Nipples
Submitted: Friday, Jun 08, 2007 at 17:49
brummie pete
Hi all i am just hoping someone can help me a specific nipple on my tail shaft .
I have a 2h diesel landcruiser and was greasing up today with my mcnaught grease gun and found i couldnt quite get the grease to go in on the tail shaft by the back axle .
I can get the gun on there but it doesnt quite sit square enough for the grease to pump in cleanly ,i was wondering if anyone had any tricks up their sleeves .
As an end note i did take the nipple out and checked to see if it was blocked but it was clear and while it was out i managed to put some in with needle but i dont believe i got in as much as i would like to .
Your help would be appreciated .pete
Reply By: Member - joc45 (WA) - Friday, Jun 08, 2007 at 18:27
Pete,
I had the same trouble with both the trusty Mav and the Patrol in the front uni. In my case, the nipple was pointing thru the narrowest gap of the uni, and the running angle of the shaft was closing that gap, a problem that didn't exist with the rear shaft, which was a straighter angle.
I had several gun nozzles, so could afford to trash one if necessary. I ground some metal off each side of the nozzle so it would just clear the yoke of the uni. There was enough meat in the nozzle to allow me to do this without cutting thru it. I still have to turn the uni to a particlular angle to get the nozzle in and get a clean squirt, but it works.
Gerry
245662
Follow Up By: Member - joc45 (WA) - Friday, Jun 08, 2007 at 18:40
Guess I meant to say that the tight gap in the uni prevented the gun nozzle from being inserted exactly square onto the nipple. Hence the mods to the nozzle.
506685
Follow Up By: Axel [ the real one ] - Friday, Jun 08, 2007 at 19:11
So you managed to pierce the nipple at [ the ] uni. lovely.
506690
Follow Up By: brummie pete - Friday, Jun 08, 2007 at 19:38
thanks gerry ,i did have a look today at coventrys and they dont have anything that would go on the nipple ,and the last thing i want to do is chew the nipple so as you have suggested a bit of grinding maybe in order .
506693
Reply By: Mike Harding - Friday, Jun 08, 2007 at 18:34
Currently at 33.
I bet this thread gets a _really_ high read rating :)
Mike Harding
245665
Follow Up By: Member - joc45 (WA) - Friday, Jun 08, 2007 at 18:38
Just your dirty mind!
I knew what he meant!!
506684
Follow Up By: Mike Harding - Friday, Jun 08, 2007 at 18:44
Please don't feel the need to justify yourself.
506686
Reply By: Mikee5 (QLD) - Friday, Jun 08, 2007 at 19:17
Jack up one wheel, turn wheel until nipple is in better position. Gap opens and closes as shaft turns.
245674
Follow Up By: Member - joc45 (WA) - Friday, Jun 08, 2007 at 20:18
Hi Mikee,
For the rear shaft, fine. Not sure what other vehicles are like, but on the front shaft of the Nissan Patrol, the front yoke only opens up at the top coz of the shaft angle, with the engine right above blocking access. No amount of turning would allow the standard nozzle to fit squarely on the nipple, except from above.
Apart from grinding the nozzle to fit, a U-shaped tube from the gun so the nozzle could come in from above was the only other answer.
Don't know what Nissan do to grease it, probably nothing - lol!
Gerry
506697
Follow Up By: V8 Troopie - Saturday, Jun 09, 2007 at 00:07
Gerry, you said it, grease the nipple when it points up. I have that dilemma on my HJ75. Replaced the solid grease tube on my grease gun with a flexible tube and the original nipple receiver screwed on its end. Works fine now but insertion is by feel only. BTW, my grease gun is the little jobbie that uses grease cartridges.
Klaus
506732
Follow Up By: Member - joc45 (WA) - Saturday, Jun 09, 2007 at 16:44
Hi Klaus,
Yeh, I've got a flexible tube as
well, but it's almost impossible to get enough pressure directly onto the nipple so as to avoid grease squirting out the sides.
Gerry
506774
Follow Up By: V8 Troopie - Sunday, Jun 10, 2007 at 01:22
Gerry, it should not require much pressure if your nipple fitting grips the nipple properly.
I found that there are fittings with two and others with three prongs gripping the nipple. I found the three prong holds better.
There is a similar issue with the snap on
water hose fittings.
All I need to make sure of is that the fitting bites squarely on the nipple and is not pushed over by one of the universals 'arms'.
Klaus
506809
Follow Up By: Member - joc45 (WA) - Sunday, Jun 10, 2007 at 10:26
Hi Klaus,
Understand what you are saying. Perhaps the quality of the nozzle fitted to the flex hose might have been a factor in my case; in any event, I found that without some good pressure on the nipple, I could not get it to inject grease properly, and getting that pressure was quite difficult with a flex hose. Perhaps if I'd bought one from a more respectable supplier!
Gerry
506825
Reply By: Member - Ian W (NSW) - Friday, Jun 08, 2007 at 20:44
This post was a complete let down
245691
Follow Up By: Johnny boy - Friday, Jun 08, 2007 at 20:50
I just walked in from outside its a little NIPPLE I mean NIPPIE out there !!!....Ah I'm going to bed :)
Night Night
506705
Reply By: goingplatinumcomau - Friday, Jun 08, 2007 at 21:01
Hi Pete
It is a simple solution all you do is go buy a Straight Nipple there about 1 inch long.
You then have to screw the other one out and put the straight one in to do the job and it pokes out through the universal so can not stay there it will do the job then screw the long one out and put the short one back abit messy but job done.
Regards John
245694
Follow Up By: brummie pete - Friday, Jun 08, 2007 at 22:25
great solution john hopefully i will be able to get some nipples an inch long .pete
506720
Reply By: Jimbo 2121 - Friday, Jun 08, 2007 at 21:17
You can take the fitting off the end and just press the pipe against the nipple. If you hold it firmly and square then most of it goes in. You could experiment with a bit of rubber to get a better seal. So far I like the idea of the tube.
245698
Reply By: hillbillie - Friday, Jun 08, 2007 at 22:50
Go to your local auto store and buy a needle adapter for your grease gun mcnaught and alemite sell them .
Cheers Andy
245719
Reply By: lindsay - Saturday, Jun 09, 2007 at 08:36
You can go and purchase a long nipple from an auto
shop, they are about 25 mm long and will protrude out where you can get the gun on to it.
245736
Follow Up By: brummie pete - Saturday, Jun 09, 2007 at 13:18
Hi lyndsey ,i have tried that today and i cannot get one that is metric .The nearest ones to me at the moment seem to be in kalgoorlie .
I went to toyota and they said
shop around at the likes of superscheap,repco,autoone which i did but no one seems to have them .
506767
Reply By: G.T. - Saturday, Jun 09, 2007 at 16:32
Not the ideal interim sloution until you buy another size nipple is to ( if pratical ) that is, disconnect the shaft and grease it disconnected. May be worth considering. Regards G.T.
245766
