thermos/flask
Submitted: Tuesday, Jun 12, 2007 at 15:32
ThreadID: 46571 Views:4486 Replies:3 FollowUps:6
im in the market for a thermos/flask with a wide top so i can fit hot dogs in & would like to the best ones around that stay hotter/warmer for longer thanks in advance
Reply By: Kev M (NSW) - Tuesday, Jun 12, 2007 at 15:49
Check this post out,
Site Link
Cheers Kev
Russell Coight:
AnswerID: 246328
Reply By: pt_nomad - Tuesday, Jun 12, 2007 at 16:37
I have a SIGG thermos that is about 750mm. I cook the dogs and then pre heat the thermos, drain pre heat water, add the still hot dirty dogs to the thermos and then add fresh boiling water.
I can fit in enough dogs for 3 kids under 12 - skinny long dogs not short fatties.
Pack the dogs in the morning and they are still v. hot at lunch time.
The archive post by Robin was a good read.
I also have had varing degress of success with thermos's. I now have a few rules on storing them.
Store them vertically - the body is insulated but the cap aint. If the hot water is in contact with the cap you will loose heat quickly.
Give them a sleeping bag. Add to the insulation by wrapping them in somthing. Store them between cloths bags or wrap with a towel.
I have found the above helps greatly - esp. with the cheaper thermos's.
PS - I got the SIGG OS, I expect you should be able to get them in Oz.
Paul.
AnswerID: 246337
Reply By: kampenman - Tuesday, Jun 12, 2007 at 17:10
hi there,
while on the thermos topic, i am looking for the old type that you filled with water and then made a fire under it and it had a hole in the top middle for the smoke , anyone know the ones i mean and can you get them any where.
and i have just brought a small food thermos that holds 470mls and says will retain it's hot temperature up to 7 hours and cold temperature up to 9 hours. was $ 30 at camping store here in nerang. have hot water in it as we type so will let you know how it go's
cheers pete
AnswerID: 246342
Follow Up By: Member - Phil G (SA) - Tuesday, Jun 12, 2007 at 17:55
Pete,
I think they are called a Volcano. Get nice stainless steel ones at The Australian Geographic Shop. Many camp stores (Like Snowys in Adelaide) have other versions of the same thing. Few sticks and a bit of paper underneath and water is boiling 10-15minutes later.
Some friends have one, and use it occasionally, but I still prefer a thermos.
FollowupID: 507215
Follow Up By: Kev M (NSW) - Tuesday, Jun 12, 2007 at 18:09
Pete,
I got mine from BBQ's Galore about 9 years ago and it cost $109, didn't get the metho adaptor or the wooden carry box.
It is called THE AUSSIE BUSH KETTLE,
available from the Aussie Bush Kettle PTY LTD,
Ph 03 5625 3421
Cnr of gould Street and Weebar Rd,
Drouin, Vic, 3818
Aust
Cheers Kev
Russell Coight:
FollowupID: 507219
Follow Up By: Member - Phil G (SA) - Tuesday, Jun 12, 2007 at 18:36
Thanks Kev, that's the one!
link 10554 also has a few options for where to buy them, and similar ones.
FollowupID: 507226
Follow Up By: Member - Kiwi Kia - Tuesday, Jun 12, 2007 at 18:41
They have them at Rays camping supplies.
Known originally in NZ as a Bengazi (sp?) boiler as the troops are suposed to have invented them in Egypt during the war. Also known as a "Thermet" (brand name)
FollowupID: 507227
Follow Up By: kampenman - Tuesday, Jun 12, 2007 at 19:12
hi Kev,
thanks for that, i found the thing i am talking about . it's called the ned kettle and it's on the australia in-sight. it made of copper though which is why they are so dare. I just skyped my brother in nz and he is going to check them out over there. thermets or some thing like that. we use to use one when i was working on a road gang about 30 years ago whould make around 10-12 cuppas.
cheers pete.
FollowupID: 507235
Follow Up By: Kev M (NSW) - Tuesday, Jun 12, 2007 at 19:22
Phil,
I found that post as well but it didn't have any details of the manufacturer.
Kev
Russell Coight:
FollowupID: 507241
