Next-G versus GSM pre-paid mobile
Submitted: Monday, Jun 04, 2007 at 19:26
ThreadID: 46272 Views:4173 Replies:4 FollowUps:24
Saturday Night - Noresman - Next-G doesn't work - Pre-paid GSM works straight away with strong signal.
I thought Next-G was able to pick up GSM as well as 3G?
Most curious
Reply By: Member - Doug T (W.A) - Monday, Jun 04, 2007 at 19:56
Sunday in Wubin, Monday in Mt Magnet,Cue, and Meekatharra, Tuesday in Newman, and 100klm to the North , the New Next G works ,
And as time goes by the Next G system will get even more coverage, In fact all the towns up North I go to have it , and I no longer use an external antenna.
And your phone is either a GSM or Next G not both,and both along with CDMA are Digital , the one that was not digital was the Analogue system that CDMA replaced .
Just checked Norseman for coverage, town is 100%
AnswerID: 244729
Follow Up By: Muddy doe (SA) - Monday, Jun 04, 2007 at 20:00
NextG is supposed to failover to GSM when NextG unavailable.
Having said that, I would expect NextG to be a stronger signal anyway so going onto GSM would be rare and would be restricted to any tower where NextG is not installed or has gone down.
Think it mainly applied in the city where GSM signal can outperform NextG in buildings or amongst buildings.
Muddy
FollowupID: 505756
Follow Up By: Member - Jay Gee (WA) - Monday, Jun 04, 2007 at 20:13
Doug and Dusty said: "And your phone is either a GSM or Next G not both"
Actually - Next-G is both. Next-G is two systems in one unit (1) 3G (which replaces CDMA) and (2) GSM. A Next-G unit checks which of the two systems (GSM or 3G) is available and uses the stronger system.
So if you have a GSM signal - a Next-G phone will use it.
The explanation for what happened to us is probably that the unit "sensed" there was a 3G signal and tried to lock into it in preference to GSM - but possibly the 3G capacity was fully utilised.
Jeff
FollowupID: 505764
Follow Up By: Member - Doug T (W.A) - Monday, Jun 04, 2007 at 20:22
Jeff
I have been for past hour searching the Telstra website for the CORRECT answer and I just can't find anything to back up this rumour, Can you show me in writing anything to prove your statement, and until I get conformation from Telstra I will stick with the knowledge i already have
Doug
FollowupID: 505773
Follow Up By: Andrew from Vivid Adventures - Monday, Jun 04, 2007 at 20:33
The phone works in one mode or other but can switch when switching cells - look at your phone and it will have a little "3" of "GSM" or the like to tell you what technology is being used.
That said, I sense there are issues with Next-G service.
I had a call from Telstra asking if everything was okay, if I was getting drop-outs etc. I said I had a few but not a lot and nothing constantly. Got given a bit of credit, but I get the feeling that the call was really about a proactive approach to real issues that the network has (not unlike lots of other new services).
Andrew.
FollowupID: 505780
Follow Up By: Member - Doug T (W.A) - Monday, Jun 04, 2007 at 20:39
Question: I have a GSM service. What will the new Next G network mean for me?
Answer: There are no plans to stop operating the current GSM network at this time and it is planned that it will be operational through to 2012.
In fact, it will also be modernised and receive an upgraded capability called EDGE (Enhanced Data rates for GSM Evolution) – improving the data speeds currently available via GPRS from approx 40kbps to 120kbps under EDGE. (A number of GSM handsets are already EDGE-capable)
Existing GSM customers who want to take advantage of the additional coverage and features of Next G will need to get a capable handset.
FollowupID: 505782
Follow Up By: Member - Doug T (W.A) - Monday, Jun 04, 2007 at 20:43
Andrew & others
I will sit back on this for a while until I get more confirmation, I am not as clued up with the phone systems as I am with Garmin GPS , I feel I am standing on 1 leg .......the middle one
Doug
FollowupID: 505783
Follow Up By: Muddy doe (SA) - Monday, Jun 04, 2007 at 20:49
Well, I just played with my Motorola V6 Maxx Telstra NextG phone and in the network settings I was able to change the network type to be "900/1800" which is GSM. It even made that annoying mosquito sound in my computer speakers when it switched modes. It displayed "2.5G" on the screen
I have now changed it back to the default "Automatic" setting and it went back onto Next G and now it displays "3G" as per normal.
This would indicate that if NextG were not available then the "Automatic" setting would allow the phone to "roam" onto Telstra's GSM network.
And Yes Doug you are completely correct that GSM will not be shut down for a long time yet and may in fact be improved. There are things that GSM can do like Locality info (where the name of the base station displays on the phone) that are not offered on NextG as yet.
Muddy
FollowupID: 505784
Follow Up By: Member - JohnR (Vic)&Moses - Monday, Jun 04, 2007 at 20:56
Muddy, I think that not all phones are multiband phones so if they ain't, then they don't change bands to the other bands like GSM. The LG I know is a tri-band phone so jumped from Next G, to GSM and also 3G where it was available.
