HZ 100 Series Engine Rattle
Submitted: Wednesday, Jun 06, 2007 at 23:44
ThreadID: 46371 Views:4061 Replies:8 FollowUps:5
Was wondering if any one can offer advise on the following. My 1999 100 Series 247K's Diesel has developed a high metallic rattle from the engine going through 1900 RPM that is audible whilst driving? The rattle is present in all gears, on acceleration and on de-acceleration. I have had it to the Toyota Dealer with not a lot of info forth coming. Any info or advice on cause/fix etc would be appreciated.
Reply By: crusa - Thursday, Jun 07, 2007 at 07:16
Hi nuboy
I had a high metallic rattle at about the same revs and it was traced to the large muffler. May not be your cause but worth a check.
AnswerID: 245307
Reply By: traveller2 - Thursday, Jun 07, 2007 at 08:09
Do search as there was a recent discussion about a ticking type noise at certain revs which is apparently crankshaft flex.
AnswerID: 245312
Reply By: AaronBarrel - Thursday, Jun 07, 2007 at 08:30
Hi Nuboy
I have a 2002 1hz 100 series with a ticking noise that is audible at about 1900 evs through to 2300 revs. Mine actually does it from 1000 through to 1400 as well so your lucky if it is the same problem as you have done 247k's I have only done 90k's. Toyota call it crankshaft flex and arent fixing the problem as they have had no engine failure resulting from this noise it seems to be the block where the crank sits in that is out of wack causing the crank to flex resulting in this noise. An easy way to diagnose this prob is stick you head in under the car whilst reving the throtte with youre hand and you will hear this noise quite easely coming from the sump. Remember Handbrake!!!
AnswerID: 245321
Follow Up By: nuboy - Friday, Jun 08, 2007 at 00:27
Thanks for the reply Aaron,
Reading all the reply's and trying to digest info, I think you may-be on the money. The symptoms or (noise) you describe sounds very similar to what I'm hearing. Seems others are having the same sort of rattle only with slight differences in RPM ranges. One thing that struck me though was the comment regarding the rattle becoming more pronounced closer to oil change time. Don't know if I'm going to be able to live with it though, bleep like that troubles me, driving along listening to it wondering when and if it is it going to let you down, thing is, seems there is no easy fix.
FollowupID: 506561
Reply By: Sea-Dog - Thursday, Jun 07, 2007 at 10:30
Try different grades of oil through you oil changes...
I initially tried some heavier oils but lately I am thinking of trying a thinner oil to see if the noise can be heard louder or quieter... I am only trying this as my engine always seemed a little noiser towards the end of the oil life and nice and quiet once the oil was changed.. however lately it seems to be that the motor is noisy until it has done at least 10k's of driving so I am assuming that the oil has had a chance to thin down with the heat.
Could have something to do with the oil pump or galleries not letting the heavy oil through or something.
Also it may be worth having a look at the actuator arms on the fuel pump... there is a small arm that is pulled in by a vaccuum from the Air Con.. the arm that then pushes the throttle link has a nylon bush that wears out and gives sideways movement.... when your motor gets to a particular rev it rattles! I had this problem and was thinking it was something serious until I found this out and took it off... that problem was then fixed!
I do have the crankshaft flex (detonation) noise though... very different type of noise and once you have heard it you know it.. a sound all of its own. as described as a little man with a hammer tapping away.. I describe it as a tin with a couple of marbles in it being rattled.
Hope that helps you out.
by the way.. I have found that different fuel mixtures etc does affect the amount of noise that is put out so it may be worth your time to have that checked out!
AnswerID: 245349
Follow Up By: nuboy - Friday, Jun 08, 2007 at 00:38
Sea-Dog
As with Aaron's response above, you have given me some food for thought. Being a petrol man my first thoughts on the matter, was piston slap but as a result of reply's which give enough info to be able to research further this Crank Flex idea seems to start taking root.
Catchyalater
FollowupID: 506562
Reply By: Member - murray S (VIC) - Thursday, Jun 07, 2007 at 12:29
Some years ago mine had a rattle [noise] Found it was the alternater mount lose .Who knows..Murranji
AnswerID: 245367
Reply By: Dustin - Thursday, Jun 07, 2007 at 14:18
Try posting on www.lcool.org .There is a forum here dedicated to 100 series LC's and a lot of good advice is posted
AnswerID: 245394
Follow Up By: nuboy - Thursday, Jun 14, 2007 at 09:49
Hi Dustin
Thanks for your response, I tried your link, seems to be shut down at the moment, At this stage I'm thinking my engine rattle problem may possibly be related to piston slap? I need to get some informed diagnostic's done.
FollowupID: 507537
Follow Up By: Dustin - Thursday, Jun 14, 2007 at 11:13
Keep an eye on the link, you can join the forum and you can receive daily updates of all answers in one email. If you want to make contact with a moderator by email let me know and I can send you their email address.
FollowupID: 507545
Reply By: cowpat - Thursday, Jun 07, 2007 at 18:50
It could be rattly springs or dampers in the springs of the clutch plate if you've got a turbo diesel. Casper
AnswerID: 245446
Reply By: nuboy - Thursday, Jun 14, 2007 at 12:57
For those that have been following this thread I have had a Diesel Mechanic check out the engine rattle and he is 98.9% convinced its only a loose tappet,
therory being the rattle when you listen to it, is double the pulse speed of the engine pulse speed or RPM. I will pull the rocker cover off on the weekend and check out his theory ?
AnswerID: 246751
Follow Up By: anleky - Thursday, Jun 14, 2007 at 13:36
shouldn't it be half pulse speed?
Camshaft turns slower than the crank.
FollowupID: 507553
