Systems Test
Submitted: Tuesday, Jun 05, 2007 at 09:49
ThreadID: 46298 Views:3358 Replies:6 FollowUps:4
Checking tracks not far from property after last weeks windy wet
Melbourne weather and came up apon a sharp 25 degree uphill off camber
left hander which I have been caught on before.
Had road tyres on, but after such a long dry the tracks couldn't be
that wet however clicked both diffs locks on as I swung into the short
50m section "Just in case".
Got 20m up before all 4 started to spin, and I began thinking I should
have taken the time to install muddies last night.
Stopped quick to avoid sliding sideways to the steep edge of the track 2 meters away.
Engine off, in gear and pulled on handbrake, where apon I thought
"That handbrake lever came up a long way, better make a note to adjust that to".
With wheels already diff locked and tyres already at 22psi best option was
to clear away loose rubble/leaves from the wet but relatively hard surface
and give it a careful go!
No luck but rear slid 1/2m making drop off now 1.5m away.
Pain ! previously got out of here with chains and had wondered if winch would
have been quicker so this time I will try the winch.
No straight pull available, but hooked up to tree and winched car 10m up
and to the left onto a slightly easier track section further away from drop off.
Recovered rope and got in car and tried again.
No luck! but slipped sideways again to 1.5m from drop off.
This was becoming an issue - by myself , not 100% prepared and
just going with normal car supplies and the evening drizzle was beginning.
Ok - attach winch to another tree this time on RHS of track and pull up
another 10m.
Fortunately winch controls are on dash next to steering wheel, for one
person operation whilst driving so this was okay, except noticed voltage
at winch was only 11v and system was under some strain.
Set the Patrols revs to 2000, and poured in the amps and this did the job
but with a little protesting.
Outside temp sensor is mounted on winch so that it can additionally warn of overheat.
Ran engine for 2 mins after winch off to ensure car restart.
Handbrake won't hold on two wheels so have to turn off engine leaving car in gear
then get out and remove winch rope again and we are set to have another go!
Well it was close, but all 4 spun, digging in a little and we moved further sideways
again now with only a meter to the edge.
Ok - I'm beginning to not have fun, except it looked liked Melbourne
was about to win its first game this season, so that helped.
On the downside is was getting darker and drizzle was still there.
Ok - lets put tyres down to 12 psi. But a deflator stuck or was it a valve ?
and one tyre went right down to about 4psi. Not good, but air
transfer hose from front wheel equalized tyres and we ended up with
around 8-9 psi all round.
This has got to do it, but a careful attempt result in no forward movement and we
are now to within 1/2m of the very slippery and loose edge.
I've seen another car slide backwards here and take out its back pillar
so this was becoming an embrassment.
Good thing about being by yourself is their was no one to "Tell you how to do it"
so I raided the car for its single museli bar, some warm coffee and thought - >
1/ I could go home and get the tractor? No! to much embrassment, espically if it got stuck to.
2/ Fit the chains? I even had two sets on board. No! I'm not quite ready to get down & muddy!
3/ Give winch a third try ? Ok - as ropes already out, however no real winch trees left!
Found 4 inch dia Wattle about 100ft out thanks to a 20m extension strap.
Wrapped plasma rope around it, thinking I'll either pull this out
or at least ring bark it, as plasma cuts deeper than steel.
(Wattle re-growth is a pest to be removed in this area !)
Ok, 2hrs gone, dark now, Melbournes got those South Aussies on the run, drizzle has stopped and this had better work !
15m pull, winch volts only holding at about 10 now, winch temp up but ok and car was now onto better ground but hard up against a stump.
Good ! the handbrake now holds the Patrols rear wheels so engine can stay running whilst I have a talk with the stump.
Well a talk didn't work but the chainsaw did and I should just clear the stumps remains with full lock and a little nudging.
Feeling confident now. Radio home - whoops forgot dinner was ready , be home soon dear!
Now, the ground nearly flat, tyres 9 psi, twin lockers in, stump gone, this time with some clutch slip and minor wheelspin we finally gained forward velocity and got onto an intersecting track.
Relief ! and not taking the 1/2 hour to fit the muddies had only cost me 2 hours !
Ok - nothing like an un-rehearsed full systems check at the start of winter but
now its time to limp the 2km home on 9 psi tyres, stuff the coffee and go
straight for the sherry.
Robin Miller
P.S. last Member pic shows the scene at same spot from previous situation in which chains were used to more easily drive straight out (last member pic).