FollowupID: 505788
Follow Up By: Member - Doug T (W.A) - Monday, Jun 04, 2007 at 21:05
Muddy
I didn't say GSM was closing down ,maybe that text was cut and pasted , I didn't read it all CDMA is the one shutting down
I just called the Bloke I have worked with, he drives the Telstra truck with the Float and hauls the Dozers aroubd the Country , I ask him ...can a next G phone be used on GSM , his answer was a very quick NO ,
FollowupID: 505790
Follow Up By: Member - Jay Gee (WA) - Monday, Jun 04, 2007 at 21:24
Hi Doug
The bloke who gave you a quick NO and drives a TELSTRA truck does not know the services supplied by his own company. Maybe he was confused about the difference between dedicated 3G phones and Next-G phones.
It is no rumour - NEXT-G phones can - and do - pick up both 3G and GSM. I know - ours does. In fact the Next-G system was specifically designed to use both networks.
You won't find that sort of information on the website - most big companies are a bit vague on the facts - I don't know why. But if you look at the display on a Next-G phone
Jeff
FollowupID: 505800
Follow Up By: Muddy doe (SA) - Monday, Jun 04, 2007 at 21:27
Well Doug, I can say that I just did it. I just used the Telstra GSM network on my Telstra NextG phone (as described above) and it worked.
Yes, it is the CDMA service that is closing (Jan '08) not the GSM service which as I said will be around for quite a few years yet!
If you are a current Telstra CDMA customer then you MUST get a new handset before Jan '08. Telstra will migrate you to NextG and cancel any remaining contract commitment to CDMA (but will try and sign you up to a new phone plan for 2 years for the NextG phone) You can as of last week get Telstra NextG on pre-paid (buy the handset up front and pay as you go for calls in advance). You could also go to GSM if you want to but NextG is better.
If you are a current Telstra GSM customer then you have the choice to do nothing or to move to NextG. Most (if not all) of the NextG phone handsets will operate on 850Mhz NextG as well as 900Mhz/1800Mhz GSM. It is a setting in the actual phone as to which network you use but in my phone it automatically selects NextG 1st and GSM 2nd.
Muddy
FollowupID: 505806
Follow Up By: Member - Doug T (W.A) - Monday, Jun 04, 2007 at 21:57
Muddy doe / Jay Gee
Thank you for your information , I will now sit back and ponder the new information the brain has been subjected to tonight , Crack open a nice cold stubby of Fosters light , Replace the Smoke alarm in it's place ....yes its because you Mongrels I burnt me sausages while debating with you pricks and filled the caravan with smoke,..........Ah such is life,,
Thanks guys
Doug
FollowupID: 505829
Follow Up By: Member - JohnR (Vic)&Moses - Monday, Jun 04, 2007 at 22:55
Doug, the guy was right on the truck. Next G phones don't work on GSM. But the multiband phones do as Muddy and Jeff say and I do above too. You just didn't ask quite the right question. Nearly right though. He just answered your question without the elaboration.
Hope your smoke detector has stopped by now. Ours has to just twist off and be put away at cooking times. Just a slice of toast will set it screeching.
FollowupID: 505860
Follow Up By: Member - Mike DID - Tuesday, Jun 05, 2007 at 14:25
As a recent ex-Telstra engineer, let me clear up the confusion.
There are currently three frequency bands in use.
850 - used for CDMA and Next G
950 - used for GSM
2100 - used for 3G
If you have a phone that can switch bands it is 3G - not NextG. 3G was the early vesion offering video services but 3G coverage is only available in cities - when there is no 3G coverage, these phones will use GSM.
There is no reason for Next G phones to fall back to GSM - all cells that have NextG also have GSM.
If you want good coverage in rural areas then the ONLY network to conider is NextG - no other netwrk comes near it in coverage area.
FollowupID: 505971
Follow Up By: Member - Doug T (W.A) - Tuesday, Jun 05, 2007 at 15:54
Muddy doe
My reply from Telstra today
Doug
Thank you for your email dated 4/6/07, regarding Telstra networks.
I can advise you that NextG operates on 850mhz bandwidth, 3G operates on 2100mhz bandwidth
and GSM operates on either 900mhz, 1800mhz or 1900mhz bandwidths. NextG will replace the
CDMA network in early 2008. Users of NextG compatible handsets will be able to access faster
download speeds when connecting to the internet via their mobile handset. I can also advise
that users connected to NextG with a NextG compatible handset will roam between networks in
order to obtain greater coverage. Please be aware that if you are unable to connect to the
3G or NextG networks with your NextG compatible handset you will still be able to use your
phone for voice calling and SMS but will not be able to utilise the video calling facility.
I trust this information has been of benefit to you.
