 rating (max charge rate is 20% of capacity) 100 a/h battery = 20 amps max charge rate.
MK Batteries are a C3 rating (max charge rate is 30% of capacity) 100 a/h battery = 30 amps max charge rate.
Here is their company website. www.mkbattery.com/index.php
Here is their AGM technical manual. http://www.mkbattery.com/images/VRLA_TechManual.pdf
Here is their charge guide lines. http://www.mkbattery.com/images/AGMBatteryCharging.pdf
“How do these units react in the event of an impulse current above the specifications?”
They have built in current limiting.
“One of the big advantages of relays is that they will accept severe abuse without failing, semiconductors are much less able to do that and MOSFETs, because of their extremely high input impedance are also far more susceptible to noise causing rogue switching.”
How long have you been retired ?
There is new technology and modern MOSFET’s are stable and used in most high end electronic products.
I thought better of you Mike.
Here is one for you….
Optima AGMs are claimed (Not by me) to fully recharge in 1 hour.
FollowupID: 504907
Follow Up By: Mike Harding - Friday, Jun 01, 2007 at 16:03
In that case it's meaningless. Automotive parts should be qualified, iirc, at -40C and +105C, _especially_ for underbonnet use. The major automotive designers (Bosch etc) don't even accept the manufacturers data they do their own qualification on _every_ _single_ _device_ they use and no devices which have not received their "automotive qualification" are permitted to be used in a product of their worldwide organisation. Last I heard it cost about A$30k to qualify a part at Bosch. Makes for very expensive resistors.
The Fullriver data sheet I gave you a link to specs. 20A (or something, can't remember) as the max initial charge current - are you suggesting it's wrong?
Really. I'm only aware of two ways to measure DC current; shunt voltage and Hall Effect and if you're using a shunt then you'll counteract the advantage of the low RDS(on) of a MOSFET and would cause your product to have significant voltage drop. This is a problem with semiconductors, it's hard to protect them from overloads - they tend to blow up. What are the overcurrent specifications for your product Derek? Is it capable of withstanding a source of 1000A for 50mS at 105C? How about overvoltage? What can it handle there? Mercedes have a spec. requiring modules to withstand 120V for 300mS can you product handle that? Spikes into the hundreds of volts are common - you have a spec for that too, do you?
Still working Derek. In fact you'll find some of my design work in the new Holden VE Commodore.
MOSFETs!!??? New technology!!!??? You make me laugh. I was designing stuff with MOSFETs when you were wondering what the difference between current and voltage was.
Derek, it is clear to me that you are an amateur masquerading as a professional, you are a salesman, not an engineer, and frequently use this forum to push your products. I'll give you a little advice Derek: make damn sure you get both the design (including EMC emissions and susceptibility) and full environmental testing of your product right otherwise you'll have more returns than you can poke a stick at. After military/space and medicine the automotive market is the most demanding environment to design for and babes in the wood who try it often end up bankrupt. Getting a few products to work is gentle environments is a whole different game to getting high volume production to work in the real world.
Derek: there are a few people, nowadays, on this forum who really know what they are talking about when it comes to electronic design: you are not one of them.
Mike Harding
FollowupID: 504916
Follow Up By: Derek from Affordable Batteries & Radiators - Friday, Jun 01, 2007 at 19:05
Dear Mike
The specification sheet is supplied by the manufacturer and 20 deg C is their foot note and seems to be an industry standard including Blue Sea Systems and Cole Hersee. My independent test temperatures are not on the manufacturer’s specification sheet and was done at normal operating temperatures. The units are fitted with heat sinks to keep the temperature low and have no derating from -40 to + 85 deg C.
I did not accept the data at face value and that is why I tested these units for 6 months prior to manufacture.
The Fullriver Data sheet was the DC100-12B and yes initial current was 20A yes. (C5)
Our unit has a 105 deg peak of 600 amps @ 50ms and recommend 2 parallel units to obtain 1000 amps or more if needed. It is unlikely that more then that will be needed on most vehicles with the exception of large diesels and high compression engines. Most vehicles are now fitted with reduction starter motors and cranking amps are with-in specification.
Surges and spikes are controlled by the internal circuit and yes spikes up to 100V are common and easy controlled. I have not seen spike go into hundreds of volts. The microprocessor controls the switch ON rise-time to limit inrush currents during first 2 ms and switch OFF is also controlled.
The units are rated 9 to 30 volts and have full CE approval.
I would be interested in your design work for the VE Commodore.
I know Mosfet’s have been around a long time I used them in the 80’s. They have been improved and are commonly used. I did not try to imply they are a new invention but are not what they used to be or even made the same. Please read what I said again ‘There is new technology and modern MOSFET’s are stable and used in most high end electronic products.’
I won’t comment on your last paragraph but find it insulting. I apologise for assuming you were retired.
Have a good weekend.
