what's the best wheel carrier hold open mechanism
Submitted: Monday, Jun 11, 2007 at 10:31
ThreadID: 46516 Views:3084 Replies:11 FollowUps:4
Hi all
Many thanks to all the reply's to our questions of late, it has been most helpful.
Am now in the middle of building a spare wheel carrier but have yet to decide on a good system to hold open the spare wheel? It need to be sturdy, reliable and very easy and quick to open and close i guess.
I liked the opposite lock type with the gas strut but l wonder if they might be a pain when on un even ground? or fail due to dust on the shafts as they seem to on tractors?
The Kaymar version with the little flip over bent rod seems simple and l wonder what people think of this?
Then possibly there is better options that someone may have come up with?
Look forward to hearing your thoughts
Kind regards GN
Reply By: Member - Captain (WA) - Monday, Jun 11, 2007 at 12:09
Hi GN,
Take a look at the large door of a GU Patrol. It has a mechanism that holds the door open to the correct angle, but if you give the guide a "push" in, it locks the door open - great when parked on a slope. And to close the door, simple has giving a "pull" on the guide to unlock. Bound to be able to source something from a wrecker (not too sure if GQ patrols had the same).
Captain
AnswerID: 246040
Follow Up By: Member - G N (VIC) - Monday, Jun 11, 2007 at 12:45
Thanks Captain
Sounds like something worth a good look.
Will check out wreckers tommorrow.
GN
FollowupID: 506982
Reply By: Johnny boy - Monday, Jun 11, 2007 at 12:11
Im hoping you get a responce because Im doing the same thing and was getting on EO to see whats out there LOL!!!
Regards and good luck J.B.
AnswerID: 246042
Reply By: Member - Ian S (NT) - Monday, Jun 11, 2007 at 12:47
Hi GN,
Had an OL dual wheel carrier on the troopy and it had a bit of bent metal to support the open carrier. Failed on first use. Replaced it wwith a short piece of 20/25mm tube fashioned to fit on the same mount and it worked a treat. It held the wheel carrier out after the gas strut opened it easily.
My experience.
Ian@Mt Dare
AnswerID: 246051
Reply By: KiwiAngler - Monday, Jun 11, 2007 at 14:04
This works ok - but u have to be sure to open the locking lug BEFORE trying to close the wheel carrier otherwise it gets bent - rather like it is in the pic - :-)
AnswerID: 246065
Follow Up By: Member - G N (VIC) - Monday, Jun 11, 2007 at 15:07
Year ok,
This also seems to have only the one position?
I was hoping to have 2 positions if possible, so this is probably another negative about the gas struts as they can only be set up to allow a certain max opening.
thanks Kiwi
FollowupID: 506995
Reply By: tuck 01 - Monday, Jun 11, 2007 at 14:40
GN
I have the Kaymar back-end and have 2 problems with the little bent bolt thingy to keep the wheel open.
Often, the bent bit does not fall down into the keep-it-open position when you open the wheel. This means you can let the wheel go and it falls back onto you (or the tail gate) if on a side-slope.
Secondly, as there is a bit of movement in the wheel swing before it hits the bent thingy, it is easy to forget to flick it up and you swing the weight of the wheel against it, straightening the bend and eventually breaking it. I have replaced one so far. The fact that my 4WD shop stocks the bent thingy suggests breakages are common.
One day I'll weld an extra tab on, drill a hole and have a pin to slide in.
AnswerID: 246073
Reply By: Member - Doug T (W.A) - Monday, Jun 11, 2007 at 15:02
This is what K&N looks like
Site Link
AnswerID: 246081
Follow Up By: Member - G N (VIC) - Monday, Jun 11, 2007 at 15:15
Hi Doug
Looks good, simple and effective it looks to me.
Plus it has a bit more distance from the pivot to the holding point so much more robust than some others.
I think this it the winner so far, still keen to see how the nissan set up works?
Was also wondering if i could just over tighten the wheel bearng to get enough load?
Thanks GN
FollowupID: 506996
Follow Up By: Peter 2 - Monday, Jun 11, 2007 at 18:53
when i built my carrier I used this same springloaded gate latch, works well, I'll try and attach a pic.
I made little ramps so it locks automatically, just lift up to release.!MPG:8!
FollowupID: 507030
Reply By: Member - G N (VIC) - Monday, Jun 11, 2007 at 15:19
Note to "outandabout david" your email address failed cob!
AnswerID: 246086
Reply By: jeffwa - Monday, Jun 11, 2007 at 17:08
The swing arm on the surf (a factory toyota jobby) just uses a basic pin. It works well and has never let me down.
Basically the pin looks a bit like an allen key in that it is just a bit of metal with a 90 degree bend in it. When it's not being used is clips into a clip but also has some string attached to it so that you can't drop it.
It sounds crude but it's quite need and as simple as you can get.
All you do when you open the swing arm and are on a hill or somthing (most times you don't need to use it as the swing arm just leans against the tailgate) then you just unclip the pin and slide it through the hole.
AnswerID: 246102
Reply By: Hairy - Monday, Jun 11, 2007 at 21:25
Gday
I put a gas strut on mine. Works well
AnswerID: 246193
Reply By: Rossco td105 - Monday, Jun 11, 2007 at 21:58
Hi GN,
Have tried a couple of set-ups now.
Fitted home made gas strut to over bumper style Kaymar, which worked well, only has two positions though as you mentioned... opened or closed. Had to do this due to always bending locking style bolt that they come with!
New ARB rear bumper worked pretty well, with gas strut and two locking positions for swing arm, don't have car know unfortunately (so can't take pics for you), but some ARB dealers have this system on display if you would like to check it out.
Strut didn't work as well as my set-up on steep side-on hills though, tended to over power the strut. I used a rubber 'buffer to stop my strut set-up bouncing the swing arm at max open position.
Seeing as your making your own carrier you could have the best of both worlds, decent strength gas strut with multi position locking tab.
Ross.
AnswerID: 246206
Reply By: Member - Patrol Geoff (QLD) - Monday, Jun 11, 2007 at 23:28
I've got the (gas strut) Opposite Lock carrier. It has the flipover bent metal thingy like KiwiAngler posted. Actually, the guys who fitted it forgot to install it, so I've got the bits sitting in the garage ready to bolt on.
You are right about the swing arms not staying open when on an incline (at least on mine that is the case). Mind you, the bent metal "lock" seems pretty flimsy and tacky to me too.
A friend has just got a strong-arm carrier. It had a locking mechanism somewhat like the one in the link posted by Doug T. The only thing to watch with those ones is if it isn't latched up when you open/close it, it will scratch the bar (if you care about that sort of stuff). But the latch looked like it would at least do the job. You could easily drill a couple of extra holes if you wanted additional opening angles.
-geoff
AnswerID: 246233
