AnswerID: 244253 Submitted: Saturday, Jun 02, 2007 at 21:16
Outnabout David (SA)
replied:
I always have mine engaged.
The Earth wire via switch works when you have everything set up correctly but if those terminals are a bit loose and swing around and touch something eg the bull bar then the earth will come from there and hey presto yiou may end up with a nasdty result.
The only sure way is for the power supply to be broken. I have seen some isolator swithes put in but the usual off the shelf things are only 100 amp jobs which are useless under full load on a winch and current draw.
The easiest way is to just leave the positive wire off until you are in areas where you may need it. It is just a quick job to reconnect to the battery terminal and it is easy to work out... It is either connected or not.
 Click Image to Enlarge |
| We have so little time to enjoy our land |
Reply 3 of 4