Derek.
FollowupID: 504960
Follow Up By: REDDOG - Friday, Jun 01, 2007 at 21:33
Thanks for yor input Derek, much appreciated
FollowupID: 505012
Reply By: Member - Peter R (QLD) - Thursday, May 31, 2007 at 21:21
Redarc have changed the voltage to the Smartstart SB112 .
Read the article on page 4 of Autumn 2007 newsletter
Pedro
AnswerID: 243850
Reply By: Member - Terry G (NSW) - Friday, Jun 01, 2007 at 19:28
Why don't you guys get off Derek's back. You're just trying to big note yourselves at the expense of guy who has helped a lot of people on this forum.
tg
AnswerID: 244028
Follow Up By: Johnny boy - Friday, Jun 01, 2007 at 20:13
Guys that all went over my head but was very entertaining I feel like I just red book from cover to cover ...how about you all just kiss and make up I think you would both get on great as you both have the same interest and seem very passionate about electronics ??? well I'm going to go pour my self a scotch and I hope when I come back you boys have shaken hands and made up ..LOL
Regards J.B.
FollowupID: 504978
Follow Up By: Member - Vince B (NSW) - Friday, Jun 01, 2007 at 20:24
HEAR HEAR!!!!!!!!!!!!!!!!!!!!
FollowupID: 504982
Follow Up By: PeteS - Friday, Jun 01, 2007 at 21:46
Spot on, HEAR, HEAR, HEAR, !!!!!!!!!!!!!!!!!
FollowupID: 505015
Reply By: Member - Leigh (Vic) - Friday, Jun 01, 2007 at 21:02
Seems to be a bit of aggro here so I'll keep it short. I did not like the long duration of the soloenoid being engaged so I put a switch on the earth and turn it off manually when I want. Light in switch go on when solenoid is engaged. Very happy and NO drama whatsoever!! Good luck and cheers
AnswerID: 244070
Follow Up By: REDDOG - Friday, Jun 01, 2007 at 21:32
Thanks Leigh that was what I was after, Im not too technical minded but can usually work things out. I havent had much of a play but I presume you just ran a wire from the black earth wire to your switch then back to earth. Thanks for your help
FollowupID: 505011
Reply By: Mainey (WA) - Friday, Jun 01, 2007 at 23:12
RedDog, your initial post asked for "experience" with Redarc solenoids
a simple enough question I thought at first.... but ???
Your QUESTION is: "Has anyone else had a bad run with these ? "
Yes, I initially used a Redarc solenoid because I was advised & convinced it was as good as anything else on the market, now I know that's technically not correct... mine 'died' shortly after warranty expired, so I replaced it with a Piranha Electronic isolator that was still working faultlessly till I replaced it with a Rotronics Electronic system for a reason not relevant to isolator performance in any way.
"These (Redarc solenoids) run hot when the batteries are connected, apparently normal.... "
Yes, that’s normal, because they are a 'mechanical' piece of ‘metal’ equipment that transfers “electricity” and 'recommended' to be installed with one direction to be 'up' to eliminate transference of undue weight on the spring loaded connecting 'head' when it contacts the mounting surfaces, that’s what causes the 'bang' noise heard when the mechanical solenoid connects / disconnects.
Your statement that it takes "quiet a few hours to drop to the cutout voltage" indicates you are not using a high drain 'appliance' on the dual battery system OR you have a reasonable capacity Aux battery.
The Starter battery and the Auxiliary battery will remain connected till the two batteries, now wired in parallel by the solenoid and are in effect just one big battery, reduce to the cut-off voltage as set in the Redarc solenoid.
When the Start battery is disconnected from the Aux battery by the solenoid it will continue it's chemical reaction to return it back (close to) it's fully charged voltage again and the Aux battery will continue ALONE to run the 'appliance' UNLESS it is terminated by a 'low voltage' cut-out switch in the 'appliance' that should be set at a much higher voltage than most are :-((
Which probably should have separated the 'appliance' from the dual battery system well before the Redarc low voltage disconnect activated anyway.
AnswerID: 244101
Reply By: Trev50 - Sunday, Jun 03, 2007 at 12:49
We installed a Redarc about 3 years ago and it has performed faultlessly. Like you, I also noticed that the relay would often remain energised for a couple of hours after the engine was stopped. I phoned Redarc on (08) 8186 5633 and the very helpful technician told me the relay remained energised until the main battery voltage dropped to the relay cut-off level and this could take a couple of hours if there was little drain on it. I don't worry about it now, but if you want to lower your battery voltage for a couple of seconds to force the relay to de-energise, turn your headlights on, listen for the click of the relay operating, or watch the led indicator go out, then turn your lights off. You don't even have to open the bonnet. The relays do run a bit hot, but that's normal, especially if it's mounted in a hot engine bay.
Trev
AnswerID: 244340
