Poor Tasting Water in Camper
Submitted: Wednesday, Jun 13, 2007 at 23:05
Brian B (Brisbane)
Hi Folks,
We recently got into a new Goldstream Camper and we are happy with it.
When we are either hooked up to mains
water or drawing our supply from the
tank the initial burst of
water is always tainted. After a while it goes away and the taste is good.
I fill with a food grade hose and the supply is clean so I am thinking it may be coming from the new plumbing fittings Goldstream have used.
I had a look through the archives and couldn't find much on this specific problem.
Does anyone have any experience with this type problem and are there any solutions out there?
Thanks in advance.
Reply By: Derek from Affordable Batteries & Radiators - Wednesday, Jun 13, 2007 at 23:14
6 to 8 drops of bleach per gallon.
There are also drops available from boat shops.
Derek.
246683
Follow Up By: Brian B (Brisbane) - Thursday, Jun 14, 2007 at 09:42
Thanks Derek
507534
Reply By: Derek from Affordable Batteries & Radiators - Wednesday, Jun 13, 2007 at 23:17
Water Treat
246684
Ok mate thanks for the info.
507535
Reply By: Ian from Thermoguard Instruments - Thursday, Jun 14, 2007 at 08:18
A teaspoonful of sodium bicarbonate (bicarb soda) in plastic tanks is supposed to help a lot. I suppose you could flush a weak bicarb solution through your mains pipes as
246705
Follow Up By: Brian B (Brisbane) - Thursday, Jun 14, 2007 at 09:43
Thanks for the info Ian.
507536
Reply By: traveller2 - Thursday, Jun 14, 2007 at 08:21
Just don't ever put Puritabs or similar in the
tank as you will never get the taste out, it seems to get into the plastic. BTDT.
246707
Reply By: Brian B (Brisbane) - Thursday, Jun 14, 2007 at 09:44
I will steer clear of Puritabs.
246724
Reply By: Member - Matt M (ACT) - Thursday, Jun 14, 2007 at 10:31
Brian,
We had similar problems with the KK and there is no point in treating the
water in the
tank, because it is fine. The initial bad taste comes from
water that has been sitting in the pipes leading from the
tank to your outlet. Once you get to the
tank water, the problem goes away.
Aside from completely re-plumbing with stainless or some material guaranteed not to leave a taste, there is not much you can do about it.
The good news is that it gets better over time, but you will still find that, left sitting for longer periods, the taste will still be there. We got around it by putting the first half a dozen or so pumps into the washing up bucket or to rinse clothes, etc.... Don't try to fill the billy with it, because the taste can beat coffee easily. You just learn to work around it without wasting
water.
That said, I would still go back to the manufacturer to see what they can do about it (take a cup of the
water with you).
Matt.
246731
Follow Up By: Russ n Sue - Thursday, Jun 14, 2007 at 11:03
Interesting observation Matt. We have a similar problem with our KK. I contacted them and they insisted that it was the
water going into the
tank that was tainted. I dumped the
water, flushed the system with solution of Sodium Bicarbonate and refilled through a food grade hose.
It still tasted like plastic. So I figured that maybe they were right - the local
water isn't the best and maybe the dissolved salts in it were reacting with the plastic hoses and fittings to give the taste.
So I repeated the flushing proceedure and this time I filled the
tank with
water I had run through a Reverse Osmosis plant. This
water was perfect! It was tested and only had 3 ppm of impurities. I then pumped it through the pipes of the KK and guess what? It STILL tasted yucky!
I had that
water tested and it was 60 ppm dissolved matter. So obviously the problem is coming from the pipes and taps in the KK. I'm not happy about this because one of the things they make a big deal about in their promotional material is how good the
water is - stainless steel
tank yada, yada.
We have taken to carrying plastic jerry cans of
water for drinking and use the
tank water for washing, showering etc. Disppointing really.
Russ.
507540
Follow Up By: Brian B (Brisbane) - Thursday, Jun 14, 2007 at 22:50
Hi Matt,
Thanks for the info.
507758
Reply By: Member Boroma 604 - Thursday, Jun 14, 2007 at 11:58
Gooday,
Have a look at this site first ( best
water filters) can't work out how to add the link !!!!!!, he gave a talk at ACC Musteer a couple of weekends ago, sounded convincing, bought an inline one to fit after tanks, have not yet fitted it but maybe others have tried them .
Boroma 604
246745
Follow Up By: Brian B (Brisbane) - Thursday, Jun 14, 2007 at 22:51
Thanks for the advice.
507759
Reply By: Redback - Thursday, Jun 14, 2007 at 13:17
My suggestion is to get a
water filter, dual filter ones are the best.
The proper household ones are the go for around $200 there abouts.
I put this in my camper, i can now fill from any
water source.
The 2 filters are for germs and taste.
Then you'll only need to flush and clean your
tank once every 3mths or so.
Baz.
246753
Hi Baz,
Sounds a good idea.
507760
Reply By: Member - Phil G (SA) - Thursday, Jun 14, 2007 at 15:21
Had exactly the same problem with my undertray
tank (Goughs plastic
tank). The clear plastic hose was bad. The shiny light blue Pope brand
drinking water hose was also bad. But once I changed all hoses (incl breather and filler) to the half inch Nylex brand braided light blue
drinking water hose, everything was perfect. Now get absolutely no plastic taste.
Just because a hose is food grade or
drinking water hose, doesn't guarantee that it won't leave a taste.
246797
Follow Up By: Brian B (Brisbane) - Thursday, Jun 14, 2007 at 22:53
Hi Phil,
All that I know so far is that the taste is only in the camper. I can fill other things with the same filler hose and no taste.
I am guessing it is plumbing fittings or hose on the camper.
I will have a talk to the agent as it is only a couple of months old.
507761