Reply By: Footloose - Tuesday, Jun 05, 2007 at 09:58
Good report, thanks for sharing. I've always said you don't need to get far from home to get into strife :))
AnswerID: 244844
Reply By: Member - Mark E (VIC) - Tuesday, Jun 05, 2007 at 10:22
Robin,
Lucky you have some experience, capable vehicle, common sense and patience. During the week, I spent a couple of days with my nephew, not intending to do anything radical...just a camp along the Big River somewhere with the dog.
Get into camp a little late, just getting dark and NO firewood to be seen. So we jump in the car with the chainsaw, looking for something appropriate, small, easy to get. See this little overgrown track leading off the main track and travel a short way down....getting steeper and looking pretty rocky...with this drizzle it might be a little uncomfortable getting back out, (no diff locks :-( ) so decide discretion is best.... just backing out and a bloke comes running up the track waving his torch...still in his waders. Has been down there fishing and has been trying to get out since about 10am that morning (now 6.30pm). Remember it's mid week, very poor weather and off-school holidays....there wasn't anyone around. Even the Rangers were up in the NP with all the post fires work!
It's a Navara with road tyres, running 32lb in 3 of the tyres and 12lb in one of the back tyres. He has a winch.... one of those cheap electric ones that you lift out of the back of the car and attach to where you want. It has cable about 4-6mm diameter. He has no shovel, no tree protectors, unrated (VERY) dodgy looking shackles, no comms gear, (well out of phone range).
After having a look at the predicament and letting the tyres down to 12 all round, still unable to drive out as it's just too slippery and with those tyres.....
Unravel the winch cable, attach drag chain to front of Nav and MY shackle, secure car with winch extension strap to very large tree behind and begin winching.... got him out in about 20 mins allowing winch to cool and like you battery to recharge a little...... needless to say he was very appreciative....
Gave him a gentle lecture on being prepared for remote area travel (even in Victoria..!) and some information on more appropriate recovery gear. (I think he said his snatch strap was from KMart??).
It seems to happen with monotonous regularity. Every time I go away, I seem to recover someone. Not that I mind helping, but it does become irritating when you know they haven't got even the most basic of recovery equipment.
They didn't even catch a fish for their trouble!!!!
Mark
AnswerID: 244849
Follow Up By: Robin Miller - Tuesday, Jun 05, 2007 at 11:06
That's so unfair that he couldn't give you a fish or two Mark.
The tracks are certainly slippering up, and at least you got a brownie
point for 4wds.
Don't mind a bit of a challenge here and enjoy estimating if
I can get out of anything I knowingly drive into with at least
one tool left unused my sleeve - like chains this last time.
Problem here is that the driver is probably the weakest link in my system.
Robin Miller
FollowupID: 505943
Reply By: Member - John (Vic) - Tuesday, Jun 05, 2007 at 11:49
"Wrapped plasma rope around it, thinking I'll either pull this out
or at least ring bark it, as plasma cuts deeper than steel"
The way I read this you hooked to plasma back onto itself??
What happened to your Tree Protector?
Not a very good idea as it lowers the tensile strength of the cable used.
AnswerID: 244870
Follow Up By: Robin Miller - Tuesday, Jun 05, 2007 at 12:55
Hi John
Yep wrapped it back on itself , not the best practise but acceptable call
in that situation.
No point using a tree protector , I'll probably be back there this weekend
with a drag chain removing the pest anyway.
Robin Miller
FollowupID: 505961
Reply By: Des Lexic - Tuesday, Jun 05, 2007 at 13:17
Robin, I can see where you went wrong. You were barracking for the wrong team. LOL
If I had of been there, I would have turned the radio off to save battery power, or so I wouldn't have to hear the crows getting a flogging anyway.
I bet your sphinkter valve was working overtime too. Glad you got out of it OK.
AnswerID: 244883
Follow Up By: Sand Man (SA) - Wednesday, Jun 06, 2007 at 00:51
You beat me to it Des.
I was going to say what a good story except for the bloody Demons flogging the Crows.
Bill
FollowupID: 506132
Reply By: Moose - Tuesday, Jun 05, 2007 at 13:35
G'day Robin
Being close to home must have been comforting, knowing there was a definite safe fall-back position if all else failed. So that's twice now you've been caught out on that spot - don't make it three :-)
Cheers from the Moose
AnswerID: 244887
Follow Up By: Robin Miller - Tuesday, Jun 05, 2007 at 18:45
Nobody saw me Moose - so if it happens again it will be the first time !
Robin Miller
FollowupID: 506041
Reply By: Member - JohnR (Vic)&Moses - Tuesday, Jun 05, 2007 at 14:25
Sounds like a near drowning Robin. You can nearly recount second by second what was happening so it comes across as a salient warning to us all. Don't take any situation for granted. Good report.
AnswerID: 244892
