Site Search
Section Image
Tyres again.
Submitted: Friday, Jun 01, 2007 at 16:15
Trevor R (QLD)
Hi Folks. Yep it's tyre info required again.
I have a caravan running 15 inch rims and for an upcoming trip I am thinking of making the GU's 265x75R16's interchangable with the vans. To do this I would need to make the rotational size of both the 15 and 16 inch tyres the same (or very similar). I understand the 15 inch rim may not fit on the GU because of disc brake clearance, but what I want is to have 2 spare 265x75R16's for the van (which I have in the shed) and buy two 15 inch tyres to suit my existing 15 inch rims already on the van with a rolling diameter of about 804mm (which is 265x75R16 rolling diameter). This way the vans spares can also be the GU's spares without extra expense of changing rims on the van to 16 inch. I do need the new tyres to have a specific load rating of no less than 112 as the van is very heavy on single axle and I have had history with tyres of less load index going POP.
Can anyone see any flaws in my way of thinking and if not is there a website link that someone can give me to look between brands/sizes and load index all in the one site. Most of the sites I have found do not give specific load index of each tyre.
I have worked out a 265x80R15 and a 32x11.5R15 will have similar rolling diameter to my Gu's 16 inch so working out the prospective sizes is not an issue.
Thanks to anyone who can help.
Trevor.
Welford NP local
Click Image to Enlarge
Thats...... KING Cane Toad to you!!!
Advertisement
ThreadID: 46147 Replies: 4
Views: 493 FollowUps: 4
AnswerID: 243997   Submitted: Friday, Jun 01, 2007 at 16:31
Steve from Top End Explorer Tours replied:
There is only one correct way to do this, get 16' rims and put the same tyres on.
If you try your way you are only looking for trouble IMOA.
Cheers Steve.
Top End Explorer ToursTop End Explorer Tours
Member: Lapsed Membership
Reply 1 of 4
AnswerID: 244003   Submitted: Friday, Jun 01, 2007 at 17:30
Member - Roachie (SA) replied:
Don't know the exact answer to your question Trevor, but from what I have gleaned from being a member of the Patrol4x4 forum, you CAN fit 15" wheels onto a GU without any issues, except that if you put them on the front, they may foul the steering linkages. I haven't tried it in any form as I don't own any 15" wheels.
If you have the 15" wheels there already, you want to just check for yourself. At a pinch, you may be able to get 15" wheels onto (at least) the rear end of your GU without any dramas.
There's only one thing more painful than learning from experience and that is NOT learning from experience!
Reply 2 of 4
FollowupID: 504950   Submitted: Friday, Jun 01, 2007 at 18:27
Trevor R (QLD) posted:
You are correct Roachie. The 15 inch should fit (and have on other GU's I have seen) but I thought I would cover my bases and stop someone telling me they won't fit LOL!!
The crux of my Question is about the website to compare all brands with sizes and load ratings. I have enough info to work out what I need but not one website to tell me what is available in each brand of tyre.
It seems possible that my wife and son may join me down at Warraweena, if so I will be pulling the van down and I want tyres from the car to interchange with the van as spares.
Thanks for the input.
Regards, Trevor.
Welford NP local
FollowUp 1 of 2
FollowupID: 505048   Submitted: Friday, Jun 01, 2007 at 23:44
Blaze posted:
Hi Roachie,
I believe it also depends on the offset of the rims. I run 15" Sunrasia Rims on my Mitsi and had the offset problem with the first set of rims, I had to use Yota rims.
I would expect the Nissan to be similar, but not sure what rims would clear the linkages.
Loveday 4X4 Adventure Park
Adventure before Dementia
FollowUp 2 of 2
AnswerID: 244026   Submitted: Friday, Jun 01, 2007 at 19:16
Pezza (Bris) replied:
Hi Trev,
Can I see any flaws ? Yep, a big one... that is, you going on a big trip when I can't !!! LOL.
You have to be carefull doing what you want to do as tyres are never the same actual size even though their advertised size is the same.
My 33-12R Buckshots are really only 32", My 35-12R Pro-comps are 35".
The only way to do what you are wanting to do, as I don't know of any websites that you are looking for, is to choose maybe 3 brands of tyres that you would be happy running on the van then going to the tyres place and getting the rolling dia. on those particular tyres and hopefully finding one that's within a couple of mm to your 265's.
Some particular brand websites, ie. Dunlop, Maxxis, Cooper etc, have the rolling dia. of each individual tyre they sell, that may help if you're interested in that brand of tyre, a lot of brands' websites don't have this and you are just gonna have to ring or chat with them I think.
Also, don't take the 804mm for granted if you worked that out mathematically from the advertised size, physically measure them or check Bridgestones website, unless that is of course where you got it from to start with :-))
Pezza
" NO FEAR " means you're not going fast enough!
Reply 3 of 4
FollowupID: 505020   Submitted: Friday, Jun 01, 2007 at 21:58
Thanks Pezza,
I have worked out a few possible tyres to suit but none of them tell me load index. I was hoping to get a few more brand options and get some load index ratings in one foul swoop.
Thanks anyway.
Trevor.
Welford NP local
AnswerID: 244177   Submitted: Saturday, Jun 02, 2007 at 15:38
Mark & Jo, S/side, Bris replied:
Gee that's nice to see both you Trev and Perry in one thread..Been a while since I can think of the last one!!!
Jo
Reply 4 of 4
FollowupID: 505171   Submitted: Saturday, Jun 02, 2007 at 17:28
Thanks Jo, it has been a while. Hope you are all well over there.
Cheers, Trevor.
Welford NP local
Activities Index
Private Surf Lesson for 1 Private Surf Lesson for 1
Far Nth Coast / Byron - NSW
A private one-on-one surf lesson with your own qualified instructor.
Revitalise Me Revitalise Me
Melbourne - VIC
Treat your hands and feet to a soothing, relaxing and rejuvenating experience that will leave you wo
Day Spa Pedicure Treatment - Ringwood Day Spa Pedicure Treatment - Ringwood
Melbourne - VIC
Indulge in this heavenly day spa treat for your hard working feet and legs!
Kangaroo Island Personalized 1-Day Escapade Kangaroo Island Personalized 1-Day Escapade
Kangaroo Island - SA
For Wine or Reason specialize in personalized guided Tours, perfect for corporate clients or the ove
Book Now - Things To Do
