99 model jackaroo roof rack
Submitted: Wednesday, Apr 30, 2003 at 16:03
ThreadID: 4663 Views:2547 Replies:6 FollowUps:2
Hi I have a 7/99 jackaroo and was wondering what type of roof rack people use.
Will
Reply By: damien - Wednesday, Apr 30, 2003 at 16:12
Will, most of the larger accessory stores (ARB, TJM etc etc) can supply either steel or alloy racks to suit the Jack.
AnswerID: 18826
Reply By: Member - NOBBY - Wednesday, Apr 30, 2003 at 18:11
Will.. I went down this road about 6 months ago and TJM etc tried to rip me off plenty ( 600- 700 bucks off memory). The answer was to look in the trading post and buy one in there (alluminum) for $100. It was off a F250 so I got out the angle grinder, cut it to size then got a Welding Business to join it all up for me. Cost me $50 for that. Got Rhino racks and together they all go together perfectly and a lot less than original GMH gear. It now takes me about 10mins to put them on or off with the help of the she devil ( only joking). I wouldn't get steel racks because of the weight/ rust factor.
AnswerID: 18837
Reply By: Member - Terry- Wednesday, Apr 30, 2003 at 21:11
Will, I use a full length aluminium roof rack made by endee metals in Bayswater. I bought mine through the Quokka for $400, it is in greatcondition and is light enough for one to carry, however you need 2 yo remove.Brackets are easy to fit yourself ( why pay $100 plus for someone else to do it ).
Takes 5 minutes to remove (12 bolts) and is serving me well.
Terry
AnswerID: 18863
Reply By: Will - Thursday, May 01, 2003 at 15:33
Thanks for the replies Guys.
Just one other thing what system do you use to attach the racks onto the roof.
Will
AnswerID: 18903
Follow Up By: Paul from Roof Rack World - Friday, May 02, 2003 at 00:22
For the Thule system have a look here for the fitting instruction for the jackaroo.
www.thule.com/fitguide/pdf/kit%201091-02.PDF
www.thule.com.au
FollowupID: 11884
Follow Up By: geoff - Saturday, May 03, 2003 at 22:45
Hi Will there are pre-drilled taped holes in the roof and dont worry about the aerodynamics to much I have a roof top tent on my Jack and the fuel changes about 1l per 100k's.
Regards geoff
FollowupID: 11978
Reply By: Member - Royce- Thursday, May 01, 2003 at 19:54
I always try to avoid using a roofrack.... incredible how much extra fuel is used with even an empty one on board. Pay careful attention to the aerodynamics.Royce www.funshow.com.au
AnswerID: 18924
Reply By: Paul - Friday, May 02, 2003 at 00:02
Firstly, what do you want to carry? Obviously aerodynamics is important, however safety is more important, and if you are concerned with aerodynamics find the roof rack which is easiest to take off altogether = best aerodynamics.
AnswerID: 18947
