Cooper tyres on Pajero
Submitted: Monday, Jun 11, 2007 at 20:49
ando24
I am running cooper STT 265/75/16 on my NP pajero DiD and are loosing between 300 and 400 k's out of a
tank of fuel, just wondering if anyone has come across this problem.
Reply By: Member - Vince B (NSW) - Monday, Jun 11, 2007 at 21:40
Hi Ando.
The 75 series tyres aren't giving a false speedo reading by any chance?
246201
Follow Up By: Member - Vince B (NSW) - Tuesday, Jun 12, 2007 at 19:14
Hi again Ando.
I had a set of coopers on my previous NL pajero.NEVER AGAIN WILL I BUY COOPERS!!!.
tHE TYRES STILL HAD PLENTY OF TREAD LEFT BUT THEY DEVELOPED TREAD SEPERATION. I sold the pajero & replaced the tyres as the steering wheel developed a strange wobble above 80kph.
I now have have a np model & will replace the bridgestone tyres when they wear out.
Regards.
Vince
507236
Reply By: Member - jeff M (SA) - Monday, Jun 11, 2007 at 22:26
Hi ando,
300 - 400k's that would half a
tank then wouldn't it.Do you mean 30 or 40 k's ??
Cheers Scoof.
246214
Reply By: Gronk - Monday, Jun 11, 2007 at 22:56
Ahh, Coopers!!!! One of the lugs has come off and tore a hole in your
tank !!!!!!!
He, he, he...............
246227
Reply By: marq - Tuesday, Jun 12, 2007 at 05:19
I assume you have an AUTO?
If you will find the auto torque convertor is not locking and if your not careful (ie run in 4th) you will
cook the auto fluid fairly quickly.
I believe the manual isn't as bad with the fuel...
246248
Follow Up By: marq - Tuesday, Jun 12, 2007 at 05:26
If you have an AUTO DiD Pajero - I recommend you stay with original size rubber. Unfortunately only BFG make LT A/T tyres for 265/70;16
507140
Follow Up By: Dean - Tuesday, Jun 12, 2007 at 10:35
marq fyi, Simex do a C load AT in LT265/70/16, I have one as a second spare, however I am running BFG's now and are far better than others I have had.
Dean
507162
Follow Up By: marq - Tuesday, Jun 12, 2007 at 16:32
"C" load is no good for Pajero (hence only one choice) - it's a real pain in the >>>>
I guess the other option is 245/75/16 (bit norrower than 265/70/16 - but large choice of brands in L/T's)
507198
Reply By: Member - lyndon K (SA) - Tuesday, Jun 12, 2007 at 22:28
Had Coopers once, only ONCE!!!
246463
Follow Up By: Shaker - Tuesday, Jun 12, 2007 at 22:36
ONCE, was one time too many for me!
507299
