battery chargers for AGM deep cycle batteries
Submitted: Tuesday, Jun 05, 2007 at 07:25
ThreadID: 46292 Views:3242 Replies:5 FollowUps:12
Gday guys =D... Its that Noob again, showing his lack of experience lol. After valuable info supplied by members on here and cost considerations. I have decided to charge the 100aH AGM deep cycle battery I am going to purchase in the next week off a battery charger. Been looking at some heavy duty chargers that put out 20-50 amps, on a popular auction site. Are there any special needs that an agm battery needs considered when buying a battery charger? Have seen in posts that 3 stage charger is reccomended. Is there anything else that I need to consider before buying a charger? Going for the Higher amperage ones to try and cut down time gennie running ticking ppl off lol. Thanks in advance for all advice folks =D
Reply By: Member - lyndon K (SA) - Tuesday, Jun 05, 2007 at 07:53
We run a Christies 80 amp charger. Charges all four batts in about an 1.5hrs of run time each day. We just run it when other people are away from camp, that way there is no need for us to annoy ourselves or others.
Cheers Lyndon
ps. the batts are agm's.
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
AnswerID: 244816
Reply By: Robin Miller - Tuesday, Jun 05, 2007 at 08:43
Hi Tentenkaman
While you can't go far wrong if cost is not a major concern with 3 stage charger -
as long as it specifies that it has AGM settings (slightly higher volts etc)
and is suitable for your size battery.
I.E. Little point in getting bigger than 25amp for 100ah battery.
The features though are not required for when charging is under your control and limited to a couple of hours or so, as charger would not have time to get into its float mode in less than about 4 -5 hours.
Here Lyndon's approach in post above is very effective.
I believe ABR is about to release a tricked up gennie based version also.
Robin Miller
AnswerID: 244821
Reply By: TentEnKaMan - Tuesday, Jun 05, 2007 at 09:21
Thanks guys appreciate the info very much. I have now purchased the 100AH AGM if I add another one to it in parralel is this going to change the equation much? Lyndon you seem to have a little multi battery experience. Okay so I do need a specialist charger =D
AnswerID: 244827
Follow Up By: Gronk - Tuesday, Jun 05, 2007 at 09:34
Adding another one will change the equation by 2 !!!! But as far as a charger goes, no not much, except charge times will obviously be longer !!
A good quality 3 stage ( some of the small size electronic units are called multistage ) charger of between 10 and 25A will be all you need !!
If you want faster charge times, go the 25A, but don't expect to fully charge your 70% discharged batts in 2 hrs !! But if you use it every day then charge times will be fairly short as the batts will probably only be down approx 10 to 20% from fully charged !!
Chargers to pick from ( and there are plenty others as well ).....Ctek, durst, absorbed power,......and I'm sure with the 50 other replies your gonna get, there will be another list of chargers..
FollowupID: 505920
Follow Up By: TentEnKaMan - Tuesday, Jun 05, 2007 at 09:41
Ta Gronk 2. I am looking at probably a 25A as I only have a small gennie at this stage thanks for the advice mate. The batteries are 2nd hand and aquired cheaply is that float difference 0.2-0.4volts if i recall correctly going to make a big difference. Thinking of cheaping it out yet again lol. Cant keep up with the $$$ atm
FollowupID: 505923
Follow Up By: Gronk - Tuesday, Jun 05, 2007 at 09:51
If you want cheap, have a look at Absorbed Power chargers, mine ( 10A ) was $159 !!
Can't remember the price on the 25A, but its on the web site !!
These people do mainly boats, but seem to be very knowledgable about batteries !!
FollowupID: 505925
Reply By: TentEnKaMan - Tuesday, Jun 05, 2007 at 09:35
Also I have seen it elsewhere but forgotten so can someone please tell me what that float charge voltage is for the AGM battery (13.6v versus 13.4v) if i recall correctly lol
AnswerID: 244832
Follow Up By: Mike Harding - Tuesday, Jun 05, 2007 at 09:41
Typically; 13V8.
