2.8 GU 1998 patrol clutch
Submitted: Tuesday, Jun 12, 2007 at 16:56
ThreadID: 46575 Views:2419 Replies:3 FollowUps:3
Some people have suggested that I replace the clutch and flywheel with a solid flywheel and generic heavy duty clutch. Has anyone had experience with this arrangement? Also, what mileage have people got out of their clutch. This GU has had a reasonable life and has towed a trailer for about 5,000K.
Thanks for your replies.
Reply By: Patrol22 - Tuesday, Jun 12, 2007 at 18:12
Tonka Toy - I would recommend a exeddy hd clutch/solid flywheel replacement. I think they are the only manufacturer who make the full kit. Been thinking about changing mine for some time now but apart from a slight shudder at 1400rpm there is nothing wrong with it. Mine now has 220000km with about 15000km towing a Kanga Camper.
Pete
AnswerID: 246357
Reply By: Member - stefan P (NSW) - Tuesday, Jun 12, 2007 at 18:30
Mine was replaced by the previous owner at 90,000 which means he can't drive manual properly or there was a un-expected failure, I bought the car with 114,000 on it, now has 145,000....but I like to think I am nice to my clutch so I am hoping not to need one for a while now. The nissan service docket that had the clutch repair came to about $2300, so I WON'T be paying that much when my turn comes to replace it!!! So I guess I would look at the after market options as well
Cheers Stefan
AnswerID: 246366
Reply By: rolande- Tuesday, Jun 12, 2007 at 21:04
G'Day All,
I faced the same dilemma last year when a noisy spigot bush pushed the issue.
After some long discussions with my mechanic, I replaced the clutch with an Exeddy Heavy Duty, (as in has a heavier spring, no difference with the clutch plate), and left the dual mass flywheel as is. Mechanic said no hot spots and no sign of anything worn enough to need replacement.
Original clutch changed at 225,000, now at 258,000 including spending most of its time towing 1700 kg caravan and not a single issue.
Total cost including parts came to under $900.
Had other quotes ranging from $1400 - $2500 to do the complete change-over
If dual mass such an issue why do commodore's etc. use them with little complaint?
Rolande
AnswerID: 246428
Follow Up By: Patrol22 - Wednesday, Jun 13, 2007 at 11:14
Rolande
I don't know about no problems with the commodore etc and their dual mass flywheels.......the Brake and Clutch specialists I spoke to in Canberra insist that most of their work comes from this sector of the market.
FollowupID: 507366
Follow Up By: Patrol22 - Wednesday, Jun 13, 2007 at 11:17
...not saying their is a particular problem with dual mass per se ....it is just that you can't (easily???) machine a dual mass flywheel - indeed most place simply won't do it - so you have to replace it. The dual mass flywheel for a 2.8 Nissan is around $2.5K and a solid exeddy is <$1K so no decision really!
FollowupID: 507369
Follow Up By: Member - 120scruiser (NSW) - Wednesday, Jun 13, 2007 at 21:40
Its not that people won't surface grind a dual mass flywheel, you can't hold it in the surface grinder.
We change commodores to solid state flywheels as well. Best move you will ever do.
FollowupID: 507472