Please do not hesitate to contact us on 125 111 (a 24 hour/7 days per week service which is
a 25 cent call from any Telstra service including mobiles, except via Telecard) or via
www.telstra.com if you require further information or assistance.
The rates set out in this email are correct as at 5/6/07 and include GST. The rates may
vary from time to time. Any variation will be done in accordance with the General Terms of
Our Customer Terms which can be found by visiting " target="EOF" class="lbg">Site Link
Yours sincerely,
Jared d279109
Mobile Online ****************************************************************
The contents of this email are strictly confidential. If you are not the intended recipient,
any use, disclosure or copying of this email (including any attachments) is unauthorised and
prohibited. If you have received this email in error, please notify Telstra immediately by
return email and then delete the message from your system.
Telstra Corporation Limited, ACN 051 775 556, ABN 33 051 775 556
Telstra is committed to providing you with the highest levels of customer service, including
protecting your privacy. Telstra is bound by the Commonwealth Privacy Act 1988, which sets
out a number of principles concerning the protection of your personal information.
To view our Privacy Statement, please visit Site Link
If you no longer wish to receive marketing emails from Telstra, you can change your
subscription preference at Site Link
FollowupID: 505989
Follow Up By: Muddy doe (SA) - Tuesday, Jun 05, 2007 at 19:54
Thanks Doug,
I think I had it pretty spot on!
Muddy
FollowupID: 506077
Follow Up By: Member - Doug T (W.A) - Tuesday, Jun 05, 2007 at 20:17
Muddy doe
Your welcome ,
Doug
FollowupID: 506091
Reply By: Philip A - Monday, Jun 04, 2007 at 20:54
On page 69 of my ZTE F252 manual under
"Advanced handset settings"
It says
"Preferred mode. If you have poor Next G coverageyou can choose to lock your Phone to GSM."
ON page 12 it shows screen icons
One is "signal strength on the Next G network"
One is "Signal strength on the EDGE Network"
One is " Signal Strength on the GPRS network"
It automatically chooses, depending on availability.
Regards Philip A
AnswerID: 244754
Follow Up By: Muddy doe (SA) - Monday, Jun 04, 2007 at 20:56
EDGE and GPRS both relate to data calls but both are GSM based technologies so would be a good indicator of the ability to place a voice call on GSM.
Muddy
FollowupID: 505787
Reply By: Muddy doe (SA) - Monday, Jun 04, 2007 at 20:58
Jeff,
What NextG phone do you have? It might be that it is set to NextG only and you would need to manually change it to use GSM or set it to "automatic network selection".
Muddy
AnswerID: 244755
Follow Up By: Andrew from Vivid Adventures - Monday, Jun 04, 2007 at 21:18
Hi there Muddy,
I understand that some NextG phones are not GSM capable.
Apparently, however, the SIMS or USIMS as I think they are more correctly named, from 3G network can be used happily in GSM phones and vice versa (so long as they are Telstra ones, of course).
Andrew.
FollowupID: 505795
Follow Up By: Muddy doe (SA) - Monday, Jun 04, 2007 at 21:36
Yes, I tried that, swapping sims between a NextG and a GSM and they work fine. It is just a case of not being able to use the features of the NextG network from the NextG phone if you are using only a GSM SIM in it.
Muddy
FollowupID: 505812
Follow Up By: Andrew from Vivid Adventures - Monday, Jun 04, 2007 at 21:40
Not so sure on that Muddy ... I think it's the other way.
The NextG features don't work with a NextG SIM in a GSM phone and the GSM phone doesn't work on 3G network.
The GSM SIM will work in the NextG phone fully and completely like a NextG SIM - in fact the USIMs are exactly the same except for the printing on the outside ;-)
Andrew.
FollowupID: 505815
Follow Up By: Muddy doe (SA) - Monday, Jun 04, 2007 at 21:44
Well naturally NextG features don't work with a NextG SIM in a GSM phone as the phone would not be capable of that frequency (850MHz WCDMA) but I would be surprised if the GSM SIM in the NextG phone was able to access things like video calling and high speed data rates using HSDPA. Unless of course Telstra just whack you straight onto the most expensive roaming call rates (outside any plan).
Lol - sounds just like Telstra!
FollowupID: 505819
Follow Up By: Andrew from Vivid Adventures - Monday, Jun 04, 2007 at 21:53
You got it...
The most expensive data rates.
FollowupID: 505828
Reply By: Member - Davoe (Nullagine) - Tuesday, Jun 05, 2007 at 16:22
your phone is stuffed - next G works just fine In Norseman and gets reception out at Peak Charles
AnswerID: 244923
Follow Up By: Member - Davoe (Nullagine) - Tuesday, Jun 05, 2007 at 23:56
oh and as well as most of the way between Norseman and Kambalda as well as my ol stamping grounds South ofWidgie
It is starting to get some of my respect
FollowupID: 506122
