Clutch shudder after real main seal replacement
Submitted: Tuesday, Jun 05, 2007 at 16:28
ThreadID: 46316 Views:2697 Replies:6 FollowUps:10
I posted about a week ago regarding Nissan being cagey in replacing a leaking rear main seal. Well it turned out I had no problems and they replaced it. However I now have a shudder when moving off in first gear. Now, this shudder may have been there before but was almost un-noticable but now it is just damn unpleasant.
It seems to be getting steadily worse almost by the hours driving round town so I took it back and had a mechanic test drive it. It was actually the chap who did the work on the rear main who confirmed clutch shudder and suggested I needed a new clutch.
Apparently shudder is caused by hot spots or high spots on the clutch plate and is not covered by warranty and could not possibly have been caused by the work recently undetaken. Quote to replace $1600. I am not silly enough to pay that but I have done a site search and it appears that most vehicles that develop a clutch shudder while still under warranty have had them fixed under warranty. Is this the case or is the clutch a "consumable" part?
Should never have let the buggers at it!
2004 GU Cab chasiss 68,000 klms 4.2td
3 weeks left on factory warranty
Jim
Reply By: Member - 120scruiser (NSW) - Tuesday, Jun 05, 2007 at 16:41
Clutch's generally aren't covered by warranty but a good dealer will attempt to look after its customers. Make sure they have the flywheel surface ground otherwise it will be a waste of time doing the job. I would also find out if they are going to replace the whole clutch kit including pressure plate and release bearing or only the clutch plate. Some dealers will only replace the clutch plate.
Food for thought.
AnswerID: 244934
Follow Up By: Batboy - Tuesday, Jun 05, 2007 at 18:40
If Nissan fixes it under warranty then as long as it works fine and lasts I don't care which bits they replace. If I am paying then it will be done by my mechanic the right way
Cheers for the feedback
FollowupID: 506038
Reply By: MintabiePete (NSW) - Tuesday, Jun 05, 2007 at 16:45
Your shudder is possibly caused but oil on the clutch plate caused by the leaking rear main seal . Its a wonder the mechanic never mentioned this possibility .
AnswerID: 244936
Follow Up By: Batboy - Tuesday, Jun 05, 2007 at 18:42
If that where the case then I expect it would have shuddered more before the seal was replaced rather than after. If it was contamination on the clutch plate would I expect this to get better over time?
Cheers Jim
FollowupID: 506039
Follow Up By: MintabiePete (NSW) - Tuesday, Jun 05, 2007 at 20:20
I have never seen them improve once they are contaminated by oil and get to the shudder stage , usually only a new clutchplate , pressure plate , thrust bearing and possibly a spiggot bearing and the replacing of the rear main seal usually gets them back to the way they were :)
FollowupID: 506092
Follow Up By: oldpop - Tuesday, Jun 05, 2007 at 21:43
Maybe the mech should have cleaned his greasy paws before he put it back together
regards
Old pop
FollowupID: 506100
Reply By: rescue134 - Tuesday, Jun 05, 2007 at 17:44
I WONDER IF THAY REMOVED THE GEAR BOX ON AN ANGLE (BENT / WORPED THE CLUTCH PLATE) THIS IS A REGULAR PROBLUME IF NOT DONE WITH A GEAR BOX STAND???
AnswerID: 244954
Reply By: Member QLD Steve & Lorraine Mc - Tuesday, Jun 05, 2007 at 17:50
Batboy
Did you go back & read your replys to your last post, letting those idiots near it was the wrong thing to do. Best of Luck ???
Steve.
AnswerID: 244958
Follow Up By: Member QLD Steve & Lorraine Mc - Tuesday, Jun 05, 2007 at 18:16
Knocking that rubber block out would have done the job just fine, shows you how brain dead they are, they cant even work that out??? Post ID-46088 Answer ID-243707
FollowupID: 506027
Follow Up By: Batboy - Tuesday, Jun 05, 2007 at 18:38
Hi Steve, I really didn't want ANYBODY pulling out the gearbox let alone Nissan. Thay had another look and decided to replace the main seal. I didnt realise how that foam thing fitted into the equation but now that its missing its obvious. You gotta ask why they didn't remove it on the first trip in. Surely that would have shown where the "leak" was.
I'm just so damn busy at the moment I don't have the time I would like to double guess the "experts". So now it looks like the car will be off the road again soon. Dammit! Wish I had read your post before they got there hands on it.
FollowupID: 506036
Reply By: Peter 2 - Tuesday, Jun 05, 2007 at 17:54
That's bullcrap about clutches not being covered under warranty, I've had several replaced under warranty on Toyota's due to clutch shudder.
AnswerID: 244959
Follow Up By: Batboy - Tuesday, Jun 05, 2007 at 18:43
What klms did you have on them? I think they are reasonibly happy to replace them up to around 20,000klms
Cheers Jim
FollowupID: 506040
Follow Up By: scottp - Wednesday, Jun 06, 2007 at 09:50
Yep,
We had a 99 and 02 luxe both had clutch kit put through them at around the 28,000k mark, and my new October 05 model is having the same done next week with 42,000k on the clock (although I have been complaining about it since 10.000k)
All covered under warranty.
With the 02 luxe the local dealer (Madills in Noosa) told us that the clutch was a wearable item and not covered under the warranty. $1200 quoted to repair. Local mechanic quoted $750. Toyota dealer in Nambour quoted $650 so we booked it in,
had it done and when we picked it up and the dealer told us no charge, the vehicle is still under warranty.
We buy two luxes every 3 years and service them religiously. none of our business goes to Madills nor will it ever.
Both Nambour and Currimundi Toyota dealers on the sunshine coast I find are very helpful.
Scott.
FollowupID: 506176
Reply By: Mark & Jo, S/side, Bris - Wednesday, Jun 06, 2007 at 12:11
G Day James! long time no post!
You been back to the pines area since I last spoke to you on the phone when we went there?
Jo
AnswerID: 245112
Follow Up By: Batboy - Wednesday, Jun 06, 2007 at 18:19
Hey Jo, I 've been around, posting here and there.
Hows the Jack going? All the probs sorted yet?
I had a look at p/pines abour a month ago and it was pretty dry but now it will be a real mess :) I am not going near it!
Cheers Jim
FollowupID: 506271
Follow Up By: Mark & Jo, S/side, Bris - Wednesday, Jun 06, 2007 at 18:37
Bet you'll get a phone call off someone this weekend!! it will big a huge boggy mess there now!!!
We got a Paj not a Jack! yeh all good now, harmonic balancer and all got done the other week. All good now. Thank goodness for that!!!!! the vehicle is starting to become bad luck for us!!
FollowupID: 506275