FollowupID: 505922
Follow Up By: TentEnKaMan - Tuesday, Jun 05, 2007 at 10:13
Thanks Mike. So will that 0.4volt difference just mean the battery wont quite charge up to 100% ?
FollowupID: 505931
Follow Up By: Mike Harding - Tuesday, Jun 05, 2007 at 10:43
I'd have to look up the specs. but, from memory, most AGMs spec a float of 13V6 to 13V8 so giving them 13V4 shouldn't be much of an issue. I think they will still obtain 100% charge but sulphation may occur a little more rapidly although, in reality, I doubt you would notice any difference. Try and keep them in the 20C to 25C temperature range for long term (one week +) storage.
Mike Harding
FollowupID: 505939
Follow Up By: Gronk - Tuesday, Jun 05, 2007 at 10:57
Bit like everything, treat em good and usually get a good life out of them....
But in reality, if you only got 6yrs instead of 8 out of them, you'd be hard pressed to pinpoint the exact cause ?? Was it that 0.2 of a volt or was it draining them too much ????? or something else ???
FollowupID: 505940
Follow Up By: TentEnKaMan - Tuesday, Jun 05, 2007 at 11:20
Thanks again gronk and mike. Well looks like im going to have to borrow a little cash. Do you know of a good value for money 25A charger for them Gronk? I wouldnt really know gronk mine are 2nd handies with 3 month guarantee. They are 1-3 yrs old and im assured theyve always been trickle charged and were only used in power blackouts and never run flat . Good price but and still half warranty, guess we'll see lol.
FollowupID: 505945
Follow Up By: Gronk - Tuesday, Jun 05, 2007 at 14:04
AGM's Australia.com.......25A $399.........10A $159
Ctek.....$ ??
Durst....$ ?
Xantrex...$ ?
A 3 stage is really the go, as they will FULLY charge your agm's !! Once charged, they can then be left for weeks ( or months ,maybe ) without needing another charge !!!
FollowupID: 505969
Follow Up By: Outa Bounds - Tuesday, Jun 05, 2007 at 18:23
Price wise Durst makes several different models some cheaper ones and some dearer ones. The dearer ones would be about the same price bracket as the Ctek.
I found Durst to be a great company to deal with, and would suggest contacting them for a price and recommendation. Pretty happy with the 15 amp we brought.
FollowupID: 506030
Follow Up By: Member - Roachie (SA) - Tuesday, Jun 05, 2007 at 19:26
Durst www.durst.com.au/
OR.......what about using an EO sponsor/advertiser: www.sidewinder.com.au/product5.html
I think you'll find that Derek's price is better than what Durst will charge you; and I like to deal with a company that is up-front enough to advertise their prices on the Internet.
The units are identical.
I can certainly recommend Derek Bester's service. He is prompt and you get what you order.....simple as that!!!
I have no financial interest in ABR Sidewinder etc.etc.
FollowupID: 506052
Follow Up By: Outa Bounds - Wednesday, Jun 06, 2007 at 07:45
Derek Bester is certainly the man to talk to if you're after the models that he sells, I have got an impression from my short time on this forum that he also provides some invaluable advice as well.
However Durst does sell other models that Derek may not, check out the SwithchMode Chargers link on the Durst website. It comes down to your budget really and weather you're the type who has to pay more to believe you've got a good quality product that will last.
Lol we got the BCS-1215B recently so you could put us in the category above. Plenty of people seem to have proven that the Jaycar model doest the job just as well, however we chose ours due to size, temp sensor and Aussie product.
If you don't want the real budget option and you don't want to pay top dollar then I'd have a good look at Derek's website, of course if you really do want to pay top dollar I'm sure Derek will be happy to sell you a Ctek.
FollowupID: 506147
Reply By: TentEnKaMan - Wednesday, Jun 06, 2007 at 10:04
Thanks guys had a look at the sidewinder link looks good. Just wondering if i upgrade my generator to a 2.7kva would this upgrade my charging capabilities (that 1 and a half hours sounds good lol) or am I limited by the 2 x 100Ah ? If they are set up in parralel would the charge amperage be divided by the two batteries and therefore double the effective maximum charge allowable?
AnswerID: 245084
