brake warning
Submitted: Friday, Jun 08, 2007 at 21:01
slush
does the gu 2000 have a warning buzzer when brake pads are low, as in when you put your foot on brake peddle it sounds a buzzer.
Reply By: Member - Jiarna (NT) - Friday, Jun 08, 2007 at 21:30
Have a look at the brake pads - do they have a wire attached to them? I used to own a Peugeot 504 and it had brake pad sensors which consisted of a wire inserted into the pad. The pad wore down to the wire which then contacted the rotor and turned on a light on the dash.
245701
Reply By: Member - 120scruiser (NSW) - Friday, Jun 08, 2007 at 21:36
No they don't.
245704
Reply By: Member - extfilm (NSW) - Friday, Jun 08, 2007 at 21:44
check your brake fluid level
245710
Reply By: Derek from Affordable Batteries & Radiators - Friday, Jun 08, 2007 at 21:47
Hi Slush
I am getting reply's on the other Prodigy thread.
Most pads have a metal tab 'tell-tale' it touches the disc when the pads are low and cause a high pitch screech. I would say this is what you hear. You will have about 2mm of pad or 2000 km left.
Derek.
245711
Follow Up By: slush - Friday, Jun 08, 2007 at 21:57
sorry derek,
i keep login on under my member #, but as i go through the post it goes back to the old user name for some reason. don't know how to fix it.
506715
Follow Up By: Derek from Affordable Batteries & Radiators - Saturday, Jun 09, 2007 at 08:21
On your internet explorer 'Tools' tab. 'History' 'Delete' clean up history folder and passwords folder.
506739
Follow Up By: Member - shane (SA) - Saturday, Jun 09, 2007 at 19:58
thanks Derek, all fixed now. (computer that is)
506791
