D40 Navara suspension
Submitted: Tuesday, Jun 12, 2007 at 15:18
ThreadID: 46570 Views:11644 Replies:8 FollowUps:6
Has anyone had anything to do with upgrading the suspension on the D40. With a Blackwidow draw unit, 60 ltr engel plus camping gear and a camper trailer hooked up there isn't to much travel left in fact last trip it bottomed out quite a bit. ARB and TJM both recommended replacing front and rear springs and shocks to the tune of $1800 -$2200. Does any one know if it's to go to this extreme or would something like an extra leaf in the springs be Any help in deciding on which way to go would be appreciated
Cheers Dave
Reply By: Stu-k - Tuesday, Jun 12, 2007 at 15:39
If your happy with the ride and lack of clearance then why waste the money, I would probably look at air bags before an extra leaf so as to keep the ride nice when empty.
Cya
Stu
AnswerID: 246325
Reply By: Member - extfilm (NSW) - Tuesday, Jun 12, 2007 at 15:45
Hey itsdave,
I got a d22 and although unloaded the rear springs are flat...... Couldn't bear the thought of loading up the tray with 850kg of fuel, water and supplies.
Went to suspension place and for $455 they would add another leaf.
Don't want to spend too much as am selling it upon my return of my next adventure
AnswerID: 246327
Reply By: Chris & Debbie - Tuesday, Jun 12, 2007 at 16:30
Hi Dave
I have just had TJM suspension fitted to my D40 a couple of weeks ago and barted the price down to $1645 fitted, inculding greasable shackles and urethane bushings. Went with the 40mm lift front and rear with the 150kg springs rear (intermediate), the ride is firmer but is still just as comfortable and not harsh, it has made a big difference on corrugated roads where it doesnt float around like it did before.
I was having the same problem as you with the camper on and gear in the back which was the reason for the upgrade, I also looked at an extra leaf or airbags but decided on the package as I also wanted the front lifted, and the extra clearance does make a difference, I have not had a chance to load it up for a full test yet but we are heading out for a few weeks next month so hopefully it will prove itself worth while.
Cheers, Chris
AnswerID: 246335
Follow Up By: itsdave - Tuesday, Jun 12, 2007 at 17:32
Hi Chris
Looks like I'll go the same way as you with front and rear. I think just doing the rear may still leave it a little soft in the front if its not done as well and also the rear would be higher I'd imagine. Be interesting to see how it handles loaded up
Cheers Dave
FollowupID: 507206
Reply By: Teabag (Queanbeyan) - Tuesday, Jun 12, 2007 at 17:09
Try this....
caloffroad.com.au/nissan_lift_kits.htm
Owners name is Cal Goodman and is in Berridale NSW depending on where you are?
AnswerID: 246341
Follow Up By: itsdave - Tuesday, Jun 12, 2007 at 17:25
Little bit far to travel unfortunatly as I'm on the Gold Coast. Pity as we came thru the Snowys 8 weeks ago on our last trip.
Thanks anyway
FollowupID: 507205
Follow Up By: Teabag (Queanbeyan) - Tuesday, Jun 12, 2007 at 17:41
Maybe he has a kit you can buy and install yourself or your local mechanic? They look like awesome suspension systems.....
FollowupID: 507209
Reply By: Member - Bucky (VIC) - Wednesday, Jun 13, 2007 at 06:13
I had Ride Pro suspension package fitted to my D22, and the difference it made was nothing short of brilliant.
follow the other posts
PostID: 41523
Bucky
AnswerID: 246484
Reply By: montana - Thursday, Jun 14, 2007 at 10:33
chris and debbie, could you measure how high your d40 is from centre of axle to guard on front and rear, im looking at changing mine ,but want to find out how high 40mm gives first. thanks allan
AnswerID: 246732
Follow Up By: Stu-k - Thursday, Jun 14, 2007 at 11:47
Isn`t 40mm....40mm?
FollowupID: 507546
Follow Up By: itsdave - Thursday, Jun 14, 2007 at 17:45
Hi Chris
The front measures 480mm from centre of wheel to guard and the rear is 505mm. Although I dont think this is an accurate measument on the rear because of the load in the back i.e Black widow drawer unit and the 60ltr Engel. Looks like I wont be able to go with the springs and shock idea as I wont have enough clearance to get into the Garage (also have roof racks on)
Cheers Dave
FollowupID: 507616
Follow Up By: Chris & Debbie - Thursday, Jun 14, 2007 at 19:33
Sorry guys i am away working at the moment and wont be home for another 3 weeks so I am unable to take measurements, but im sure it ended up just over 40mm higher than original, front and rear as they log the before and after measurements for warranty records.
Thats a shame about the height problem Dave as it is worth the mone in my opinion, looks like you might have to go the airbag route.
Chris
FollowupID: 507651
Reply By: Member - John A (SA) - Thursday, Jun 14, 2007 at 17:43
G'day Itsdave
We have one at work with canopy, _Affordable_Storage_Drawers.aspx, fridge, lr tank & a heap of tools so it weighs in at 2.85t with a full fuel load.
We had ARB Mackay install HD suspension upgrade front & rear & are very pleased with it.
Its a great "car" to drive, highway or corrugated dirt roads.
Why don't you try getting Nissan to pay for heavier suspension? If the ute is still within its rated load then the rig as sold should have suspension to cope with it!
Good luck.
John A
AnswerID: 246821
Reply By: Member - warren B (QLD) - Thursday, Jun 14, 2007 at 21:15
put a 2 inch tjm lift under mine with air bags made it twice the ute from standered if you have the bucks you will love the result
AnswerID: 246869
