Spare Wheel Carrier Problem
Submitted: Friday, Jun 15, 2007 at 01:21
Jacko1
Just put on BFG All Terrains (LT265 70R 17) to standard rims for 2005 Prado and found it impossible to fit spare to rear door carrier even after removing the plastic protector from the carrier. Has anyone solved the problem, as I am sure I would not be alone with this problem. I am thinking the solution is to put 10mm spacers between the carrier and the door mounting point ? Any suggestions or am I on the right track.
Reply By: Johnny boy - Friday, Jun 15, 2007 at 07:40
Hi Jacko , Mate I havnt got time to look for it Im heading off to work in a sec but try the search engines on this site as I remember someone saying that they had the same prob I think this week or mid last week and they just made some spacers up but someone eles said they bought them on EBAY ?? I think , but yes I think you are on the right track .
Regards J,B.
246965
Reply By: madCrow - Friday, Jun 15, 2007 at 15:37
Hi Jacko
It's a common problem that happens when you up size your gumboots (tyres).
Solutions:
Change rims to ones that have off centred hub mounting position,
or go to ARB, TJM or any good forby toys supply
shop & check out either a Kaymar or ARB rear wheel carrier spacer.
I wouldn't consider the stacked washer scenario as a spacer, unless you want to pay later for the door nuts damage.
The Kaymar or ARB rear wheel carrier spacer are great as they distribute the pressure evenly over a large area as opposed to the stacked washers which focus the pressure quiet severely on to a small area.
Success with your endeavour
madCrow
......(0_o)
\\\\(-><-)///// The large shy bunny wabbit with a wicked hair cut, hides in the grass.
The sound of a wabbits on the grill also makes him sit up straight!
The sound of Elmer Fud on the grill makes him smile!
247060
Reply By: Member - Glenn D (NSW) - Friday, Jun 15, 2007 at 15:53
Do : do a search , fix this yourself for < $10
Dont : go to ARB etc spend a fortune to do the same thing.
Glenn.
247063
