FollowupID: 505823 Submitted:
Monday, Jun 04, 2007 at 21:48
Pezza (Bris) posted:
I know Trev won't be bothered, but I will.
Going by your analogy Ken there should be a big sign in front of the driving position to also let people know there is a risk of serious damage if the vehicle runs out of oil, same sign if run out of water, you say it's not the same with oil because there are warning lights, do new vehicles not have low fuel warning lights ?
"It just ain't right that a fuel pump on a vehicle could be so severely damaged simply by running dry.
Sorry, but that just is not acceptable."
Why ain't it just right ? Why is it not accectable ? Ever tried running your
tyres without air and see how long they last ? No sign any where telling you not to do that is there ?
You say "The manufacturers should not release such a pump if it can't take a bit of a hiding." IMO running out of oil, water or fuel is not 'just' "a bit of a hiding".
"IF it is strongly worded in the owners manual AND (for eg) inside the fuel filler flap, that running the tank dry would cause a serious mechanical failure,"
Where, near the oil filler cap or dipstick does it state likewise regarding oil ?
"Driver education " What driver education ? People buy cars and they drive them, there is no "education" that goes along with it.
Most of us know about the oil or water situation because it is common knowledge proven to us by people that found out the hard way, the same way we are now finding out about the fuel pumps on modern technology engines via others finding out the hard way for us.
Seems to me that you're the type of person that specializes in finding ways to always blame others for your own incompetencies.
If you accept a bit of responsibility in vehicle ownership and regularly check oil, water, battery water level, clutch & brake fluid level, tyre pressures, fuel level etc then the above scenario should never happen and if it does, don't try to blame someone else for it.
Pezza
 Click Image to Enlarge |
| " NO FEAR " means you're not going fast enough! |
