Car won't start!
Submitted: Sunday, Jun 10, 2007 at 09:11
Outa Bounds
80 series cruiser with 6.5l chev diesel engine. Engine is only about a year and a half old at the most.
He's replaced the glow plugs, battery was fully charged. Starter motor replaced a week ago. Any ideas?
We'll have to get it looked at on Tuesday. So just after ideas of things we could look at in the meantime or if anyone is aware of known things going wrong with this type of engine?
It was going fine on Friday, several short trips and then Sat arvo no go. He's also tried extending the glow plug timer with no luck. the fan spins and it's trying to start.
We're recharging the battery now with the 3 stage to give it another go.
Reply By: Footloose - Sunday, Jun 10, 2007 at 09:14
Fuel problem ?
245833
Follow Up By: Outa Bounds - Sunday, Jun 10, 2007 at 09:25
He's checked that there is power to the fuel solenoid.
Dirty fuel, don't know? But it was running fine last time I drove it, no hickups or anything, and it just sat there doing nothing for a day.
Batteries are Orbitals only about 18 months old.
506820
Reply By: 3.0turbob - Sunday, Jun 10, 2007 at 09:45
Tend to agree with Footloose.
Filter primed? Loose/cracked fuel lines (sucking air)?
........sounds like a job for Roachie
245838
Reply By: Peter 2 - Sunday, Jun 10, 2007 at 09:46
They have to reach a certain amount of revs on the starter motor to start especially when cold.
They definately won't start when cold without the glowplugs, but if at least 3 or 4 are working and the engine can be turned over fast enough it should start.
A few things to check:1/ Fuel at the injection pump, loosen the incoming line from the fuel lift pump (does it have an electric lift pump or mechanical ?), fuel should leak out straight away if it has an electric pump and the ignition is on, no fuel supplied till the engine is turning over with a mechanical pump.
2/ Power to the stop solenoid (on top of injection pump) should be there when ignition is on, check that solenoid operates, you should hear a click when the ignition is turned on.
3/ check power supplied with either a testlamp or multimeter at one of the glowplug leads when ignition is turned on and glow cycle begins.
4/ Actual glowplugs ok? check by unplugging the leads to plugs and either a multimeter (continuity to ground/engine) the glowplugs go open circuit when blown.
It is easier with a test lamp, wire connected to positive battery, test plug by placing probe on connector on top of plug with leads disconnected, light on plug ok, light off plug blown.
As I said earlier it should start with at least 3 or 4 functioning unless it is really cold but will run rough and chuck out a bit of smoke initially.
245839
Reply By: Outa Bounds - Sunday, Jun 10, 2007 at 09:56
I'm printing all this and taking it out for him to read....
245842
Reply By: Outa Bounds - Sunday, Jun 10, 2007 at 10:29
He checked everything on the list, all was aok. Battery finished charging and it started.
Not sure then, battery issue perhaps due to doing some short runs. He did try to jump start by connecting to the 100% charged auxilliary as
well though (this morning). And yesterday it didn't start after fully charging the battery - which was when he replaced the glow plugs with a new set he had as spare.
But everything else on the list checked out.
245851
Follow Up By: Member - Roachie (SA) - Sunday, Jun 24, 2007 at 20:18
As it started to get cooler recently, I noticed that
mine was getting a bit dohey when i started it too, even though the battery was a fairly new 760cca Supercharge Gold jobbie and in good condition. So, I've recently fitted a 2nd dedicated starter battery (making a total of 3 batteries in the Patrol all-up) and now she fires up REAL quick even on the coldest morning. Also, the glow plugs seem to take less time to do their job than before.
Hope this helps.
509708
Reply By: Outa Bounds - Sunday, Jun 10, 2007 at 10:32
We'll speak to the bloke where we got the engine done on Tue to try & figure out the issue.
Thanks for your help everyone.
245852
Reply By: Kev M (NSW) - Sunday, Jun 10, 2007 at 12:01
Are you doing the ground work for Roachie??
Sounds like he's to scared to tell us that his Chevnissan in the disguise of an 80 Series wont start again. LOL
Kev
| Russell Coight:
245872
Follow Up By: Outa Bounds - Sunday, Jun 10, 2007 at 14:16
Hmmm so he had a similar issue? I did read some threads of a chevnissan when I was having a look at related topics this morning.
Currently we think we'll try replacing the battery - too many short runs maybe means not charging enough or not providing enough cranking amps, it's all we can put it down to at this stage. Living in a small town like
Cobar means dropping the kids of and going to the shops is a 5 minute drive.
What kind of batteries is Roachie running?
506852
Follow Up By: Kev M (NSW) - Sunday, Jun 10, 2007 at 14:43
Check out this post,
Site Link
Cheers Kev
| Russell Coight:
506854
Follow Up By: Outa Bounds - Sunday, Jun 10, 2007 at 15:04
Thanks for that.
506858
Follow Up By: Outa Bounds - Sunday, Jun 10, 2007 at 15:24
Read Roachies thread, sounds like we should get all the electrics checked out.
If you're reading this Roachie, have you had any further problems or did you find the cause in the end?
We have a spare starter motor to carry on the trip with us and plan on replacing the battery just in case before we go. Gee really hope it's not going to turn out to be unreliable.
506860
Follow Up By: Member - Roachie (SA) - Sunday, Jun 24, 2007 at 20:23
Sorry for the late reply......Annette just pointed this post out to me.
As I have said above, I now have a 2nd battery just for starting (ie: I now have 2 batteries, just for starting and doing the other standard things that a starter battery has to do).
However, the no-go problem turned out to be the starter motor's solenoid. The starter motor itself is also a bit worn and I have asked the auto-elec to order me in a new one as
well as check out the alternator etc (maybe new bearings etc if he deems them necessary). My starter had a hard life externally, cos the previous owner didn't have much of a lift in it.....every time it went over a bit of gnarly country, the front diff's flange would hit the bottom of starter motor.
Roachie
509713
Reply By: Member - Col G (WA) - Sunday, Jun 10, 2007 at 15:46
Was on a trip with one of those in the party. It just ran out of power and stopped dead. Tried most things wouldnt start. Turned out to be a dodgy immobiliser, part of it had stopped the fuel pump from doing its thing. If you have an intermittent fault, may be worth looking at.
Hope all is
Col
245907
Follow Up By: Outa Bounds - Monday, Jun 11, 2007 at 06:50
Hi Col,
We had immobiliser trouble with the last car I believe and it was different to this time - like you say it just wouldn't go. So with this one my husband got shown how to get around it should we have trouble in the middle of nowhere -
well that's if he remembers what he's supposed to do (which wires etc).
Certainly something always to keep in the back of the mind though.
506948
Reply By: Outa Bounds - Tuesday, Jun 26, 2007 at 16:22
Well just an update, had the starter motor solenoid replaced and then the starter motor. Also got a new alternator.
The starter motor did go the first time but seems that the plug in the back of the alternator was a bit loose too which probably didn't help.
Next we're looking at getting a higher CCA battery as a starter or putting a second one under the bonnet like Roachie has done.
It will probably be the two orbitals for now and if we just want one starter battery seems like an Optima is the only other with higher CCA than 750 that would fit under the bonnet in the current holder.
No problems starting in the last week or so, hopefully it continues.
249275
