12 volt lights
Submitted: Tuesday, Jun 05, 2007 at 06:12
Eric from Cape York Connections
I need a new 12 volt light the type you clip to your battery what do people use and recommend.
All the best
Eric
Reply By: Member - Troopytrek - Tuesday, Jun 05, 2007 at 06:27
G'Day Eric, We always used to use super cheap lights . Before we went on our three month trip we lashed out and bought the primus flouro's. After owning these we are extremely happy with their light output and the are more efficient than the cheap ones, and you can replce the bulbs in them if you have any dramas. Cheers Troopytrek.
244810
Reply By: mattie - Tuesday, Jun 05, 2007 at 07:10
Hi Eric
i have a versa light which is great and doesn't use much power (..8amp i think) but there is one advertised on this site a yellow torpedo light which only uses .45 amp the only down side to these is that there is no shield on the light so when u hang it up in the
camp or using it as a work light u always have it shining in your eyes.
MATTIE
244812
Follow Up By: Derek from Affordable Batteries & Radiators - Tuesday, Jun 05, 2007 at 07:20
Hi Mattie
Our Torpedo lights are supplied with a self adhesive silver shield that can be fitted, I recommend a piece of al foil inserted into the cover so it can be removed when not needed.
Derek.
505892
Follow Up By: mattie - Tuesday, Jun 05, 2007 at 19:02
Hi Derek
thanks for that we were
camping with a friend at the Carnarvan Gorge a couple of weekends ago just after i had seen them on the web site. I had 2 things i didn't like u have cleared one the other was the hanging hook has a tendancy to slip along the cord. It sounds like a good light with replacable components and low amperage and compact.
MATTIE
506043
Follow Up By: Derek from Affordable Batteries & Radiators - Tuesday, Jun 05, 2007 at 19:16
Hi Mattie
Yes the hook is a loose stainless steel hook, I have zip tied my hook in place.
Derek.
506050
Follow Up By: Sand Man (SA) - Wednesday, Jun 06, 2007 at 00:15
I would have to agree that if you had a choice of only one light, the EvaKool Torpedo is the one to own.
It comes with a cigarette style plug with internal fuse and a short adapter lead with cigarette style socket on one end and battery clamps on the other, for use if you don't have a cigarette style 12 volt socket to plug into.
Very robust and compact lamp which puts out as much light as a 100watt incandescent globe.
"No association with EvaKool or their distributors".
506128
Reply By: traveller2 - Tuesday, Jun 05, 2007 at 08:24
Want a cheap and reliable, low current draw (less than 1 amp) then get yourself a normal 240v batten fitting,
Nelson 12v CFL globe, plastic(PET) peanut butter/jam jar and a woolies extension lead.
Cut off the 240v plug from both ends of the lead fit your 12v plug of choice to one end and the batten fitting to the other, make a hole in the plastic lid of the jar to fit the collar on the batten fitting and it is finished. Less than $20 and a bleep load of light.
I fitted a magnet to the base of the batten fitting so it could stick to the vehicle or a tent pole.
Another option is to buy a bunnings type trouble light and change the globe and plug to 12v items.
244820
Follow Up By: Eric from Cape York Connections - Tuesday, Jun 05, 2007 at 19:33
Yes I made one these many years ago but the old jar used to break on all the corrugations.
All the best
Eric
506058
Follow Up By: traveller2 - Wednesday, Jun 06, 2007 at 08:04
Eric
You must have been using a glass jar, the PET bottles/jars don't break even when dropped out of a moving vehicle onto the road at 80k when full!! Don't ask how I know;-))
506148
Follow Up By: Member - Bill F (VIC) - Wednesday, Jun 06, 2007 at 19:53
Where do we buy a
Nelson 12v CFL globe and I will convert a plastic bed end clip on 240v light fitting
BillF
506292
Follow Up By: traveller2 - Thursday, Jun 07, 2007 at 08:07
They are available at the bigger Bunnings stores or any electrical wholesaler should be able to get them.
They look exactly the same as a 240v one, but are made to run direct on 12v.
506361
Reply By: Member - TasGareth (TAS) - Tuesday, Jun 05, 2007 at 14:43
Hi Eric
I lashed out and bought one of the expensive Pirahna lights.
Did not want to be let down by another cheapy in the middle of the nightgt.
A bit expensive I know, but draws less than 1 amp, really rugged and attaches to the battery or has a merrit / ciggy lighter plug converter, you choose. Has a nice long chord as
Broke but happy
244899
Follow Up By: Sand Man (SA) - Wednesday, Jun 06, 2007 at 00:23
OOps,
In my post above, I mentioned this adapter lead. Now that you have mentioned it Gareth, I think I have confused myself with the accessory adapter lead that came with my Pirahna light, rather than the Torpedo. Sorry folks for the mistake.
The Pirahna light is also very good and is identical to the Versalite. (both made at the same factory)
506129
Reply By: Member - Brian H (QLD) - Tuesday, Jun 05, 2007 at 17:11
I have two versalites and they work fine. As for hooking to the battery I have two weather proof external cig outlets i just plug in.
I have seen similar set ups like travellers and they give plenty of light and are cheap to set up.
Brian
244944
Reply By: Member-Granpa Joe - Wednesday, Jun 06, 2007 at 19:15
If you want low power consumption from your battery these things are fantastic!
Site Link
I use 2 of them in my camper. They draw less than 200 milli Amps (0.2A)
245206
Reply By: Member- Rox (WA) - Wednesday, Jun 06, 2007 at 19:21
Just bought a rechargable LED light (long tube similar to a Flouro) 5 hours + before recharging $44
245207
Reply By: Sea-Dog - Thursday, Jun 07, 2007 at 11:03
I use a Col-lite and have found it to be excellent... cost around $100.
Draws 0.8a and gives off heaps of light..
I have used
mine on several
camping trips including the cape for the past 2 - 3 years and it works a treat.
Made on the Sunshine Coast and built nice and strong.
Col-Lite Products. Lot 11 Ahern Rd Conondale QLD 4552. p: (07) 5494 4655
245354
